A35 and Dolby TrueHD PICS - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 637 Old 11-10-2007, 09:19 AM
liftsalot's Avatar
I have an Onkyo 705 and just purchased an A35 and cant get DolbytrueHD to light up. I have the player set to bitstream and I just don't get it and it is really pissin me off. What do I need to do? I have the latest firmware. I have gone over both manuals front to back. Help
liftsalot is offline
post #632 of 637 Old 11-10-2007, 09:37 AM - Thread Starter
joerod's Avatar
Quoted: 613 Post(s)
Liked: 492
Do you have the A35 set to Direct in the set up menu for audio?
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #633 of 637 Old 11-10-2007, 09:41 AM - Thread Starter
joerod's Avatar
Quoted: 613 Post(s)
Liked: 492
Also, depending on the title sometimes you have to select Dolby True in their audio menu on the disc...
joerod is offline
post #634 of 637 Old 11-10-2007, 03:52 PM
liftsalot's Avatar
I got it thanks. Found a thread prior to reading your reply which had a setup for the a35 and it worked. 300 sounds awesome........
post #635 of 637 Old 11-10-2007, 03:57 PM
bhawes's Avatar
I have the movie Contract When I tried to play the movie it gets stuck after 1 minute I return the movie once and am getting the same problem. Can some help out with the problem.
bhawes is offline
post #636 of 637 Old 02-04-2008, 04:41 PM
BlueRSX's Avatar
yeah...just return the player as they are junk!
BlueRSX is offline
post #637 of 637 Old 02-04-2008, 07:02 PM - Thread Starter
joerod's Avatar
Quoted: 613 Post(s)
Liked: 492
That last post was from November and you just answer it today?
joerod is offline
Reply HD DVD Players
