1st gen A1/XA1 firmware 2.3 is out - Page 20 - AVS Forum | Home Theater Discussions And Reviews
post #571 of 598 Old 11-12-2007, 02:53 PM
yukon04's Avatar
Originally Posted by angelo913 View Post
Have you down-graded your firmware in the past? Toshiba Support DOES NOT recommend going to a earlier firmware as it "may" cause problems. So once I upgrade to "newer" firmware, I don't down-graded the firmware on my A1.
What I do when I upgrade the FW
- document any special settings like 5.1 audio setup
- upgrade firmware via Ethernet and wait to complete and power down
- power-up and do the "Initialize" to factory default the unit with the new FW
- reconfigure unit to any special settings that was documented
- test/watch DVDs or HD DVDs, done
...Angelo
After upgrading to 2.3 on my HD-A1, I tried the "Initialize" procedure. The HD-A1 locked up in SETUP and would not respond. I had to pull the plug from rear, connect to TV via Component then power up again, reset the input to HDMI and tried SETUP again. Locked up again.
I pulled power plug and waited then repowered. I reloaded the 2.3 firware upgrade CD and HD-A1 reloaded it even though it indicated firmware 2.3 was installed? Not sure why this happened? SETUP seems to clear okay now, but HD-A1 still skips during playback on DVD's which are not a perfect mirror finish. I thought I had read that HD DVD's were less susceptible to DVD defects than Blu-Ray? Picture PQ with "Disturbia" is great when its not hung up or stuttering.
yukon04 is offline
post #572 of 598 Old 11-13-2007, 09:52 AM
redjr's Avatar
Quoted: 66 Post(s)
Liked: 45
Originally Posted by Craigslue View Post
I'm curious if anybody received 2.3 without contacting Toshiba? I read people receiving a 2.3 update from Toshiba. I received 2.2 and all the previous updates but not 2.3. I would prefer to use the update disc that Toshiba usually automatically sends but I guess I may have to download myself over dial up!
I believe once you are on their FW upgrade disc list, you get sent a CD when a newer FW version is released. I've received 2.2 and 2.3 from Toshiba directly without contacting them. I never did upgrade to 2.2 due to some issues that had been reported here, but instead waited and went directly to 2.3 a few weeks ago. The latest release covers all previous releases too. Mailing in your warranty card puts you on the list automatically I believe.
redjr...
Pioneer Elite - A-20, DV-79AVi, BDP-HD1, SC-89, SC-05
redjr is offline
post #573 of 598 Old 11-13-2007, 12:24 PM
jeffbenson's Avatar
I contacted Toshiba again last night. They stated the back log is getting better. The new firmware should be coming out soon.
jeffbenson is offline
post #574 of 598 Old 11-13-2007, 12:28 PM
Megalith's Avatar
Quoted: 22 Post(s)
What is Toshiba doing for 2.4?
Megalith is offline
post #575 of 598 Old 11-13-2007, 08:17 PM
ResOGlas's Avatar
Thank goodness. Firmware 2.1 fixed a lot of my HD DVD playback issues (Not all, but things are much better than they were).
2.3 added SD DVD playback issues for me. I'd appreciate it if they'd fix whatever they messed up.
ResOGlas is offline
post #576 of 598 Old 11-13-2007, 08:31 PM
Rolls-Royce's Avatar
Quoted: 327 Post(s)
Liked: 501
Originally Posted by roger_richards View Post
Question (yes, I've searched first): If an A1 is hooked up to a 1080i TV with analog component connection, DVD (SD) are not upconverted to 1080i - Correct? That is my experience and I cannot get my A1 to upconvert DVD to 1080i (it will only play at 480p). All the reports of high quality DVD upconvert must be via HDMI connection - Correct?
That is correct, Roger.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #577 of 598 Old 11-14-2007, 04:41 AM
buddahead's Avatar
Been on 2.3 for a while now,Not one problem.I did have to install it twice.But all seems to be fine.
buddahead is offline
post #578 of 598 Old 11-14-2007, 10:22 AM
bobgpsr's Avatar
Not entirely. A few SD DVDs are not protected with CSS. They will upconvert on a A1's component video connection. Also doing a "backup", of a DVD you own , will give you a DVD that will upconvert on component video.
bobgpsr is offline
post #579 of 598 Old 11-14-2007, 10:28 AM
Quoted: 327 Post(s)
Liked: 501
Roger, Bob's right. I forgot about unprotected DVDs and backups. Sorry!
...Royce...
post #580 of 598 Old 11-14-2007, 05:12 PM
mrkrispy's Avatar
not sure, but G2 players got an upgrade and the G1 updates are usually a week or so after. Very interested to know what they might be tweaking/fixing...
mrkrispy is offline
post #581 of 598 Old 11-15-2007, 11:10 PM
mrkrispy's Avatar
well Toshiba is faster than usual, I just started downloading a new firmware update...
*edit* I have an XA1. After 5 minutes it went from 0pct to 5pct. It took about 30 minutes to download over my wireless bridge. I verified that is plays a disc, boot time was the same, and the version under setup is 2.4
It is midnight so that is all I get for now. Interested to see if we get reports of what the update is.
mrkrispy is offline
post #582 of 598 Old 11-15-2007, 11:11 PM
ResOGlas's Avatar
interesting... I'm on it!
ResOGlas is offline
post #583 of 598 Old 11-16-2007, 03:30 AM
golffnutt's Avatar
Quoted: 140 Post(s)
Liked: 31
Couldn't find 2.4 on Toshiba site, where did you find it? Any idea what it does to improve the A1, thank you for the info.
Golffnutt
Thank you. Golffnutt "GO DAWGS" !!!!!!!!!!!!!! Panasonic PT-AE 8000U Projector with 10' Screen // Samsung 65" 4K TV UN65KS9500F // Denon X6200W Receiver // Oppo 203 4K Player // Pioneer Elite BDP-51FD Blu-Ray Player (Great CD Player and Excellent Blu-Ray Player) // All PSB Speakers in my 9.2 speaker setup with 2ea. M&K 12" Subs // Panamax Surge Protection // 35' Bluerigger Cable (18gbps band width, 60 frame rate, and 4:4:4 capable) and 3 ea Monoprice 6' Premium Certified Cables
golffnutt is offline
post #584 of 598 Old 11-16-2007, 04:33 AM
Desmo888's Avatar
Up until last night, my XA1 was poorly operating with FW 2.0. Some of the problems included skipping, stuttering, ramdom power-off's, and intermittent lip-sync issues. To complicate matters, the player would not update via Ethernet or Disk, to later firmware versions.
After getting RMA authorization from Toshiba, I sent the player in and waited, and waited, and waited.
Got it back last night (thanks FedEx) and watched Transformers. Not a problem encountered!
I will play with the features to see what 2.3 has added. Since I have been at 2.0 since the initial release I anticipate a noticeable difference.
Desmo888 is offline
post #585 of 598 Old 11-16-2007, 06:13 AM
Super Moderator
markrubin's Avatar
Quoted: 1241 Post(s)
Liked: 2751
unstuck
2.4 firmware link:
http://www.avsforum.com/avs-vb/showthread.php?t=939816
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #586 of 598 Old 11-16-2007, 11:29 AM
golffnutt's Avatar
Quoted: 140 Post(s)
Liked: 31
Originally Posted by markrubin View Post
unstuck
2.4 firmware link:
markrubin thank you for the link but I can find no such link for 2.4 using your above link. Can anyone tell me where I can find the 2.4 FW link for the A1? Thank you for your help.
Golffnutt
post #587 of 598 Old 11-16-2007, 06:14 PM
golffnutt's Avatar
Quoted: 140 Post(s)
Liked: 31
Can ANYONE tell me where to find the A1 FW 2.4 update, I can not find it on Toshiba's website and markrubin's link does not show it either. I would really appreciate the help, thank you.
post #588 of 598 Old 11-16-2007, 08:28 PM
jdmac29's Avatar
I updated through my ethernet connection. I don't think the website has updated any info yet. Some say it will be a few days before you can download the iso file.
jdmac29 is offline
post #589 of 598 Old 11-17-2007, 05:36 AM
golffnutt's Avatar
Quoted: 140 Post(s)
Liked: 31
Thank you, will check back in a few days. Anyone know what this FW 2.4 improves or fixes?
post #590 of 598 Old 11-19-2007, 07:31 AM
Tom Thomas's Avatar
2.4 disk image for the A-1 is posted on Toshiba's site
http://www.tacp.toshiba.com/tacpasse...vdfirmware.asp
Tom Thomas is offline
post #591 of 598 Old 11-19-2007, 07:54 AM
Hello, World!
Mark_H's Avatar
Quoted: 297 Post(s)
Liked: 205
Anybody confirm success using 2.4 XA1 with Lumagen ProHDP and EDID handshaking to get YCbCr?
Ta,
Mark
My cinema: The Cave!
My kit: 15' 2.35:1 Screen Research CP2 4-way mask, JVC Z1, Lumagen Pro, Meridian 861/621/7x5500/2xSW5500
Mark_H is offline
post #592 of 598 Old 11-29-2007, 04:53 PM
chrislee's Avatar
Hi All,
Sorry for jumping in here, but I just upgraded my firmware to 2.4 for a XA-1. I'm having to use the HDMI out, HDMI to DVI terminated cable to a DVI input in a DVI input on the plasma (no hdmi input).
This is wierd, I HAD 1080i with HD-DVDs before the firmware upgrade to 2.4...kinda the opposite of what's eluded to below. Now the question, why am I only outputting 720p now for HD-DVDs???
If I need to, can I get back to 2.2 or 2.3 again? Any ideas why I'm now having this problem??
Thanks for any help here, I'm pretty confounded at this point
Chris
Originally Posted by HumanMedia View Post
Things I want fixed in Firmware 2.4 (for A1 and XA1):
*Keep the DVD video colour range, when using DVI (it currently switches to PC levels when using DVI regardless of player setting)
*Bring back 1080i for DVI connections (this disappeared for many DVI displays with Firmware 2.2 and 2.3)
*Fix any BTB WTW and black crush issues
*Fix the video flagging issue with 720P connections and all Universal titles since and including Children of Men
*Fix the bass managements issues when passing Bitstream, over a digital connection.
Thats all I want. I dont care if I miss out on any new interactivity/internet updates, just give the best audio/video quality that the hardware can provide.
chrislee is offline
post #593 of 598 Old 11-29-2007, 07:17 PM
hawkeye3.1's Avatar
Have you tried toggling through the resolution options? Might clear some flaky logic.
hawkeye3.1 is offline
post #594 of 598 Old 11-29-2007, 08:36 PM
chrislee's Avatar
Yes I have, it goes to 1080i while in play, but then the player jams when you hit play. Gotta powerdown the unit to get it going again. If I have it in 1080i to begin with, then hit play, the movie starts but has switched itself over to 720P. Very aggrivating and of course, Spiderman III just arrived today from Netflix and I'm jonesen to see it...but not with jaggies.
Any other ideas anyone..... PLEASE???
chrislee is offline
post #595 of 598 Old 11-29-2007, 09:21 PM
hawkeye3.1's Avatar
All you can do is clear persistent memory, reinitialize the player, turn it off, unplug it for at least 5 minutes, plug it back in and give it another shot, don't forget to reselect HDMI out because reinit sets it to component. I was told this by a Tosh CSR over the phone btw for my CD reading problem. If that does not fix it as a last resort try to reflash the fw with 2.4 or the version you updated from. Good luck.
post #596 of 598 Old 11-30-2007, 09:47 AM
chrislee's Avatar
Thank you very much Hawkeye for the suggestions, I just tried all that, to no avail. So how do I 'reflash' back to 2.2?
Thanks again....I sure hope I can watch Spiderman tonight!
Edit: Got desperate and called Toshiba, 1-800-319-6684 who said they're having problems with the site/firmware over last few days and it's probably corrupted file. Said to retry downloadnext wed, and they are sending me a hard disc....10dys delivery....aargh!!!
Guys beware!
chrislee is offline
post #597 of 598 Old 12-02-2007, 10:15 AM
yukon04's Avatar
I successfully downloaded 2.4 f/w from Toshiba website and burned a CD at 40X using freeware "BurnAtOnce". Worked first time after creating 10 coasters of Memorax CD-R CDs. Neither Nero, Roxio Sonic, Realplayer or Isoburn software worked.
Cleared persistent memory and reinitialized successfully. So far so good.
yukon04 is offline
post #598 of 598 Old 01-05-2008, 02:59 PM
jfjohnson's Avatar
D-Nice - did you ever solve the VUP Err 222 @ 50% problem? If so, how? I am having the same problem with my HD-A1. 2.2 was the last successful update. Toshiba support was no help.
jfjohnson is offline
Reply HD DVD Players
