Toshiba: 1st gen FW 2.2 available- see first post for FW ISO - AVS Forum | Home Theater Discussions And Reviews
post #1 of 744 Old 04-27-2007, 01:08 PM - Thread Starter
David Susilo's Avatar
Quoted: 637 Post(s)
Liked: 593
report your findings here
update: the 2.3 ISO can be downloaded here:
http://tacp.toshiba.com/tacpassets-....ware.asp<br />
-- THANK YOU none74 FOR THE LINK !!! --
IF YOU HAVE HAPPY FEET PROBLEM try the following:
1. update FW to 2.2
2. clear Persistent Storage
3. shutdown player
4. unplug player
5. press power on player (yes, AFTER unplugging)
6. wait for about 1 minute
7. re-plug power
8. restart player and play the disc.
My disc problem solved forever after doing the above sequence.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #2 of 744 Old 04-27-2007, 01:18 PM
Sarcoptic's Avatar
Are you kidding me, G2 better be around the corner....
Otherwise congrats to the G1 people heh
Sarcoptic is offline
post #3 of 744 Old 04-27-2007, 01:27 PM - Thread Starter
Quoted: 637 Post(s)
Liked: 593
I think this is to fix the HDMI-DVI issue. As usual, Toshiba Canada is completely oblivious with the existence of 2.2 "there is no such thing as version 2.2, Sir"
my home theatre
post #4 of 744 Old 04-27-2007, 01:39 PM
bitemymac's Avatar
downloading started.... still at 0%...flashing...
bitemymac is offline
post #5 of 744 Old 04-27-2007, 01:43 PM
b.greenway's Avatar
wait a min, wasn't 2.1 just a few weeks ago? blargh I'm getting gen1 and gen2 mixed up now.
b.greenway is offline
post #6 of 744 Old 04-27-2007, 01:44 PM
erick granato's Avatar
Quoted: 38 Post(s)
Liked: 31
David- just got my 2.1 version 5 minutes ago in the mail. I have a dvi-hdmi cable for my set up and have read here about the problems with 2.1. Called Toshiba Canada (yes there was somebody there at 4:30 est.) and they had no clue that there was a problem with firmware 2.1 and said that their engineers would have analysed my situation and sent out the firmware to fix. But I have had no problems with 2.0. I think I should wait for the responses from other 1st gen users before updating to 2.2, forget about 2.1.
erick granato is offline
post #7 of 744 Old 04-27-2007, 01:49 PM
realracer2's Avatar
Thanks, updating mine now, at 10 percent.
realracer2 is offline
post #8 of 744 Old 04-27-2007, 01:49 PM
TommyV's Avatar
hopefully this fixes the DVI problems for the DVI users. Pretty cool Toshiba jumped right on the problem and came out with a fix. I wonder if this is the only difference between 2.1. Maybe it works on the HDCP handshake as well. 2.1 has been great for me but I also use component video. Can anyone test the boot and loads times before and after updating?
TommyV is offline
post #9 of 744 Old 04-27-2007, 01:53 PM - Thread Starter
Quoted: 637 Post(s)
Liked: 593
The cluelessness of tech support of Canadian company is astounding. I face the same problem with Canon, Nikon, Samsung, Sony and now Toshiba. The only company that still great are Yamaha and Pioneer.
my home theatre
post #10 of 744 Old 04-27-2007, 02:03 PM
Quoted: 38 Post(s)
Liked: 31
Yes they have no clue-when I told the tech guy that I heard about the problems with 2.1 he asked me where I heard this and I told him AVS FORUM and he said that if I did not get the information from Toshiba Canada's website or directly from Toshiba Canada that it was not true and not to listen. I trust what the people around here experience before I trust some dude on the phone from Toshiba Canada. Please update us on 2.2. Thanks guys (and girls).
post #11 of 744 Old 04-27-2007, 02:15 PM
Sumo-Zwerg's Avatar
good job toshiba!
i update my hd-xe1 (german version from the hd-xa2) today and now i can download update 2.2 for my hd-a1.
which company worries in such a way about old products as toshiba?
Sumo-Zwerg
Sumo-Zwerg is offline
post #12 of 744 Old 04-27-2007, 02:19 PM
IcemanDallas's Avatar
I just loaded 2.2, took a long time, almost an hour. I downloaded it because my A1 would not play Relentless Enemies. It will play now, will update after playing some disks that had given me minor probs in the past...like MI3. It would almost always freeze when they started across the bridge.
IcemanDallas is offline
post #13 of 744 Old 04-27-2007, 02:21 PM
TommyV's Avatar
Iceman did you update from 2.0 or 2.1? Were you having those disc problem on 2.1?
TommyV is offline
post #14 of 744 Old 04-27-2007, 02:22 PM
chad_cincy's Avatar
This appears to have fixed the HDMI->DVI issues for my setup. A1 to a Lumagen HDP.
Mark me as a happy camper.
chad_cincy is offline
post #15 of 744 Old 04-27-2007, 02:23 PM
jorgerod's Avatar
I wish this one would really solved my Skips and locks. After 2.1 MI:3 still locks at the bridge and Happy feet locks at the Graduation splash scene.
Jorge
Audio Enthusiast, HD Videophile.
jorgerod is offline
post #16 of 744 Old 04-27-2007, 02:24 PM
bitemymac's Avatar
Yup... HDMI/DVI fixed.... one thing I did notice is that it boots faster now... takes about 22 sec to see the welcome screen.
post #17 of 744 Old 04-27-2007, 02:27 PM
hconwell's Avatar
Geez, I have to go out and play a gig tonight. Won't have time to try on 2.2 'til tomorrow.
I'll be reading this thread with much interest. I had to move over to component with 2.1 ... it killed my HDMI (out) > Gefen switch HDMI (in) > DVI (out) > IN76 M1-DA (in).
Hank Brown
"Being at the right place at the right time is purely a function of being at the right place a lot."
JPEG's of my Home Theater.
hconwell is offline
post #18 of 744 Old 04-27-2007, 02:37 PM
Mr. Cinema's Avatar
Wonder if this will fix issues those are having with Universal combo discs.
Mr. Cinema is offline
post #19 of 744 Old 04-27-2007, 02:42 PM
I think I had 1.4, I had never upgraded before since everything was working, except MI3.
post #20 of 744 Old 04-27-2007, 02:53 PM
Jayderek's Avatar
cool that this fixes the DVI problems for you all that were affected.
I'll wait and see what others think of 2.2. When i upgraded to 2.1, it really helped playback in most of the discs...so i'm hesitant right now to upgrade unless this fixes more than the DVI issue...
~Jason
~Jason
Jayderek is offline
post #21 of 744 Old 04-27-2007, 02:58 PM
kami's Avatar
The update notes on Toshiba's site for 2.2 are identical to 2.1....looks like they didn't update it unless 2.2 actually adds more network functionality than 2.1 did.
Can anyone confirm if Stalingrad will recognize now? I guess I'll go update myself and see....not holding my breath.
kami is offline
post #22 of 744 Old 04-27-2007, 03:02 PM
los seres's Avatar
Quoted: 17 Post(s)
Liked: 24
yes can someone confirm.
los seres is offline
post #23 of 744 Old 04-27-2007, 03:08 PM
kami's Avatar
I am updating now so I'll let ya know in 45min or so.
I also timed my bootup and disc load times beforehand to see if they changed.
kami is offline
post #24 of 744 Old 04-27-2007, 03:10 PM
ChodTheWacko's Avatar
My 2.1 works fine (I'm HDMI to HDMI), but the drive head makes a lot more noise now. 'clunk clunk' noises like something broke loose or something. Anyone know if that stopped with 2.2? It's really obvious on say, a menu screen of a dvd when the video loops.
ChodTheWacko is offline
post #25 of 744 Old 04-27-2007, 03:25 PM
bigmac11's Avatar
Just updated and my boot time increased from 51 seconds to 64. Hoping I'll be able to watch my burnt videos and hopefully play thru NIN without skipping. Took 31 minutes to update. Here's hoping for the best for all of us
bigmac11 is offline
post #26 of 744 Old 04-27-2007, 03:27 PM
TommyV's Avatar
~Jason
I'm with you Jason. My playback has been near flawless since 2.1 so I am hesitant to tinker with it.
I havn't heard any clunky noises that some others have reported but mine is in my stand with a sliding front glass door. I tried to listen next to it and I didn't hear anything. My DirecTV HR20 is so loud I probably wouldn't hear anything even if it was there.
TommyV is offline
post #27 of 744 Old 04-27-2007, 03:28 PM
TommyV's Avatar
bigmac are you updating from 2.0 or 2.1?
TommyV is offline
post #28 of 744 Old 04-27-2007, 03:36 PM
richmond5's Avatar
Quoted: 21 Post(s)
I just started my for 5 min. Keep my finger cross and have the 2.0 handy!
richmond5 is offline
post #29 of 744 Old 04-27-2007, 03:50 PM
bigmac11's Avatar
2.1 I have a HUGE collection of video from Iraq that I want to show my family. So far I've been unable to play any of them thru my Toshiba, yet they play fine on my pc? NIN has made it farther than usual
bigmac11 is offline
post #30 of 744 Old 04-27-2007, 04:06 PM
TommyV's Avatar
Wow so you were even having issues with NIN even with 2.1? 2.1 completely cured mine. I watched it all the way through and man what a disc! That is what HD DVD is all about!
I'm assuming the burnt discs you are talking about are SD DVD? If they play only on your PC they may be in a different format. Have you tried them on any other DVD players?
TommyV is offline
Reply HD DVD Players
