Tosh HD-XA2 1080p HD DVD - First End User Reports!: USERS ONLY PLEASE! - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #451 of 4682 Old 01-21-2007, 05:42 PM
GmanAVS's Avatar
Originally Posted by JimP View Post
BenDover,
Do you have any way of determining what the XA2 is? The A1 is 4:2:2. (according to my plasma HDMI screen) For some reason, I'm thinking its 4:4:4.
Yes, can someone please check this out.
Stacey Spears, have you done an "objective measurement" with the XA2?
GmanAVS is offline
post #452 of 4682 Old 01-21-2007, 06:31 PM
BenDover's Avatar
BenDover,
no, i don't have any way of determining that, unfortunately...
BenDover is offline
post #453 of 4682 Old 01-21-2007, 07:28 PM
J y E 4Ever's Avatar
Liked: 40
Hello everyone.
I finally got rid of my 720p DVI only Samsung plasma and purchased a 1080p Sharp 52" LCD.
Want to laugh?
I went from my PS3 working fine with the 720p Samsung even though it was going thru my Onkyo 674 receiver and thru an HDMI to DVI adapter but the XA2 would only output 480p because of the HDMI to DVI adapter.
NOW, with my new 1080p HDMI only TV, the XA2 works flawlessly at 1080p but the PS3 can only output 1080i because the Onkyo is having trouble sending the 1080p to the TV therefore the 1080p setting is causing crazy video distortion and breakup as if the screen is having a seizure. Switch back to 1080i and it looks fine.
I know that it's the Onkyo because I connected the PS3 directly to the TV via HDMI and 1080p worked but when the Onkyo was introduced back into the equation the problem came back.
I CAN'T WIN!
Besides all that, one of the two HDMI inputs on the Sharp is dead. You can only hear audio, no video on the screen.
Replacement is already enroute.
J y E 4Ever is offline
post #454 of 4682 Old 01-21-2007, 08:07 PM
Lars158's Avatar
BenDover,
For the XA2 it is also 4:2:2 (according to my ABT VP50)
Lars Berglund
Plano, TX
Lars158 is offline
post #455 of 4682 Old 01-22-2007, 05:29 PM
stevekaden's Avatar
I just finished making an order with Value Electronics for an XA2 and some discs. Just as so many people said, they are great. I had some special situations to deal with and Graham, my CS person, was patient with those details AND my penchant for telling all the stories behind the points.
A pleasure to do business with them and a good deal too (not to mention it was in Stock!)
Now if shipping just doesn't make a mess of this...I might offer some observations in a few days.
Partying my new XBR75-X940D, soon new Denon X4200 AVR
stevekaden is offline
post #456 of 4682 Old 01-22-2007, 11:30 PM
bembol's Avatar
I guess I should've waited for my HD-XA2 to arrive before selling my HD-A1! LOL
The store I deal with ran into some delay...should arrive by the end of this month. This is killing me, the reviews on this is really amazing!
bembol is offline
post #457 of 4682 Old 01-23-2007, 04:09 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 327 Post(s)
Liked: 6701
Is the YCbCr 4:2:2 8bit or 10bit? (if you can determine)
larry
Ich bin hier und du bist mein Sofa
PooperScooper is offline
post #458 of 4682 Old 01-23-2007, 05:06 AM
Quoted: 1701 Post(s)
Liked: 731
If both XA2 and A1 are both 4:2:2, then my theory they were using different specs resulting in different "snap" is shot down. Although the different specs should result in the same picture, I can tell a difference on my display. My methodology is to put up a color bar pattern using a HD signal generator and photographing it with RGB and then 4:2:2 off of the screen. The difference although slight is probably attributable to how the display was calibrated at the factory.
JimP is offline
post #459 of 4682 Old 01-23-2007, 04:06 PM
BadassBuddy's Avatar
G-damnit! The device worked like a charm for several days. Got to enjoy Jet Li's Fearless in hi-def, several standard-def films, but started to watch Batman Begins today and stopped about 30 mins into the film. When firing it back up a couple hours later, the device no longer reads ANY hi-def DVDs. Getting the error: This disc is not DVD format. Cannot play the disc.
My a$$ it's not. The player has suddenly turned into a non-hi-def DVD player. Standards play fine. Fookin lemon. Toshi is going to fix the device but c'mon, 5 days after receiving it? Do I follow through with the Toshi service and settle for a 5-day-old refurbed device, or do I contact the vendor?
Thanks folks
BadassBuddy is offline
post #460 of 4682 Old 01-23-2007, 04:08 PM
Robert D's Avatar
Thanks folks
Try holding the power on button on the player in for ten seconds until it turns off. This will force a re-boot of the player.
Robert D is offline
post #461 of 4682 Old 01-23-2007, 04:42 PM
That actually did something but it didn't resolve the problem. It recognized the GoodFellas Hi-Def DVD, but it didn't seem to want to play the disc. Then inserting the Batman Hi-Def resulted in the same error MSG. If this reboot method actually did prove to be helpful, do we spend the rest of our lives rebooting our thousand dollar machines like fools? Is this thing running Windows 95 or what?
Thanks for the advice brother.
EDIT: Correction! After soft-rebooting the machine, then hard-rebooting (leaving it unplugged for 5 mins), i'm able to watch Batman again! What a flakey machine! Do I wait for a firmware upgrade before sending this thing back to Toshi? Thanks again man!
post #462 of 4682 Old 01-23-2007, 05:49 PM
lgans316's Avatar
Quoted: 74 Post(s)
Liked: 47
At first my apologies for posting in spite of not being an End User. As a prospective customer I would like to mention the below.
Both XA-2 / XF2 (A2) shares the same HD DVD Drive. Being a Premium model I expected Toshiba to put a better drive. I am waiting for the mid range HD-A20 as it can output 1080p and may contain some upgrades over the HD-A2 / XA-2.
I think the HD-XA2 may arguably be the best upscaling DVD Player though HD DVD performance may just be equal to it's cheaper brother A2 which is not expected from a premium model.
I don't remember exactly where I saw but I am sure that HD-XF2 (A2) HD DVD drive is Made in Japan. However the HD-XA2 HD DRIVE seems to be completely Made in China. Pretty misleading at the moment. The Toshiba HQ is just few blocks away from my work place. If time permits and if possible let me check and revert back.
Blu-ray : 340
lgans316 is offline
post #463 of 4682 Old 01-24-2007, 10:40 AM
mediahound's Avatar
The A20 is supposed to have the same chipset as the A2. Whereas the XA2 has a different better chipset. You will probably still find that the XA2 upconverts standard def DVDS even better than the A20 or A2.
mediahound is offline
post #464 of 4682 Old 01-24-2007, 11:17 AM
Gary Murrell's Avatar
it will be worth your wait, the XA2 smokes the 1st Gens and the A2
-Gary
Gary Murrell is offline
post #465 of 4682 Old 01-24-2007, 11:30 AM
lorelevitt's Avatar
You should have bought from Robert at VE....
lorelevitt is offline
post #466 of 4682 Old 01-24-2007, 06:16 PM
TurboVis's Avatar
Just got mine (XA2) from Robert @VE today, running it through a 70" Sony SXRD.
AWESOME!! Player has been on several hours without a hitch, upscaled IRobot looked great and Waterworld and Riddick were excellent!! Robert's service is outstanding.
Upscaler is better than my Sony (keeping the Sony)or the Pio (both B-Ray) I will be taking back soon. Format Neutral!
Haven't really had a chance to play with it but any suggestions on settings overall as all I have done is plug and play?
TurboVis is offline
post #467 of 4682 Old 01-24-2007, 10:02 PM
Scott Gammans's Avatar
Just got my HD-XA2 from VE and have already noted two big problems:
(1) The audio on all multi-channel outputs (5.1 analog, optical and coaxial digital) has a bad distortion problem. With both of the discs I tried (Batman Begins and Brokeback Mountain) I had to turn the XA2 off and then on again because the first time I try to play the disc the audio sounds all scratchy and off-pitch.
(2) The player is connected to my Lumagen VisionHDP processor's DVI1 port (I run all my connections through the Lumagen--only one DVI cable runs to the projector). I have noted that if the projector and/or Lumagen are already on and I turn the XA2 on last, I get nothing but white snow. I have to physically unplug and plug in the HDMI cable for a picture to appear.
Not a good start for the HD-DVD half of my Neutral Zone, especially compared to the flawless performance I experienced with the other half. Hopefully the latest firmware update will fix both of these issues. I can live with the HD-DVD player having to be the first thing turned on, but that audio problem is a deal-killer.
Scott Gammans is offline
post #468 of 4682 Old 01-24-2007, 10:19 PM
Robert D's Avatar
How are you getting the audio to your receiver via Toslink or analogue? Have you tried changing the audio settings in the players setup?
Robert D is offline
post #469 of 4682 Old 01-25-2007, 02:44 AM
joerod's Avatar
Quoted: 720 Post(s)
Liked: 653
Your best bet is to cycle thru the AUDIO button on the remote when the High screeching starts. It will go thru the 3 different languages but when it comes back to english it will stop. That should work for awhile. How long I am not sure. Just do it though...
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #470 of 4682 Old 01-25-2007, 06:36 AM
applejackaz's Avatar
The white snow happens both with my XA2 and my DVI TV input and my A1 to my DVI computer monitor. Switching to another input and back solves the problem in both cases. Any one else?
applejackaz is offline
post #471 of 4682 Old 01-25-2007, 06:54 AM
I'm not at home right now but I'm using whatever the default setting for audio is "out-of-the-box". When I get home tonight I'll try some of the other settings to see if that ameliorates the problem.
Sounds like you've encountered this issue before. Sorry, but that's not an acceptable solution... the screeching is REALLY bad. Hopefully Robert's suggestion will cure this.
And it sounds like you have encountered this issue before. I played with the unit some more this morning before coming to work, and the thing is, even if I turn on the XA2 first I'm not always guaranteed that I won't get snow. In other words, the snow workaround I described above isn't consistently occurring.
post #472 of 4682 Old 01-25-2007, 07:44 AM
bwclark's Avatar
Installed the XA2 a couple of days ago and so far so good!
Excellent operation w/o any issues. PQ/SQ is great.
Very pleased with units operation and performance.....great job Toshiba
HD DVD ROCKS!
bwclark is offline
post #473 of 4682 Old 01-25-2007, 08:10 AM
Josh Z's Avatar
Quoted: 2420 Post(s)
Liked: 1589
The Firmware Update thread is swamped with posts about the A2 update, so I've stopped reading it. Can someone post here when the XA2 update is made available?
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #474 of 4682 Old 01-25-2007, 08:13 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Just got my HD-XA2 from VE...
Not a good start for the HD-DVD half of my Neutral Zone, especially compared to the flawless performance I experienced with the other half. [That] audio problem is a deal-killer.
I encounted the exact same issue with my XA2, along with several other issues, and it was a deal-killer for me since there was no rhyme or reason to it that I could detect. I went back to the A2 and all has been well since.
bferr1 is offline
post #475 of 4682 Old 01-25-2007, 10:05 AM
A coworker of mine also has the HD-A2 and reports no problems with his player, either. I'll tell you what, if I can't get this thing to work I'm sending it back to VE for an A2. This was supposed to be an interim player anyway, since I was planning on selling it as soon as an HD-DVD player with 7.1 analog outputs surfaces.
post #476 of 4682 Old 01-25-2007, 10:43 AM
hdtvhdtv's Avatar
Thanks folks
This is why more CE companies should step into the Production of HD DVD players.
Giving the consumer choices. As of today Toshiba being the only player in the game, does not pressure them into extensive Quality and control before releasing on the market.
Another thing,. Most of you should not be all that surprise with Toshiba anyway. It's not like they have been known for putting out top notch products prior to HD DVD. They have always been a so so brand in terms of real good quality.
They just happen to be the only player in town making the stand alone players, so therefore we are forced to go with them should we want one.
hdtvhdtv is offline
post #477 of 4682 Old 01-25-2007, 02:59 PM
After a couple of hard/soft resets the unit is working flawlessly and totally mind-blowing, but i agree, it's too bad Toshi is the only competitor in the market. If you have the cash and are dying for Hi-Def ASAP, get this unit. Patience, however, is a virtue, especially in the electronics industry.
post #478 of 4682 Old 01-25-2007, 03:10 PM
joerod's Avatar
Quoted: 720 Post(s)
Liked: 653
I agree 100% with your post!
joerod is offline
post #479 of 4682 Old 01-25-2007, 05:58 PM
Good news! I figured out both issues with my HD-XA2.
The white snow issue was caused by the Lumagen VisionHDP scaler being turned on before the HD-DVD player was fully booted up. The XA2 has to be turned on and must go through enough of its boot-up sequence to get to the point where "HD-DVD" shows on the display. Once it's gotten that far, I can turn on the VisionHDP. I'll just have to program the startup macro on my MX-3000 universal remote to start the XA2 and then wait about a minute before turning on the scaler. It doesn't seem to matter whether my InFocus 333 projector is on before or after any of this, btw... it's the scaler timing that's key.
The sound issue was solved exactly the opposite way: the Outlaw 990 preprocessor has to be on before the XA2 is turned on. It doesn't matter whether I'm using the SPDIF or 5.1 analog outputs, and it doesn't matter whether the SPDIF is set for Bitstream or PCM.
So to summarize, the startup sequence needs to be:
  • Projector (can come on at any time)
  • Audio preprocessor/amplifier
  • HD-XA2
  • Wait ~ 1 minute
  • Scaler
The next test will be whether the XA2 works with the HDMI switcher I bought to switch three of my three high-def sources (the XA2, my DMP-BD10, and my high-def TiVo). I'm crossing my fingers!
post #480 of 4682 Old 01-25-2007, 06:25 PM
DTV TiVo Dealer's Avatar
Great detective work Scott. Very happy you solved the issues.
-Robert
DTV TiVo Dealer is offline
Reply HD DVD Players
