VERSION 2.0 FIRMWARE FOR THE A2, XA2, A20, A2W, and D2 (Fixes Chroma Bug!) With link - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 682 Old 06-25-2007, 09:53 PM
stevesns69's Avatar
Originally Posted by Jon Spackman View Post
I am pretty sure this does NOT contain 1080p24. I check every menu, tried all the different sync settings on my VP50 and I can only get 1080p60 out of it. I think 1080p24 will be another upgrade.
I timed my XA2 before and after and its a little quicker. It was:
Before (1.6) off no disc in player, press open --- 42.45 seconds to tray fully open.
After (2.0) off no disc in player, press open --- 38.25 seconds to tray fully open.
Not much, but a 4 second improvement is still an improvement.
Thanks John, that was my biggest question. I can't wait until 1080p/24 comes through.
stevesns69 is offline
post #92 of 682 Old 06-25-2007, 09:55 PM
ac388's Avatar
Quoted: 77 Post(s)
Liked: 26
Cleaning up the CUE is already a blessing for me.
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
post #93 of 682 Old 06-25-2007, 10:04 PM
LarryChanin's Avatar
Hi Jon,
Thanks for the report.
While Toshiba has been notoriously vague when it comes to describing the fixes that each firmware release addresses, nevertheless I have to believe that new features, especially this long awaited one, would be prominantly described in their release documentation.
Larry
LarryChanin is offline
post #94 of 682 Old 06-25-2007, 10:16 PM
crussell1492's Avatar
2.0 does NOT fix my A2->Sanyo Z2 HDMI->DVI problem...BUMMER
crussell1492 is offline
post #95 of 682 Old 06-25-2007, 10:43 PM
Jack Gilvey's Avatar
Quoted: 35 Post(s)
Liked: 34
Originally Posted by FilmMixer View Post
What do you think you are going to gain in doing the decoding in the receiver?
The reassurance of the nice lights, of course.
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
post #96 of 682 Old 06-25-2007, 11:03 PM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
"Just watching Nature's Colors using 2.0 and there is a big difference from 1.6. All the colors are more vivid and the contrast seems better."
That seems odd. Maybe updating f/w causes picture setting changes or resets.
Noah
noah katz is offline
post #97 of 682 Old 06-25-2007, 11:14 PM
joebird's Avatar
Sorry for the ignorance, but what's CUE stand for?
joebird is offline
post #98 of 682 Old 06-25-2007, 11:15 PM
livingproof73's Avatar
Ok....not to sound like a total idiot.....but what is the CUE issue??? What does CUE stand for???
livingproof73 is offline
post #99 of 682 Old 06-25-2007, 11:32 PM
a4164's Avatar
CUE (Chroma Upsampling Error)
http://www.hometheaterhifi.com/volum...ug-4-2001.html
HD DVD: 45
a4164 is offline
post #100 of 682 Old 06-26-2007, 12:11 AM
rover2002's Avatar
I am from HK too. I usually wait for the ISO n burn it to a CD. I feel safer doing it this way, since if we get screw in internet updating, we have to send the unit all the way back to U.S. for service.
I turned off DHCP/DNS and all went smoothly I feel your pain with imported units, my A1 bricked with 2.1 and that was the end of that ! I now have a HD-E1 HK version so alls good warranty wise.
rover2002 is offline
post #101 of 682 Old 06-26-2007, 12:25 AM
Gary Murrell's Avatar
Originally Posted by sspears View Post
Yes, CUE is fixed.
thanks Stacey, I am one happy HD-DVD dude now
I did notice a change in saturation levels after this update, lower in level, obviously due to the cue and correcting it I would think?, that would be normal I take it Stacey?
thanks a bunch
and oh yeah, just as Jon said, this does not contain any 1080p/24 or direct stuff, I don't know where that came from
-Gary
Gary Murrell is offline
post #102 of 682 Old 06-26-2007, 01:28 AM
ac388's Avatar
Quoted: 77 Post(s)
Liked: 26
I have the A2 version from U.S. since last X'mas n so far not a single problem. Do you think you may void the HK warranty by updating the firmware on your own ?
It happened to me when I did the upgrade on a local Denon 2910.
ac388 is offline
post #103 of 682 Old 06-26-2007, 02:17 AM
CraigCooper's Avatar
Need a little help guys. My XA2 arrived today and i'm trying to update the firmware. But i Keep getting the message ( cannot find out server ) Can someone please help me with this. Thanks in advance.
CraigCooper is offline
post #104 of 682 Old 06-26-2007, 02:29 AM
Robert D's Avatar
Enable DNS and DHCP then on the same screen click on "confirm" wait for the screen to update then click on "OK", exit the setup and turn the player off. Now power the player back on and try the update and it should work.
Robert D is offline
post #105 of 682 Old 06-26-2007, 03:36 AM
yes, the key is connecting the ethernet and then turning off the player before trying the update
-Gary
post #106 of 682 Old 06-26-2007, 03:47 AM
thehun's Avatar
Quoted: 637 Post(s)
Liked: 527
If you connect it first with power off, and then just power on and start the updating process would be the same thing. That's how I did the past 2 updates, and currently downloading for this update right now.
De sagittis Hungarorum libera nos, Domine!
The Hun
thehun is online now
post #107 of 682 Old 06-26-2007, 03:47 AM
No still a no go. I get the right IP address displayed and the SUB as well. But no DNS address though, it just say 0.0.0.0
I have to say though this player is mighty impressive.
post #108 of 682 Old 06-26-2007, 04:00 AM
ravenous's Avatar
Are you using a broadband router for isp connection ?
If so, just enter router base IP adress (often 192.168.0.1) as DNS, if the router handels DNS forewarding. Otherwise enter your isps DNS servers directly.
DHCP and DNS are both turned on and were confirmed on the XA2 ?
HD-EP35 & PS3 & (soon to be) Regionfree Oppo BD-93. 148 : 481
ravenous is offline
post #109 of 682 Old 06-26-2007, 04:12 AM
It's a Broadband Router. I turned on and cofirmed DHCP and DNS. Sorry to sound like a noob, but how do I find the ISPs DNS server address.
post #110 of 682 Old 06-26-2007, 04:45 AM
bergelson's Avatar
Hi,
Does anyone know if it fixed the de-interlacing bugs w/ the A20?
bergelson is offline
post #111 of 682 Old 06-26-2007, 05:19 AM
Bud-man's Avatar
Originally Posted by aloneindark View Post
Just updated with the new 2.0 firmware. It seems to have fixed the hiccup issue when playing audio CD.
Same audio dropouts here
Bud-man is offline
post #112 of 682 Old 06-26-2007, 05:39 AM
Got it sussed I call my ISP and got the proper DNS address and its all updated now. Thanks for all your help.
post #113 of 682 Old 06-26-2007, 05:47 AM
gooki's Avatar
Sesh Craig - you're flying ahead. It's to late for me to do the update tonight.
International HDDVD Screenshot Archive (Full 1080p Images): www.hdmovies.co.nz
gooki is offline
post #114 of 682 Old 06-26-2007, 05:50 AM
I'm loving it, the picture is so crisp maybe even better than my Panasonic. Just wow
post #115 of 682 Old 06-26-2007, 05:57 AM
MauneyM's Avatar
Quoted: 78 Post(s)
Liked: 38
On a PC connected to the link, open a console window (command prompt) and enter the command "ipconfig /all". This will give you the relevant information about each of your network connections.
MauneyM is offline
post #116 of 682 Old 06-26-2007, 06:09 AM
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 842
Did it fix the analog LFE issues?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #117 of 682 Old 06-26-2007, 06:26 AM
Adam_ME's Avatar
Quoted: 35 Post(s)
Improvements I noticed after the 2.0 update:
1) Initial load time is faster. Not by much, but every second counts.
2) Lipsynch issues are gone. Despite having my Onkyo 605 hooked up through HDMI and not analog, I was still experiencing some major lipsynching problems on certain titles. The worst was Coming To America, but it works perfectly now.
3) The remote works a little smoother. Rewinding and fast-forwarding is still too jerky compared to the A1, but I still noticed a little bit of improvement.
Adam_ME is offline
post #118 of 682 Old 06-26-2007, 06:36 AM
mlankton's Avatar
You were aware that there is another bug that makes bass management work properly, yes? I'm waiting to hear that either a) they fixed bass management altogether, or b) that they didn't fix the bug that allows bass management to work correctly.
mlankton is offline
post #119 of 682 Old 06-26-2007, 07:55 AM
Winky65's Avatar
That does not work for me. No idea why. I tried DNS and DHCP enabled and disabled, manually entered the addresses and cannot connect to server message keeps popping up. When I turn on DHCP and DNS should they read all zeros? I did click confirm and it did confirm and grey out, I power off, power on, go right to the update and get the error message. Hopefully an ISO will be available soon.
Winky65 is offline
post #120 of 682 Old 06-26-2007, 08:10 AM
MauneyM's Avatar
Quoted: 78 Post(s)
Liked: 38
There were no LFE issues - LFE has always worked properly.
There WAS an issue with Bass Management, which was largely corrected in v1.6.
What do you mean by 'another bug'? The only remaining quirks are:
1) You must select PCM for the SPDIF output.
2) If you try to use Bass Management for only the center/surrounds, there is a 1 dB reduction in the surround/center output levels.
Both of these are minor annoyances at worst - certainly not major bugs.
Why do people continue to say that BM doesn't work, when it has been clearly shown that it works perfectly well?
MauneyM is offline
Reply HD DVD Players
