Need help with my 5.1 analog audio from my XA1 and Onkyo Reciever - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-18-2007, 02:12 PM - Thread Starter
grif32's Avatar
Hey guys I am confused and was hoping someone could help me hook-up my 5.1 analog output from my XA1 correctly.
I have the Onkyo HT-r540
On the back of the XA1 I see
Front:
Surround:
Center:
ON the back of the receiver I see
Front:
Surround:
Center/Subwoofer
I have 3 sets of RCA red/white cables from mono price.
I hooked up the first set of rca cables to:
Front on the back of the XA1 and Front on the back of the reciever and I get sound from every speaker including the sub
Confussed I thought I need to hook up all 3 sets of cables
Also no matter what I click on on the reciever
Optical 1, Optical 2 Optical 3 , Coax I get sound out of everyone.
Please help me understand what is going on.
How do I hook this up correctly to take advantage of the 5.1 analog outputs
Thanks for any help
grif32 is offline
post #2 of 7 Old 08-18-2007, 03:43 PM
dklayn's Avatar
You're wanting to use analog inputs, not any of the digital inputs (optical, coax, etc).
It looks like you need to enable Multichannel input on your receiver. From the manual that I found online, it says:
"Press the [RECEIVER] REMOTE MODE button, followed by the [MULTI CH] button. The MULTI CH indicator appears on the display." It also looks like you need to be using the "DVD" input source.
dklayn is offline
post #3 of 7 Old 08-18-2007, 05:15 PM - Thread Starter
grif32's Avatar
I tried using the multichannel input but the problem is when people talk no matter how loud I turn the reciever up you can barely here them.
Thanks for the help
grif32 is offline
post #4 of 7 Old 08-18-2007, 05:22 PM
Splicer010's Avatar
Liked: 40
Sounds like you have the center channel connected to different input(s). Also you may have to go in the XA1 menu to switch audio output from digital to analog...
Splicer010 is offline
post #5 of 7 Old 08-18-2007, 05:36 PM - Thread Starter
grif32's Avatar
Didnt see anywhere to switch to analog in the menu on the xa1
grif32 is offline
post #6 of 7 Old 08-19-2007, 02:41 AM - Thread Starter
grif32's Avatar
anyone?
grif32 is offline
post #7 of 7 Old 08-19-2007, 04:27 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Make sure the "center" output from the A1 is connected to the "center" multichannel input of the receiver. Also, check the receiver's "center channel" setup and increase the volume.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
Reply HD DVD Players
