An Alternative to DVD Scratch Removing Machines - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-10-2007, 07:51 AM - Thread Starter
49Merc's Avatar
Quoted: 150 Post(s)
Liked: 37
Materials: (available at most auto supply stores and Walmart)
  • One - 10 fl. oz. bottle of "Meguiar's PLASTX Clear Plastic Cleaner & Polish"
  • One - "Meguiar's Even Coat Applicator Pad" (or other brand)
  • Two - "Meguiar's Supreme Shine Microfiber"cloths (or other brand), preferably in two different colors
IMPORTANT NOTE #1: Before purchasing the PlastX read the entire back label for directions and precautions. Specifically verify that the Polish can be used on scratch CD's. Do not purchase the product if for use on CD's not listed.
STEP 1. Apply the polish following the manufactures directions. Again per Meguiar's directions, use color "A" microfiber cloth to remove the dried polish residue .
Your DVD's scratches may either disappear or be greatly minimized. Note that more than one application may be required.
STEP 2. Thoroughly wash the disk with window cleaner and cold running water. Thoroughly dry the washed disk with color "B" microfiber cloth.
IMPORTANT NOTE #2: Never use color "A" microfiber cloth to dry the washed disk. Never use color "B" microfiber cloth to remove the polish residue from the disk. Microfiber cloths may be washed per manufacturers instructions. Never interchange the cloths. Doing so could leave polish residue on your disk and possibly damage your HD-DVD player. The applicator pad is also washable.
This method is much less expensive that buying a scratch removing machine. It worked for me with a terribly scratched Netflix "Sleepy Hollow" HD-DVD" disk.
Good Luck
Sony HDTV KDL-46HX750, Denon AVR 1912, DirecTV HD DVR Genie HR44, DirecTV AM21 OTA Rcvr, Sony BDPS3500 Blu-Ray, Infinity Alpha Speakers 50's, 20's, 10's, 37c, Velodyne VRP-1000 Sub, Panamax M4300-PM, Harmony Ultimate One Remote, Monoprice AV Cables. (Currently running a 3.1 setup)
49Merc is offline
post #2 of 4 Old 07-10-2007, 08:01 AM
Bud-man's Avatar
Good one!!
I've had good result's with a cloth buffer on my drill press and i can buff the inside out in a straight line.
Bud-man is offline
post #3 of 4 Old 07-10-2007, 01:05 PM
nikonjava's Avatar
Good Luck
Thanks for the good information. BTW, I hope I get the discs that you return to Netflix.
No electrons were harmed during the creation, transmission or reading of this posting. However, many were excited and some may have enjoyed the experience.
nikonjava is offline
post #4 of 4 Old 07-10-2007, 01:58 PM
hawkeye3.1's Avatar
Blue Coral also has a similar product called Plexiglass/Plastic Cleaner/Preserver. One of the uses listed on the back is "restores optical clarity to CDs". Really does the trick for scuff marks and light scratches and seems to make the surface more resistant to fingerprints. If the plastic protecting the instrument panel in your car has dulled from cleaning it with a paper towel, this stuff will make it disappear.
Good tip about the two types of microfiber cloths also, I'll have to try those.
hawkeye3.1 is offline
Reply HD DVD Players
