VERSION 2.0 FIRMWARE FOR THE A2, XA2, A20, A2W, and D2 (Fixes Chroma Bug!) With link - Page 23 - AVS Forum | Home Theater Discussions And Reviews
post #661 of 682 Old 07-29-2007, 11:27 PM
cappyxavs's Avatar
Originally Posted by Bobcel View Post
Congrats, glad it worked out
thanks, me too i made five coasters prior to your post
the upgrade seems to have improved my picture and audio a bit. i am happier with the machine as i was at ver 1.3
WIDESCREEN WAS MADE FOR FOOTBALL!!
Anxiously waiting for a next gen HD-Rom media format to replace the old spinning disc technology.
Go Dallas Cowboys!!
cappyxavs is offline
post #662 of 682 Old 07-30-2007, 08:03 AM
raymar99's Avatar
Can someone tell me how I check to see what firmware version the A2 currently has installed?
I purchased it two days ago and it might already have version 2.0 installed but, I can't seem to find where to display it.
RayM
raymar99 is offline
post #663 of 682 Old 07-30-2007, 08:25 AM
dirtydan's Avatar
RayM
In the menu, press Setup, then select Maintainance, this will show version and ask if you want to update firmware, page 58 in manual.
dirtydan is offline
post #664 of 682 Old 07-30-2007, 08:56 AM
raymar99's Avatar
Thanks Dirydan -
actually you have to select UPDATE, one of 3 choices within Maintenance to see the version. I was not sure what would happen if I selected UPDATE. Sometimes these things start updating without a Yes or No. No clue on page 58 or elsewhere in the manual.
Turns out I have version 1.2 and it has a protocol error trying to connect to the internet, can't find the server.
raymar99 is offline
post #665 of 682 Old 07-30-2007, 09:17 AM
dirtydan's Avatar
Thanks Dirydan -
Yep, you now need to burn the new fw and then have the cd in the A2 when you go to that update in the menu.
dirtydan is offline
post #666 of 682 Old 07-30-2007, 09:26 AM
WayneL's Avatar
Here is what I wrote in my manual, thanks to a previous poster
Settings: DHCP on, DNS on, Proxy off, NTP on. Menu: Confirm, shows "update", OK
Power off, power on. Follow update process
Make sure there is no disk in drive
WayneL is offline
post #667 of 682 Old 07-30-2007, 04:36 PM
HDTVFAN0001's Avatar
Guess what - Version 2.1 just came out today (7/30/07).
It's on the U.S. and Canada sites....
HDTVFAN0001 is offline
post #668 of 682 Old 07-30-2007, 04:43 PM
Itsdon's Avatar
Yup, this thread is about to wither away.....
"Life is a toy, play with it"
Itsdon is offline
post #669 of 682 Old 07-30-2007, 05:58 PM
allargon's Avatar
Quoted: 51 Post(s)
Liked: 44
It's not even on the update servers yet. I tried this morning. (I check every Monday morning out of habit.) I tried just now after reading this. My player says at version 2.0 that I've already been updated. I'm sure the update servers will be slammed tomorrow just like last time.
allargon is offline
post #670 of 682 Old 07-30-2007, 06:26 PM
GVLBob's Avatar
I just tried at 8:24 PM ET to update from version 2.0 and received the same "Firmware is already up to date" message (or whatever it said).
Perhaps that was just as well
GVLBob is offline
post #671 of 682 Old 07-30-2007, 08:55 PM
Scorp1us's Avatar
JULY 30: New BIOS update! (2.1/T22T) but does NOT fix it.
You can download it to the player directly if you plug the ethernet cable in.
Scorp1us is offline
post #672 of 682 Old 07-30-2007, 09:14 PM
gtgray's Avatar
Quoted: 206 Post(s)
Liked: 136
Originally Posted by zglass2 View Post
Got the 2.0 disc from Tosh and after reading about all the problems it introduces decided NOT to update my XA2 which came with 1.5, will wait until the next update.
Not impressed with Tosh QC.
I got news for you the XA2 is a far better player with 2.0 than it was with 1.5. Your money, your choice. I have 3 Tosh players A2, D2, and XA2. Each firmware update has been a very positive thing for me. 2.0 made the most difference. I have not done 2.1 yet but it is on ASAP list for all 3.
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #673 of 682 Old 07-31-2007, 12:33 AM
cappyxavs's Avatar
too funny... i finaly figured out how to burn and instal 2.0 sunday. Monday i get the update ver 2.0 from toshiba via snail mail and tuesday i'm burning and installing ver 2.1
Go Dallas Cowboys!!
post #674 of 682 Old 07-31-2007, 05:57 AM
That's strange because in another thread, at least a dozen people already did the update.
post #675 of 682 Old 08-08-2007, 02:52 PM
raymar99's Avatar
I just got online and updated my A2 from v1.2 to 2.1. Took about 20 minutes or so, 34 packets received and 5 steps to completion. Neat.
raymar99 is offline
post #676 of 682 Old 08-08-2007, 03:21 PM
jpeter1093's Avatar
Now you can update to 2.2
jpeter1093 is offline
post #677 of 682 Old 08-08-2007, 03:41 PM
oleus's Avatar
Quoted: 33 Post(s)
any chance this one will fix colorspace issues for people using hdmi-dvi?
oleus is offline
post #678 of 682 Old 08-09-2007, 04:01 PM
chucko8008's Avatar
i've had my player for about 3 weeks now...worked PERFECT with 2.0, until yesturday. it started pixelating/artifacting to the point where it would not even read a disc....it would just freeze up.
called them up today, and they told me to update to 2.1, and it updated to 2.2 hehe.
before the update today i turned it on and it seemed fine today except it pixelated a little bit...but yesturday it was totally unplayable. so far with 2.2 i see no pixlelation/artifacting at all.
the dvr on top was kinda hot...can anyone shed some light on wha tmight have been happening with my HD-A2?
thanks.
chucko8008 is offline
post #679 of 682 Old 08-09-2007, 09:04 PM
chucko8008's Avatar
ug, this is really making me angry.
i did the update to 2.2 and it was FINE for one episode of planet earth a few hours ago. just now i turned it back on and its pixelating again right now as i watch another episode.
another edit....
i am confused on whats going on. this episode was pixelating yesturday, and today, but i checked another episode and it was fine, so i went back to the pixelating episode now its working good.
yesturday after this happened, NO CD would work, the thing would totally freeze up.
any ideas?
thanks.
post #680 of 682 Old 08-10-2007, 12:25 AM
CraigCooper's Avatar
It sounds like an issue with the player itself. Just as a matter of interest does it happen with all disks or just one or two.
CraigCooper is offline
post #681 of 682 Old 08-10-2007, 07:10 AM
oleus's Avatar
Quoted: 33 Post(s)
so other than causing some people's players to pixelize, what does 2.2 add over 2.0??
oleus is offline
post #682 of 682 Old 08-10-2007, 03:01 PM
chucko8008's Avatar
ya know, this happened at a bad time. i had people over and i was showing off the new set up so i really didn't bother with testing.
it started causing problems with disc 3 episode 2 (planet earth) other episodes seemed fine. then, directly after that, i popped in a movie i've already watched three times problem free (children of men), but this time the menu pixelated and froze up completely. nothign would do anything, so i pulled the plug (yeah yeah, i know). but it booted up and allowed me to get my disc out...tried another HD disc and it wouldn't even load, it'd just get stuck.
the next day it worked perfect, until it was towards the end of disc 3 episode 2, so i changed episodes then went back to where i was and it worked.
i've got the DVR standing on blocks now, trying to keep the heat away from the dvd player.
i guess i'll have to retest. thanks for the response.
Reply HD DVD Players
