Official Toshiba HD DVD Firmware ISO Downloads Here! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 238 Old 05-19-2007, 06:31 PM - Thread Starter
MidnightWatcher's Avatar
Quoted: 37 Post(s)
Liked: 25
Updating Your Toshiba/Venturer/Onkyo HD DVD Player
Firmware. Why update it? Think of it as a driver update for computer hardware, or a new updated version of your favorite software program for Windows. It makes things work better and may even have new features added. With HD DVD players the latest updates often include playback fixes, improved functionality and new features for some of the latest HD DVD titles that include improved web-enabled extras, such as those found on Transformers, Blood Diamond or Evan Almighty, for example.
Updating the firmware on your new HD DVD player is a lot easier than you may think. You can update your player to the latest firmware by either 1) the ethernet port (connecting the player to the internet since there is an ethernet port on the back of all HD DVD players for this), or by 2) manually downloading the firmware ISO and burning it to a CD ROM. If you're a little wary of doing something like this yourself, ask a techie friend who is familiar with this sort of thing to give you a hand.
How To Find Out What Firmware Version You Already Have
Stop any movie that may be playing and press Setup on the remote. In the Setup menu go to General --> Maintenance --> Update. It will tell you in the first set of numbers what the version is, for example 1.2/T19M. The firmware version in this example would be 1.2.
To Update Via The Ethernet Port*
* For all Toshiba HD DVD models, the Venturer SHD7000 and the Onkyo DV-HD805
First, go into the internet section of the Setup menu (Ethernet --> DHCP) and do the following:
1) Turn DHCP to ON
2) Turn DNS to ON
3) Move cursor to highlight the Confirm button in Yellow and press OK
Exit out of the setup menu and remove any disc that may be in the HD DVD player. Turn off the power and then turn it back on. You should then be able to update to the latest firmware via the Setup menu (General --> Maintenance --> Update) and then following the on-screen instructions.
Once the firmware update download process has finished:
  1. A message will appear, and the firmware update will automatically start.
  2. When the firmware update is completed, the player will automatically turn itself off.
For the HD-XA2 player only, you may need to follow these additional instructions if updating from firmware 2.5 or older:
  1. Power up the player again.
  2. The player will display a message (MSSG) that another update will start.
  3. Read the message and press OK. The message will disappear, and the second firmware update will automatically start. Please be patient during this process. (During the update, "VERUP" may flash on the display of the player.)
  4. When the firmware update is completed, the player will automatically turn itself off.
  • DO NOT UNPLUG, TURN OFF, OR USE ANY OTHER FEATURE OF YOUR PLAYER DURING THE FIRMWARE UPDATE PROCESS. Doing so will cause the writing of the firmware update to the player to be halted and the player may no longer operate properly. If the player stops working, please contact Toshiba Customer Solutions at 800-319-6684 (US) or 800-268-3404 (Canada).
  • If no firmware update is available, the player will quickly exit the update process.
The good thing about connecting your player to the internet is that you'll also be able to take advantage of all the web-enabled extras on an increasing number of HD DVD titles.
To Update By Downloading The ISO Firmware
ISO Burning Software: Use a CD only to burn the ISO image and not a DVD. If you do not have any burning software there is a FREE version of DeepBurner that will burn ISO images (works on Windows 95/98/2000/NT/ME/XP/Vista x86/Vista x64 and is virtually compatible with ANY CD/DVD burner). Click here to download. Since the firmware filesize is relatively small, please be sure to burn at a slow speed as this can often ensure a solid, error-free burn. Also remember to select Burn ISO image and to not just create a data CD.
DeepBurner: Choose Burn ISO Image
DeepBurner: Change Write Speed to 4x before navigating to the downloaded .ISO. When ready click Burn ISO.
If your burning software has the option, choose "Disc At Once" instead of "Track At Once". If the firmware update is in a .ZIP file, extract it and burn the large .ISO file image to disc. If the burn seems to have completed successfully and you feel like checking the disc after burning the ISO image and are concerned that the PC is unable to read the disc, don't be alarmed. This is perfectly normal, just follow the instructions below to update the firmware.
You can download the firmware update from either the Canadian or American Toshiba websites.
Toshiba HD DVD Firmware ISO Downloads - Canadian Site
Toshiba HD DVD Firmware ISO Downloads - American Site
Current Version: Firmware 2.4 for the HD-XA1, HD-A1 and HD-D1
  • This firmware update improves network connectivity for supporting the download of web-enabled network content associated with certain HD DVD discs, improves certain video and audio processing capabilities, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba.
HD-A1/D1 -- 69.8 MB .ISO - Firmware update 2.4 Date: Nov 15, 2007
HD-XA1 ---- 69.8 MB .ISO - Firmware update 2.4 Date: Nov 15, 2007
Current Version: Firmware 2.8 for the HD-XA2, HD-A20, HD-A2, HD-A2W, and HD-D2
  • A20 and XA2 Updates: 1080p/24 forced option now implemented; Improved HBR Audio Support For DD+, TrueHD and DTS-HD for the XA2 (Set Digital Direct Audio Mode to ON and Digital Out HDMI to Auto); From 2.7: Lip sync issue reduced significantly; Reports of improved bass management using multi-channel analog out (Set digital SPDIF to PCM and all speakers to the same size)
  • Improves network connectivity supporting the download of web-enabled network content associated with certain HD DVD discs
  • Addresses certain disc playback and HDMI/DVI related issues identified by Toshiba
HD-A2/D2 -- 39.5 MB .ZIP - Firmware update 2.8 Date: Jan 22, 2008
HD-A20 ---- 39.5 MB .ZIP - Firmware update 2.8 Date: Jan 22, 2008
HD-XA2 ---- 39.5 MB .ZIP - Firmware update 2.8 Date: Jan 22, 2008
Current Version: Firmware 2.0 for the HD-A30, HD-A3, HD-D3, and HD-A35
HD-A3 ----- 38.7 MB .ISO - Firmware update 2.0 Date: Feb 12, 2008
HD-A30 ---- 38.7 MB .ISO - Firmware update 2.0 Date: Feb 12, 2008
HD-A35 ---- 38.7 MB .ISO - Firmware update 2.0 Date: Feb 12, 2008
Now That You've Downloaded And Burned The ISO Image To Disc ...
The following events may interrupt the firmware update process and cause the player to malfunction.
  • DO NOT unplug the power cord during the firmware update process
  • Avoid loss or interruption of power during the firmware update process
  • DO NOT press the power button on the unit during the firmware update process
  • Check the disc for dirt or scratches before beginning the firmware update process
1) Confirm that the player is connected to a television. Turn on the television and select the appropriate video input on the television to view the player. (I.e. Video 1, Video 2, HDMI etc…)
2) Turn the player on by pressing the “On / Standby” button” on the unit or with the remote control.
3) Open the player’s tray by momentarily pressing the “Open / Close” button on the front of the unit.
4) Place the firmware update disc on the tray and close the disc drawer. The player will indicate “Loading” as the firmware update disc is initially read.
5) The players front display will indicate “Ver Up” and the on-screen display will indicate “Do you want to update the version?”
6) If “Yes” is not already selected (Highlighted in yellow) select “Yes" by using the cursor left button on the remote control.
7) Press “OK” on the user remote.
8) If you receive a message “Error code : 2007c5c2” on the TV, this indicates you are using an incorrect firmware version. You should contact Toshiba Customer Solutions at 1-800-319-6684 to obtain the correct firmware version.
9) After approx 2 minutes the players front display will indicate the progress of the firmware update in steps. It will first indicate “STEP 1/5” then “STEP 2/5”, “STEP 3/5”, “STEP 4/5” and finally “STEP 5/5”.
10) The player will stay on “STEP 5/5” for an extended period of time.
11) The complete firmware update process will take approximately 30 minutes. DO NOT UNPLUG or POWER DOWN the Player during the update process or it may result in damage to the HD DVD Player. The disc tray will automatically open upon completion of the firmware update. The unit will shut off with the tray in the open position.
Note: HD-XA2 owners only: Please see the additional instructions at the top of this page beginning with the green text.
12)
Remove the update disc from the tray.
13) Turn the player on by pressing the “On / Standby” button on the front of the unit. The disc tray will automatically close.
14) The firmware update is now completed.
TIP: Re-initialize your player after the firmware update has completed (go back in the maintenance menu to do this). Settings will then be reset back to default so you may need to change a few things back to where you had them before. Think of re-initializing as a soft "reboot" where it gets things working the way they should. (And I know, it's not really a reboot. To do that hold the power button down for about 10 seconds and then power it back up).
Enjoy!!
MidnightWatcher is offline
post #2 of 238 Old 05-19-2007, 06:35 PM
Capek's Avatar
Nice. I've been waiting for this. Thanks for posting.
Capek is offline
post #3 of 238 Old 05-20-2007, 04:37 PM
wittangamo's Avatar
Giving a bump for all the A2 bargain hunters (like me,) who jumped on today's sale.
Thanks, MidnightWatcher.
wittangamo is offline
post #4 of 238 Old 05-20-2007, 06:01 PM
stlouisme's Avatar
the 1.5 work perfect.
stlouisme is offline
post #5 of 238 Old 05-20-2007, 08:40 PM
hd nOOb's Avatar
This link may help as well.
---------------- Toshiba Disk Creator --------------------
Windows Xp
http://askiris.toshiba.com/ToshibaSu...%200%208797788
Windows Vista
http://askiris.toshiba.com/ToshibaSu...%200%208797921
------------------ Additional Help ---------------------------
http://209.167.114.38/support//ceg/t...-tsb000026.htm
Blu ray is the best Blah, blah, blah.
hd nOOb is offline
post #6 of 238 Old 05-20-2007, 08:52 PM
Mach1_8's Avatar
Liked: 90
Anyone do a firmware update on the HD-D2 yet? I ask because I only see the A2 on the Tosh site and was wondering if I should use the same file for my D2. I know they are the same internally, but I'm of the camp "if it ain't broke, don't fix it!"
Dyin' ain't much of a living, boy...
Mach1_8 is offline
post #7 of 238 Old 05-20-2007, 08:54 PM
Scarpad's Avatar
Quoted: 67 Post(s)
Liked: 37
I Bought an A2 today, exactly where do you see what FW Version you have, I can't see any in any of the menus
Scarpad is online now
post #8 of 238 Old 05-20-2007, 08:58 PM
eghill1125's Avatar
I was wondering the same thing
Ed
PSN - eghill1125
eghill1125 is offline
post #9 of 238 Old 05-20-2007, 10:37 PM
HD-FANATIC's Avatar
Before I bought the A-2 today from BB, I actually searched the Toshiba site yesterday and found the Firmware update for the A-2. Downloaded the FW and burned it all in the time it took me to register as a member on this site.
All I have to say is info. technology right now..... fast and furious.
Love this site..thanks guys
HD-FANATIC is offline
post #10 of 238 Old 05-20-2007, 10:43 PM
HD-FANATIC's Avatar
Pick the FW scroll to the bottom of the page, save the image file to desktop and burn image to CD. One of the members posted the Toshiba CD burn software u can download and burn the image file, then.
FW-update for the A-2 is 36MB!!!! DId all of this on my "toshiba" laptop!!!!!!!
post #11 of 238 Old 05-20-2007, 11:34 PM
tteich's Avatar
I have the XE1/XA2. In order to see the FW version, I have to hit "Setup" on the remote, then select the "General"->"Maintenance" menu, further select the "Update" submenu. The box which comes up shows the firmware level currently installed. Don't worry, nothing will be updated before you confirm it in the yes/no-box. You can leave the box by hitting the "no"-button.
I guess it works the same for the A2.
Laserdiscs: ~350
HiVision LDs: 42
HD DVD count: 379 / still 20 on the wishlist
tteich is offline
post #12 of 238 Old 05-21-2007, 04:55 AM
marjen's Avatar
Quoted: 81 Post(s)
Liked: 50
This worked great. Now the Good Sheppard actually plays for me on my A2.
Mark-
marjen is offline
post #13 of 238 Old 05-22-2007, 07:30 AM
Desmo888's Avatar
Originally Posted by hd nOOb View Post
This link may help as well.]
Thanks for the link HDNoob!
Desmo888 is offline
post #14 of 238 Old 05-22-2007, 06:30 PM
wmarkw's Avatar
Quoted: 277 Post(s)
Liked: 113
I'm trying to install the Toshiba Disc Creator for Windows XP and I get through the unzipping process and proceed to instal the program and I get the error "it is not possible to install it in this pc"
Any thoughts? Thanks.
wmarkw is offline
post #15 of 238 Old 05-22-2007, 06:37 PM
jayray's Avatar
Liked: 25
Same here.
Jayray
Read the FAQs
jayray is offline
post #16 of 238 Old 05-22-2007, 07:08 PM
alexk256's Avatar
You don't really have to use the Toshiba's disk creator (especially if it doesn't work), any program which can burn .iso files should work... If you don't have any - you can use something like BurnAtOnce (do a Google search for it, I can't post links).
alexk256 is offline
post #17 of 238 Old 05-22-2007, 07:10 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 25
Maybe use NERO, or any other program that will burn .ISO images. That's all you need really.
post #18 of 238 Old 05-23-2007, 04:12 PM
Desmo888's Avatar
You must have a Toshiba computer!
Desmo888 is offline
post #19 of 238 Old 05-23-2007, 04:31 PM
wmarkw's Avatar
Quoted: 277 Post(s)
Liked: 113
Nah I don't. I used BurnatOnce and currently updating my player w/ 1.5
wmarkw is offline
post #20 of 238 Old 05-23-2007, 07:08 PM
The_Canuck_1989's Avatar
I am surprised they didn't do this earlier. I mean sure CD's cost pennies when you buy them in such bulk like I am sure they are doing, but now you don't have postage to deal with. You can get it out quicker as the information doesn't have to be pressed on to the CD's. I am wondering now if downloading it will be quicker via this compared to straight from their server to the player.
The_Canuck_1989 is offline
post #21 of 238 Old 05-23-2007, 09:37 PM
skriefal's Avatar
Quoted: 85 Post(s)
Liked: 70
Nah I don't.
I think he meant that the Toshiba Disc Creator software will only install on Toshiba-branded computers.
skriefal is offline
post #22 of 238 Old 05-24-2007, 02:00 PM
WaldorfSalad's Avatar
Originally Posted by MidnightWatcher View Post
Saw this posted on another forum, thought I'd share:
They also list other firmware downloads as well for a number of Toshiba DLP and Plasma HDTVs. Let's hope the images are posted as soon as new firmware is released.
Thanks. Its on the Toshiba Canada web site but is it OK to use on the US models, particularly the HD-D2 from Costco?
WaldorfSalad is offline
post #23 of 238 Old 05-24-2007, 02:23 PM
jcg
jcg's Avatar
Quoted: 22 Post(s)
Any guess on how long before the FW 1.6 iso file is available?
jcg
jcg is offline
post #24 of 238 Old 05-24-2007, 03:47 PM
vvista's Avatar
Yes. D2 and A2 are the same!
vvista is offline
post #25 of 238 Old 05-24-2007, 03:49 PM
dlconner's Avatar
Thanks for the link.
dlconner is offline
post #26 of 238 Old 05-24-2007, 09:15 PM
jcg
jcg's Avatar
Quoted: 22 Post(s)
Does Toshiba have a US iso downloads website?
jcg
jcg is offline
post #27 of 238 Old 06-02-2007, 03:31 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 25
jcg
Not that I'm aware of.
Btw, latest updates are now available.
post #28 of 238 Old 06-03-2007, 08:49 AM
MORPHIII's Avatar
Windows Xp
Windows Vista
Thank you thank you. I have been looking for this all over the place.
Hope it works better than nero.
MORPHIII is offline
post #29 of 238 Old 06-03-2007, 09:12 AM
MORPHIII's Avatar
Forget it, it didn't work again. I kept getting Error Code 2007c00F.
What the hell is going on?
MORPHIII is offline
post #30 of 238 Old 06-03-2007, 09:46 AM
wittangamo's Avatar
I had the same error. The player is having a hard time reading the CD.
Got past it by trying different burning software and burning at a slower speed. Nero 7 at 8x didn't work. ISO Recorder at 2x did. Go figure.
ISO Recorder
Reply HD DVD Players
