HD-A2 and HK AVR635 Audio problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-01-2007, 07:46 PM - Thread Starter
mlydon's Avatar
Just watched Serenity on a HD-A2 connected via optical to a Harman Kardon AVR635. I had to change the A2 to PCM as opposed to Bitstream because of an annoying echo whenever there was dialog. Doing this fixed the echo problem but the surround just didn't sound as good anymore. Is this normal?? I have the dynamic range set to off as well as the dialog enhancement. Is anyone else having this problem? I threw in King Kong as well and same issue but with a standard DVD, it sounds fine. I'm no expert by any means so any advice on things to try would be appreciated.
mlydon is offline
post #2 of 5 Old 01-11-2007, 03:07 PM
andy503's Avatar
I wondering if it could be that the 635 can't decode HD audio signal.... have you tried to do a reset on it?
andy503 is offline
post #3 of 5 Old 01-11-2007, 06:23 PM
millerman3732's Avatar
Isn't the A2 supposed to convert the HD audio signal to DTS before it sends out through the optical cable. I had my A1 ran to a 635 via optical cable and never had an problems with echos.
millerman3732 is offline
post #4 of 5 Old 01-11-2007, 06:39 PM - Thread Starter
mlydon's Avatar
That was my understanding as well so I'm not sure what he means...though there was something about older receivers not being able to handle the 1.5Mb DTS data stream. I had about 10 minutes before the wife took over the TV tonight and played with the avr635 EZ-EQ settings and turned off the Logic 7 setting and I "think" the problem is resolved. I'll watch King Kong this weekend to be sure.
mlydon is offline
post #5 of 5 Old 01-11-2007, 06:48 PM
Good to hear.
Reply HD DVD Players
