**Official Toshiba HD-A35 (ONLY) Thread** - Page 163 - AVS | Home Theater Discussions And Reviews
post #4861 of 4879 Old 09-21-2013, 12:40 PM
James T's Avatar
Location: Toronto Ontario Canada/ Port Charlotte Florida Port Charlotte Florida
Owning the same equipment here are some things to try.
1. Make sure the proper selection is made for the HD player on the screen of the Denon usually DVD or HDP
2. Un plug the Denon for 30 seconds this will re set it no settings will be lost
3. Make Certain that the ports on screen display are the same as the one you are using. You can change the designations in the denon as they are assignable
4. Check the settings/out put screen set up in the Toshiba 3500 should be set to HDMI you can alternate to PCM
5 Use HDMI cables you know that work or buy a new one they are now send information both ways.
6. Re connect the HDMI cables
7. Try different HD discs.
8. By pass the Denon and go direct to the tv as a trial and error experiment.
9 Make certain that the TV is set to receive the signal from the denon. If you have a blu ray set up disconnect it and replace it with the Toshiba HD player.
Both Toshiba Denon and Sony have free telephone help lines
James T is offline
post #4862 of 4879 Old 09-21-2013, 07:04 PM
Glock3540's Avatar
Quoted: 13 Post(s)
Thanks James T! Will try your suggestions.
"I'm Your Huckleberry..."
Glock3540 is offline
post #4863 of 4879 Old 09-22-2013, 07:30 AM
lujan's Avatar
Quoted: 67 Post(s)
Originally Posted by James T View Post
7. Try different Blu ray discs.
"Try different Blu ray discs."? This is an HD DVD player so why would you try blu-ray discs as they wouldn't work?
lujan
731 Blu-ray
19 HD DVD
7 DVD
lujan is offline
post #4864 of 4879 Old 09-22-2013, 01:46 PM
James T's Avatar
should be HD discs my error
James T is offline
post #4865 of 4879 Old 09-22-2013, 05:27 PM
AVfile's Avatar
Quoted: 67 Post(s)
Liked: 67
Can you summarize the problem in a shorter post? Might get more readers that way.
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
post #4866 of 4879 Old 10-07-2013, 11:30 AM
jruser's Avatar
Ok, my HD-A35 has been hooked up but unused for quite a while. I have recently had more time for movie watching and started dipping back into the HD-DVD collection.
My player seems to have a problem though. Most (or all) discs seem to freeze at what I assume is the layer break. This happened on Knocked Up, The 40 Year Old Virgin, and Goodfellas. Fast forwarding a minute or two past the point of the freeze fixes the problem. On all movies, it was right around half-way or a little past half-way through the movie. I don't suppose anybody has any ideas or experience with this? For the freeze on Goodfellas, I actually had to unplug the power from the player and restart the player. I may just toss the player if nobody has any good ideas.
I pulled my old HD-A2 out of storage, hooked it up, and updated the firmware. I skipped to the problematic chapter on Goodfellas and there was no freeze. I also tried the disc in my computer using the GGC-H20L drive and it worked fine as well on the problematic chapter. I would rather use the HD-A35 than the HD-A2 or the HTPC, but I would rather not miss a minute out of the middle of each movie to fix the freeze.
jruser is offline
post #4867 of 4879 Old 10-07-2013, 10:45 PM
AVfile's Avatar
Quoted: 67 Post(s)
Liked: 67
- AVStefan
AVfile is offline
post #4868 of 4879 Old 10-21-2013, 12:10 AM
Mr. Kennedy's Avatar
Does anyone have a copy of the A35 firmware version 1.3 or know where I could get it? The Toshiba firmware links through the forums are no longer active and the Toshiba support site only has firmware version 4.0 available.
Mr. Kennedy is offline
post #4869 of 4879 Old 10-21-2013, 04:03 AM
Quoted: 261 Post(s)
Liked: 231
If you haven't already tossed your HD-A35, try this.
When I had my A-1 permanently plugged into the power outlet, I had freezes on several disk.
Unplugged it, put it into the closet for a couple of years.
Plugged it back in and it played a disk just fine with no freezes.
Left it plugged in and a few days later, tried to play a disk and it did the whole freezing thing again.
Wound up tossing it but got thinking about it later. I'd bet that leaving it connected to power caused some kind of heat failure.
If you can, unplug it for a few hours and then plug it in and play a disk immediately. If that works, then your solution is to unplug it when you're not using it.
Samsung 64F8500, Panasonic 65VT50, Oppo 95, Tivo Roamio for OTA, Dish VIP722, Marantz AV8801 preamp, Rotel Amps, Atlantic Tech 8200 speakers, Seaton Submersive HP, Calman 5, Chromapure, Accupel DVG-5000, VideoForge HDMI II, i1Display3pro, i1pro2, eecolor colorbox.
JimP is offline
post #4870 of 4879 Old 10-21-2013, 06:35 AM
lujan's Avatar
Quoted: 67 Post(s)
I can check and see because I used to keep all the versions?
lujan
731 Blu-ray
19 HD DVD
7 DVD
lujan is offline
post #4871 of 4879 Old 10-21-2013, 01:22 PM
Thanks, if you could check I would really appreciate it.
post #4872 of 4879 Old 10-21-2013, 05:22 PM
lujan's Avatar
Quoted: 67 Post(s)
I tried to send it to you as a PM with an attachment and kept getting this error:
"AJAX response unable to be parsed as a valid JSON object."
lujan
731 Blu-ray
19 HD DVD
7 DVD
lujan is offline
post #4873 of 4879 Old 12-26-2013, 07:26 PM
bimmerfreak0's Avatar
I think my unit just died. No red light when plugged in. No response to power button. .. Nothing..... It's just dead. Any suggestions?
bimmerfreak0 is offline
post #4874 of 4879 Old 12-27-2013, 11:46 AM
Al Sherwood's Avatar
Quoted: 335 Post(s)
Liked: 126
I don't recall, is there a fuse internal to these machines?
Al
Al Sherwood is offline
post #4875 of 4879 Old 01-03-2014, 03:38 PM
tmuller's Avatar
If someone needs the HD-A35 firmware's, I keep an archive of them in ISO format. I have 1.1, 1.3, 2.0 and 4.0.
Send me a PM.
tmuller is offline
post #4876 of 4879 Old 01-13-2014, 12:29 AM
ChrisW6ATV's Avatar
If you are not a technical person, the most feasible thing to do, if you want to be able to play HD DVDs again, is to find another player for sale. Also, offer yours for sale as is; it may have value to someone who can mix and match parts from more than one player to make a good one.
The technical ideas include checking inside the machine for a blown fuse and otherwise testing its power supply.
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
post #4877 of 4879 Old 01-27-2014, 08:07 PM
I checked the fuse. Works. No blown caps. Looks flawless inside. I hate electronics.
post #4878 of 4879 Old 01-21-2015, 11:26 AM
stemfi's Avatar
Error Code 10004050
I having been using my A35 off and on. Recently my player won't turn off and after 20-30 seconds the display shows the number 10004050 and freezes. I need to uplug it to get it working again. I have the original Firmware. I have called Toshiba and some of the service centers but no luck. I notice that when I go into the Setup Menu and try to update anything, include resetting, when I press the Setup button again it comes out of the setup menu but will freeze and I get the same error code. I have tried updating the firmware to 4.0 but it won't update. Looking through this thread and others this code has come up before, but there was no solution. Any help would be appreciated.
stemfi is offline
post #4879 of 4879 Old Today, 08:05 PM
bguzman's Avatar
Quoted: 13 Post(s)
Liked: 27
Unfortunately the only advice I can give you is the same as the previous post, it should be pretty inexpensive too.
bguzman is online now
Reply HD DVD Players
