HD DVD gets 1080p 24fps output thread. - Page 42 - AVS Forum | Home Theater Discussions And Reviews
post #1231 of 1258 Old 11-28-2007, 05:30 PM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
Originally Posted by Ian_Currie View Post
Yup. I use an RS1 projector and an Anthem D2 sits inbetween. Both units confirm 24fps.
Does size matter? Cuz i notice it on HD-A30/HC5000/Carada 110". And i first had to eliminate the RX-V2700 for both it and PS3 to send the proper signal.
Go figure, fineckier than an air cooled Zaporozhets (the Onkyo of Russian
car manufacturing, their only car with a fire extinguisher, cuz if you drove it above 60kmh it caught fire). Sorry, Onkyo and Russian car fans.
bobpaule is offline
post #1232 of 1258 Old 11-28-2007, 07:02 PM
turbe's Avatar
Liked: 95
Originally Posted by lovingdvd View Post
Perhaps this has to do with the fact that the XA2 does ZERO (I think?) video processing with 1080p24 and just takes the data off the disc and sends it verbatim.
It depends if you are changing any Picture Adjustments from the Defaults. When playing a disc at 1080p24, enable EE (either 1 or 2) and see what happens.
We are having this discussion in the Onkyo HD805 thread.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #1233 of 1258 Old 11-29-2007, 09:00 AM
rockerz's Avatar
I have read that in the 1080P 24 mode, the XA2 bypasses the Reon chip. Does it do this with SD discs as well?
rockerz is offline
post #1234 of 1258 Old 11-29-2007, 09:10 AM
turbe's Avatar
Liked: 95
It uses the Reon, but either the EMMA3 is doing the picture adjustments (except for the exclusive Reon NR's), the Reon has a Pass-Through mode or the EMMA3 passes 1080p24 directly to the HDMI Port (unless any PQ Settings are changed from their Defaults).
As I noted in the Onkyo thread, the Block Diagram in the XA2's Service Manual clearly shows two paths, one bypasses the Reon. We're not sure what specifically happens internally when the non NR PQ Settings are used (i.e. EE, which does effect the PQ in 1080p24).
-Shawn
ControlCAL™
turbe is offline
post #1235 of 1258 Old 11-29-2007, 11:20 AM
DavidHir's Avatar
Quoted: 1726 Post(s)
Liked: 1336
turbe,
Do we know if the A30/A35 is designed like the XA2 in this regard?
DavidHir is online now
post #1236 of 1258 Old 11-30-2007, 01:52 PM
turbe's Avatar
Liked: 95
I'll search for the Service Manuals, I've never looked at them for those two though I had both before my XA2.
If you have a link to the SM(s), let me know.
I assumed the A20, A30, A35 and XA2 outputted the RAW stream when set to 1080p24. Now, I don't think we're sure what is going on in Firmware (XA2) since some Picture Adjustments can effect the 1080p24 output (processed).
ControlCAL™
turbe is offline
post #1237 of 1258 Old 12-03-2007, 05:51 PM
DavidHir's Avatar
Liked: 1336
post #1238 of 1258 Old 12-04-2007, 05:29 AM
Sunset1982's Avatar
Quoted: 48 Post(s)
Any new firmware news?
I'm waiting for a firmware >2.7, because 2.7 broke my HDMI handshake with my Toshiba LCD... (every version <2.7 worked without problems)
Sunset1982 is offline
post #1239 of 1258 Old 12-06-2007, 09:13 AM
evanhunter's Avatar
I set my A30 to 1080/24 when I hit display I get it saying 1080p should it say 1080p 24 somewhere? Does this mean I am not getting the 1080p/24?
evanhunter is online now
post #1240 of 1258 Old 12-10-2007, 12:44 PM
kami's Avatar
I didn't think I'd really see a difference but I do. Pans and movement in general is so smooth now. I was never even sensitive to judder but the difference is still night and day for me. I am using a HD-A35 and a Sanyo PLV-Z2000 1080p projector. I am not sure what multiple of 24 the refresh rate is but it looks great. On the information tab in the menu it shows a 1080p 24hz signal.
kami is offline
post #1241 of 1258 Old 12-13-2007, 11:20 AM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
The only way is to get into the "Information" menu of your display, if it has such a tab. There you will see things like bulb life, vertical (this would be 23.98 for film or 30Hz for video off teh Dish or DireTV tuners) and horizontal rez, etc.
bobpaule is offline
post #1242 of 1258 Old 12-13-2007, 01:06 PM
htc@htc.be's Avatar
I am not able to get 1080p/24fps working on the Toshiba HD-XE1 with Firmware 2.7.
I did buy the XE1 a couple of dats ago and I did the 2.501and 2.51 (Australian) upgrades first. I did not do any tests but went straight to 2.7.
The picture is terrible (lines all over the place and scrolling and much more. One can barely see what is shown. Even the menu is difficult to read). The projector (JVC HD1) plays it at 1080p 59.94HZ. Connection is HDMI.
First I thought it was the projector, but after connecting the XE1 to a 1080p/24 capable PIONEER 50" plasma I got the same bad picture. Definitely something wrong with the frequency.
Has anybody experienced something similar? I used different HDMI cables, long and short.
If somebody knows how I can make a clean install of 2.7 than I could give that a try.
The picture is OK at 1080p (without the 24).
Both the JVC-HD1 and Pioneer play PS3 Bluray 1080/23.976 beautifully which confirms that they are 1080/24 capable.
htc@htc.be is offline
post #1243 of 1258 Old 12-13-2007, 03:16 PM
MauneyM's Avatar
Quoted: 78 Post(s)
Liked: 38
What disc did you try this with?
MauneyM is offline
post #1244 of 1258 Old 12-13-2007, 03:48 PM
htc@htc.be's Avatar
King Kong.
I will try some others.
The problem is also with the menu.
post #1245 of 1258 Old 12-13-2007, 03:58 PM
htc@htc.be's Avatar
I tried with MI3. Same problem.
As I said it alredy happens when I go in the SETUP menu of the XE1. As soon as I choose the 1080p/24 option, the pictures goes blurry etc.
What is strange is that it is more blurry when I pass the HDMI through the DENON 4308 which does the switching.
I have a better picture but still not watcheable when I go directly to the projector. ???
post #1246 of 1258 Old 12-13-2007, 06:12 PM
turbe's Avatar
Liked: 95
Hey turbe, any updates?
I searched for the A30 and A35 Service Manuals and could not locate them. Hopefully, someone will make one available.
ControlCAL™
turbe is offline
post #1247 of 1258 Old 12-17-2007, 11:49 AM
Mod & Bluray Reviewer
Moderator
Lee Weber's Avatar
Quoted: 127 Post(s)
Liked: 367
OK SO this was a hard thread to skim....
DOES the HD DVD add ON do 1080p/24 or no?
I have one, and set my 360 via hdmi to 1080p and it says 1080p/60.
I am assuming no. If i am wrong how do i get it to be 1080p/24.
Also I have a new reveiver that does dolby trueHD and dtsHD, can i make it work with the 360/add on?
Thanks guys.
Lee Weber is offline
post #1248 of 1258 Old 12-17-2007, 02:27 PM
petmic10's Avatar
Thanks guys.
No, the add on cannot output 1080p/24.
No, the add on cannot bitstream high bitrate audio either, but it will
convert it to DTS(1.5 mbs).
Display: Pioneer PRO-151 60" Elite
Blu-ray player: OPPO BDP-93, Sony BDP-S1000ES
Processor: Onkyo PR-SC885
Amplifier: Emotiva IPS-1 150Wx7
Game Console: Xbox 360, Xbox One, PS4
Speakers: Mythos ST(Fronts), Mythos Ten(Center), Mythos One(Rears)
petmic10 is offline
post #1249 of 1258 Old 12-17-2007, 10:48 PM
ooms's Avatar
the A30 does 1080p 24hz, is this news to anyone?
ooms is offline
post #1250 of 1258 Old 12-20-2007, 04:54 PM
WebEffect's Avatar
Quoted: 98 Post(s)
Liked: 44
You have got to be kidding me. Can Toshiba do anything right? How can a CORRECTION that allows for 24fps only make things worse!
I didn't shell out a fortune for the XA2 over the A2 so that all the advantages behind it can be obsolete! I'm dependant on the player's Tint control, which I can't use in the TV, and the EE is priceless. Even if this issue is just speculation (there is no way I'm spending my time to research it!) I am sick and tired of the worry and the stress due to idiotic omissions made by a company that should know better!
WebEffect is offline
post #1251 of 1258 Old 12-20-2007, 05:12 PM
Gary J's Avatar
Quoted: 408 Post(s)
Liked: 215
Wanna sell it cheap?
Gary J is offline
post #1252 of 1258 Old 12-23-2007, 08:10 PM
dwb63's Avatar
just hooked up my new integra dhs 8.8 hd dvd the player outputs 1080p/24 it is being played on a mits 73734
dwb63 is offline
post #1253 of 1258 Old 12-25-2007, 09:24 AM
Moderator
Lee Weber's Avatar
Quoted: 127 Post(s)
Liked: 367
TY
post #1254 of 1258 Old 12-28-2007, 08:15 AM
Centurion's Avatar
Could you please share your thoughts on the DHS 8.8? I am considering the same player myself and would like to hear your feedback especially on the picture quality of SD DVD content. I'm sure HDDVDs look great. Also, have you tried bitstreaming the high def codecs like DTS-MA or DD TrueHD?
Centurion is offline
post #1255 of 1258 Old 01-05-2008, 09:46 AM
dalegg's Avatar
As far as ai know, only Pioneer and Sony will accept a 24 FPS signal. Are there other panels that support 24 FPS?
dalegg is offline
post #1256 of 1258 Old 01-05-2008, 12:42 PM
Omikron's Avatar
The Sharp 64U with 712 series can receive 1080p 24fps. Check out its thread.
Omikron is offline
post #1257 of 1258 Old 01-05-2008, 01:02 PM
MauneyM's Avatar
Quoted: 78 Post(s)
Liked: 38
JVCs projectors accept 1080p/24 and display at 96 Hz.
MauneyM is offline
post #1258 of 1258 Old 01-05-2008, 01:03 PM
MauneyM's Avatar
Quoted: 78 Post(s)
Liked: 38
I think you're in the minority on this one. Most of the people who have posted about the 1080p/24 upgrade want it to be streamed directly from the disc with no processing of any sort.
MauneyM is offline
Reply HD DVD Players
