2nd Gen Tosh HD DVD Firmware 2.5 is up (1080p/24 for A20 and XA2)! - AVS Forum | Home Theater Discussions And Reviews
Old 09-12-2007, 01:49 PM - Thread Starter
kulims's Avatar
kulims is offline
Old 09-12-2007, 01:50 PM
DrCrawn's Avatar
that says 2.2
DrCrawn is offline
Old 09-12-2007, 01:51 PM
UHD Addict
aaronwt's Avatar
Quoted: 5192 Post(s)
Liked: 3099
Sweet! I'll try the 1080P24 output when I get home.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Old 09-12-2007, 01:52 PM
b.greenway's Avatar
Q1. What does this update do?
A1. This firmware update adds support for 1080p/24Hz output and for more on-screen language display options. In addition, this firmware update improves network connectivity for supporting the download of web- enabled network content associated with certain HD DVD discs, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba.
b.greenway is offline
Old 09-12-2007, 02:02 PM
efjay's Avatar
efjay is offline
Old 09-12-2007, 02:05 PM
sharkcohen's Avatar
This better correct the BTB/WTW and colorspace issues over HDMI.
sharkcohen is offline
Old 09-12-2007, 02:08 PM
SugarBowl's Avatar
So it says the A2 is an applicable model, but only mentions the 1080p models in the details. Should A2 users get this?
SugarBowl is offline
Old 09-12-2007, 02:12 PM
Mark Booth's Avatar
Quoted: 49 Post(s)
Liked: 61
Has anyone else been able to download the ISO? When I get to the appropriate page, select HD-XA2 and click "Download Firmware File" it simply takes me to a default Toshiba page (even though the URL listed shows it supposed to be downloading a ZIP file).
Mark
Mark Booth is offline
hd nOOb's Avatar
Allways follow the links in my SIG.
Edit: keep checking back.
Blu ray is the best Blah, blah, blah.
hd nOOb is offline
Old 09-12-2007, 02:13 PM
gosawx's Avatar
or?
gosawx is offline
Old 09-12-2007, 02:17 PM
Kris-Co's Avatar
Would sure like to see my issue resolved with Happy Feet Combo HD DVD locking up at the 28 minute mark nearly every time, that I've seen hundreds of others had as well.. Never had any playback issue on the 360 with that disc, yet the A2 locks up at that point all the time! My other 107 HD DVD's play flawlessly :P
Panasonic 50" VT25 3D = Beauty
Kris-Co is offline
Old 09-12-2007, 02:19 PM
zombi3's Avatar
Sorry if this is a dumb question, but will the added support for 1080p24 output have any effect (positive or negative) if it the display only supports 1080p60?
Go ahead, take a Chill Pill.
zombi3 is offline
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
I'm updating over the internet as we speak. After it's done, I'll test my A2 for BTB over HDMI->DVI and report back.
Chris
Theater 1: LG OLED55E6P 4K TV, Samsung UBD-K8500 UHD Blu-ray player, Oppo UDP-203, Dune HD Solo 4K
Theater 2: Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D (CFW), Dune Base 3.0 / Smart units, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is offline
Old 09-12-2007, 02:20 PM
TrevorS's Avatar
Well, although there appears to be a FW 2.5 ISO coming out for the A2 as well, it isn't available yet. Still, the XA2 and A20 DO now get the 24p update plus the ability to select between Studio-RGB and PC-RGB output.
TrevorS is offline
Old 09-12-2007, 02:21 PM
TrevorS's Avatar
How many guesses do you think you need ?
TrevorS is offline
Old 09-12-2007, 02:25 PM
zombi3's Avatar
Three.
zombi3 is offline
Old 09-12-2007, 02:30 PM
TrevorS's Avatar
Check this provided PDF to find out what the changes are for the XA2/A20: http://tacp.toshiba.com/tacpassets-i...NoteXA2A20.pdf
TrevorS is offline
Old 09-12-2007, 02:32 PM
DM2006RI's Avatar
I've tried connecting with both my XA2 and A20 and in both cases it says "software already updated" (I'm running 2.2). Must not be online yet?
DM2006RI is offline
yellowcanary73's Avatar
Quoted: 12 Post(s)
Liked: 31
Still not able to get to download
yellowcanary73 is offline
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
Does that mean the A2 won't have the RGB level setting? That stinks, if that's true...
I'll hopefully be able to answer my own question in about 10 minutes, when my player is done updating...
fatherom is offline
Old 09-12-2007, 02:34 PM
LordofDoubleD's Avatar
Quoted: 88 Post(s)
Liked: 158
It's not up yet:
The software has already been updated.
The update process will end.
Maybe later.
-DD
LordofDoubleD is offline
Quetzalcoatl's Avatar
Sounds like the first to get it will be the ones doing ISO burns.
The object of war is not to die for your country, but to make the other bastard die for theirs.
General George Patton
Quetzalcoatl is offline
Old 09-12-2007, 02:35 PM
akbled's Avatar
Hopefully it will be by the time I get home.
akbled is offline
Old 09-12-2007, 02:39 PM
MorganB's Avatar
Yep still not up, probably needs to replicate across their servers or something.
MorganB is offline
Old 09-12-2007, 02:41 PM
Quoted: 12 Post(s)
Liked: 31
Can't get the ISO BURN just sends you in circles
Old 09-12-2007, 02:42 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
Woops...I only just updated mine to 2.2 (I had 2.1 until today). I guess I don't have 2.5 either.
fatherom is offline
MidnightWatcher's Avatar
Quoted: 37 Post(s)
Liked: 25
This is the sort of update that makes me want to buy a standalone.
MidnightWatcher is offline
Old 09-12-2007, 02:45 PM
hd nOOb's Avatar
When does the bitstream passthrough come out?
And is it also for the A20?
hd nOOb is offline
Old 09-12-2007, 02:49 PM
rveras's Avatar
The HDMI on the A20 is not version 1.3, it is 1.2 so it won't be able to pass bitstream data for TrueHD and DTS-HD.
rveras is offline
Old 09-12-2007, 02:52 PM
markjmills's Avatar
Still not up for ethernet download.
"Playing strip poker with an exhibitionist somehow takes the challenge away."
When you're racing...it's life. Anything that happens before or after is just waiting.
markjmills is offline
