i can't decide. spend my money. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-27-2007, 01:12 PM - Thread Starter
ccotenj's Avatar
Liked: 101
ok, i've had 2 xa2's, both of which have gone back for the same reason (player shut down randomly when playing 1080p, tried many different things, nothing worked)...
also, i really didn't notice any difference when using it for upscaling/de-interlacing vs. my pio59avi putting out 1080i and the display de-interlacing (it's possible this is because i was really frustrated with the xa2 and biased )... so i'm really not inclined to spend the money on it anymore...
options...
1) buy either a2 or a20 at pretty good price. a20 for a few bucks more gives me 1080p24. advantages: cheaper. stable firmware (relatively speaking).
2) order a3 or a30 from robert. costs a bit more. advantages: newer. not that much more than the models they are replacing. disadvantage: no real knowledge of stability of machines.
spend away.
- chris
ccotenj is offline
post #2 of 7 Old 09-27-2007, 01:21 PM
kevivoe's Avatar
options...
spend away.
Give 1/4 of your money to charity and then buy and HD-A30. You don't need 1080p.
kevivoe is offline
post #3 of 7 Old 09-27-2007, 01:44 PM
dildatonr's Avatar
Quoted: 25 Post(s)
Yeah I love my Xa2 but for you I would say go for the A30.
The free title promo is much better post october first anyways.
dildatonr is offline
post #4 of 7 Old 09-27-2007, 01:45 PM - Thread Starter
ccotenj's Avatar
Liked: 101
i already give enough to charity...
if i "don't need 1080p", why not go with the a2 or a3 then?
fwiw, my display is a pio 150fd...
- chris
ccotenj is offline
post #5 of 7 Old 09-27-2007, 02:22 PM
kevivoe's Avatar
Because if you are like me, you'll regret not at least trying a 1080p output. I wouldn't recommend top XA2 or even 1.3a HD-A35 for you but at least have the A30 in case you change your mind later. A3 will keep you wondering ...
That's my logic. I used HD-A1 for 14 months and now expect HD-A35 next week. Have gone from 720p to 1080p front projector capable of 24fps so HD-A35 was needed. SD-DVD don't matter as much as HD DVD's do to me now.
k
kevivoe is offline
post #6 of 7 Old 09-27-2007, 02:46 PM - Thread Starter
ccotenj's Avatar
Liked: 101
k
lol... glad to see i'm not the only one who thinks in that manner...
fwiw, the 150fd does 24fps too... although i'm not really sure i care... either i'm impervious to judder, or i just don't recognize it (and if i don't recognize it, i don't want anyone to tell me what to look for )...
i'm not really concerned about sd dvd's, to be honest... like i said in my original post, i really didn't see any difference (when it worked) between the xa2 scaling/de-interlacing and the 59avi scaling/set de-interlacing...
- chris
ccotenj is offline
post #7 of 7 Old 09-29-2007, 10:17 AM - Thread Starter
ccotenj's Avatar
Liked: 101
fwiw, i picked up an a20 at best buy yesterday for $299... i'll play with it for a couple weeks and see where we stand...
- chris
ccotenj is offline
Reply HD DVD Players
