**Official Toshiba HD-A35 (ONLY) Thread** - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #4351 of 4902 Old 11-11-2008, 06:31 AM
johndn's Avatar
Not to play mod, but deal talk is strictly prohibited (and enforced). You may want to move your post to the deals thread. Otherwise this forum becomes a classifieds section.
johndn is offline
post #4352 of 4902 Old 11-29-2008, 09:28 PM
dogone's Avatar
Yes...and if someone were to want one they should just PM me
dogone is offline
post #4353 of 4902 Old 12-07-2008, 07:59 PM
slow ride's Avatar
Quoted: 27 Post(s)
I just now have gotten around to downloading the firmware updates. I didnt realize that there have been two( 3.0 & 4.0 ) I assume that I should skip the 3.0 and just add the 4.0.
anybody have a problem with that ? what should I expect with the new 4.0 firmware update. thanks
slow ride is offline
post #4354 of 4902 Old 12-08-2008, 07:46 AM
BasicBlak's Avatar
Indeed skip 3.0 and go directly to 4.0. You should experience increased stability and (finally) flawless 24fps playback of AVC/MPEG-4 HD DVDs.
Panasonic PT-AX200U
Da-Lite Model B 106" HCMW
Sony KDS-60A3000
VIP 3D Theater Plus Converter w/ MonsterVision Max 3D Eyewear
Onkyo TX-SR805 (v1.08 w/DSP & HDMI Updates)
Oppo BDP-103
Sony PS3 Slim (v4.50)
Toshiba HD-A35 (v4.0)
Polk Audio RTi8 / CSi5 / FXi3
Boston 595x Subwoofers
My DVD Collection
BasicBlak is offline
post #4355 of 4902 Old 12-08-2008, 09:12 AM
slow ride's Avatar
Quoted: 27 Post(s)
ok, thanks
post #4356 of 4902 Old 12-08-2008, 02:49 PM
Splicer010's Avatar
Liked: 40
When you install 4.0FW all previous update components are also installed...
Splicer010 is offline
post #4357 of 4902 Old 12-09-2008, 12:53 PM
Carey P's Avatar
Quoted: 14 Post(s)
All I can find is the old 2.0 Firmware when I select HD-A35 and click on Download File. Where is the 4.0 FW? Is there a secret link to this firmware?
UPDATE: Never mind. I found it. Thanks. http://www.tacp.toshiba.com/customer...p?model=hd-a35
Carey P is offline
post #4358 of 4902 Old 12-10-2008, 11:41 AM
LOOKHEAR's Avatar
Could someone please confirm for me that the 4.0 fw is, in fact, for both the XA2 and the A35, even though my copy says XA2 on the disc. Tks in advance.
SEEING IS BELIEVING
Phil
LOOKHEAR is offline
post #4359 of 4902 Old 12-10-2008, 12:25 PM
BasicBlak's Avatar
Each model has it's own version for any given firmware update. So no, you would not be able to use the XA2's 4.0 f/w on the A35 player (or vice-versa).
Panasonic PT-AX200U
Sony KDS-60A3000
Oppo BDP-103
My DVD Collection
post #4360 of 4902 Old 12-10-2008, 12:27 PM
Wryker's Avatar
Quoted: 136 Post(s)
Liked: 62
You are incorrect - taken straight from Toshiba's website:
Applicable Models: HD-A1, HD-XA1, HD-D1, HD-A35, HD-A2, HD-A2W, HD-A2C, HD-D2, HD-A20, HD-XA2, HD-A3, HD-D3, HD-A30.
http://www.tacp.toshiba.com/resource.asp?resourceid=71
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #4361 of 4902 Old 12-10-2008, 12:45 PM
Splicer010's Avatar
Liked: 40
YOU are the one that is incorrect...The OP has an original Toshiba update disc and these discs CLEARLY WARN AGAINST USING THAT FW IN ANY OTHER MACHINE THAN THE INTENDED MODEL...There is indeed a version 4.0 for all models but each version is model specific...
post #4362 of 4902 Old 12-10-2008, 12:57 PM
BasicBlak's Avatar
^Thank you, Splicer... Saved me the effort.
Panasonic PT-AX200U
Sony KDS-60A3000
Oppo BDP-103
My DVD Collection
post #4363 of 4902 Old 12-10-2008, 01:48 PM
lujan's Avatar
Quoted: 2767 Post(s)
Liked: 1284
Yes, this is correct. I found out the hard way. One time, I put in the A35 disk into the A30 or vice versa and it gave me some sort of error message so the code for each update must be set for the specific model.
lujan
236 Ultra HD
780 HD
18 HD DVD
4 SD
lujan is offline
post #4364 of 4902 Old 12-10-2008, 03:53 PM
LOOKHEAR's Avatar
Thanks all for the help and especially Splicer. Originally when I ordered the 4.0 disc (and a friend and member had burned a copy for me already), I asked Tosh for each models 4.0 disc and the rep (a lady) told me that the XA2 disc would also work in the A35. I said . . . "hmmm, are you sure". She assured me that was correct. Well, still not sitting right and since the disc itself says to not use with any other player except the XA2, I questioned it. I also called Tosh earlier today (right after my post here) to again check in the meantime and the rep (a guy) this time, said "NO". Otherwise, he said I'd be sending the player in for another one.
I drive myself nuts triple checking everything anyway and this is why. Thanks again everyone.
SEEING IS BELIEVING
Phil
LOOKHEAR is offline
post #4365 of 4902 Old 12-20-2008, 06:38 PM
HMenke's Avatar
Liked: 54
Why does the HD-A35 limit component output from DVDs to 480p, but will output 1080i/60 over component from an HD-DVD? Is this something in the authoring of DVDs?
HMenke is offline
post #4366 of 4902 Old 12-20-2008, 07:06 PM
Splicer010's Avatar
Liked: 40
Copy protection...
post #4367 of 4902 Old 12-20-2008, 10:27 PM
jedi.master.dre's Avatar
HDCP (High-bandwidth Digital Content Protection)!
jedi.master.dre is offline
post #4368 of 4902 Old 12-21-2008, 02:19 AM
HMenke's Avatar
Liked: 54
Sure, but what's weird is that the 480p content on standard-def DVD is being "protected" from being upscaled to 1080i/60, 1080p/30, or 1080p/24 over component... yet the 1080p/24 content on HD-DVD is allowed to pass out through component as 1080i/60. That doesn't make sense.
HMenke is offline
post #4369 of 4902 Old 12-30-2008, 12:52 PM
AvGrog's Avatar
I tried to download FW 4.0 but the Toshiba web site doesn't seem to be working right. I list 4.0 but I can not find anyway of getting the download version. I found the older versions but not the 4.0. Has anyone been able to download it. The links on here take me to a page that shows it but no where to click to get download.
AvGrog is offline
post #4370 of 4902 Old 12-30-2008, 12:57 PM
snowghost's Avatar
Quoted: 25 Post(s)
Try this link. http://www.avsforum.com/avs-vb/showt...A2%2FA20%2FXA2
"The best long distance runners eat raw meat, run naked and sleep in the snow."
snowghost is offline
post #4371 of 4902 Old 01-02-2009, 09:04 AM
DUCeditor's Avatar
I expect it was a compromise made with marketing in mind. IF HD discs used with older, non hdmi, monitors only could show the same definition as regular dvds many folks would not have bought into the system.
-don
DUCeditor is offline
post #4372 of 4902 Old 01-02-2009, 09:16 AM
Splicer010's Avatar
Liked: 40
-don
What it really was/is all about is the studio's don't want upconverted copies made andthen sold as HD...Pretty simple actually...
post #4373 of 4902 Old 01-03-2009, 03:13 AM
Super XP's Avatar
But stupid at the same time. Good for the studios and bad for people that buy the movie. I am sure there is a by-pass for this unnecessary inconvenience.
Super XP is offline
post #4374 of 4902 Old 01-03-2009, 05:10 AM
HMenke's Avatar
Liked: 54
It doesn't make sense to "protect" the 480i content on SD DVD from being upconverted and copied over component...when the same content on 1080p HD-DVD (or Blu-ray) could be copied from component in actual hi-def.
HMenke is offline
post #4375 of 4902 Old 01-03-2009, 10:15 AM
BasicBlak's Avatar
Be that as it may, these are the restrictions on which the content providers have decided. You're preaching to the choir, folks, so don't shoot the messengers....
Besides, it's my understanding that 1080p from component cannot be copied unless (1) DMR has somehow been hacked (most of us are not technically astute enough to do that), or (2) the 1080p source in question is not copy protected to begin with. And even if it could be copied, 1080p over component is not identical to 1080p over HDMI/DVI, the latter of which is 100% pure digital. It's the signal in pure digital form that studios are most concerned with.
Panasonic PT-AX200U
Sony KDS-60A3000
Oppo BDP-103
My DVD Collection
post #4376 of 4902 Old 01-07-2009, 01:59 PM
abeas's Avatar
Quoted: 18 Post(s)
If this has been asked, I apologize. Is it me, or does the "auto" setting under frame rate not work? I have the resolution setting set at up to 1080p/24, and my television (Sony KDL-46V4100) does do 24fps. When I select auto under frame rate, the TV still states 1080p. When I change frame rate to 1080/24p, my TV does display 1080/24p. Seems like the auto is not working. I have tried several movies like HArry Potter, Batman Begins, Friday Night Lights, they all show up 1080p under auto.
My PS3 is set to auto, and it shows blu-rays in1080/24p when appropriate.
abeas is offline
post #4377 of 4902 Old 01-07-2009, 02:26 PM
lateralis's Avatar
someone will correct me if this is wrong but I seem to remember reading that the "auto" frame rate was a feature being setup to be implemented in the future with discs that supported it but since discs aren't being authored anymore, we probably won't ever see it working. I just remember a similar issue that when you set "up to 1080p24" SD content looked jittery and I'd have to go turn it back to plain 1080p to get it to go away.
lateralis is offline
post #4378 of 4902 Old 01-07-2009, 02:34 PM
snowghost's Avatar
Quoted: 25 Post(s)
The Auto Frame Rate works, but only if you're set to 1080p/24hz. The player will change to 1080p/60i if the content is not 24fps. It won't go the other way unless the DVD has a flag to tell the player. I know of no HD DVDs released with such a flag, although there may be some out there.
Basically it was for "future use" that never came to be.
post #4379 of 4902 Old 01-07-2009, 04:20 PM
BasicBlak's Avatar
Actually, Lateralis has it correct. Indeed Auto doesn't work--not in the way Blu-ray has implimented it, at least. At present, when set to "Up to 1080p/24Hz", everything is played back at 1080p/60Hz when "Auto" refresh rate is selected REGARDLESS of whether or not the source is 24fps. As mentioned, however, it would have detected 24fps material in future specifically-flagged HD DVDs had the format survived.
Panasonic PT-AX200U
Sony KDS-60A3000
Oppo BDP-103
My DVD Collection
post #4380 of 4902 Old 01-07-2009, 05:42 PM
abeas's Avatar
Quoted: 18 Post(s)
Thanks everybody for the info.
abeas is offline
Reply HD DVD Players
