Disc Error code: 408bc504 Poll - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Do you or don't you get the disc error code: 408bc504
I get the error with the player at 720P 19 8.84%
I get the error with the player at 1080i 81 37.67%
I do NOT get the error with the player at 720P 18 8.37%
I do NOT get the error with the player at 1080i 97 45.12%
Voters: 215. You may not vote on this poll
post #1 of 77 Old 11-11-2007, 10:08 PM - Thread Starter
AV99GT's Avatar
I thought that this might be a good Poll to have. Maybe it will help in figuring out the problem.
Post which player you have / firmware. I have the A3 with 1.0.
AV99GT is offline
post #2 of 77 Old 11-12-2007, 10:41 AM
Grasschopper's Avatar
Whay about those of us with the A30 and 1080p?
So are people finding that they do not get the same error at the same points in discs when using other resolutions?
Oh and to report my errors:
Player HD-A30 with Firmware v1.1 playing at 1080p/24
Hot Fuzz - plays perfect
Transformers - lock up at 1:15 mark both times I tried to watch through this point in the movie disc is brand new and clean
Knocked Up - lock up on boot...wouldn't even load the first time and I had to unplug the player to get it to function. Other sketchy picture issues but no other lock up. Disc brand new and clean.
HD-DVD - 15
BluRay - 30
There was a format war...Best Buy won, I lost.
Grasschopper is offline
post #3 of 77 Old 11-12-2007, 10:43 AM
rdclark's Avatar
Quoted: 285 Post(s)
Liked: 544
I have gotten the error once on my A2, on a badly-scratched rented copy of Planet Earth, Disc 1, playing at 1080i.
Wide Awake
on the Edge
of the World
rdclark is offline
post #4 of 77 Old 11-12-2007, 10:45 AM
G-star's Avatar
Quoted: 18 Post(s)
error code observed at 1080i with the A2/firmware 2.5, HDMI to 768p plasma
"That's right Mr. Martini...there is an Easter Bunny".
G-star is offline
post #5 of 77 Old 11-12-2007, 11:31 AM
fuzzatch's Avatar
I have not seen this error.
I have an HD-A3 with 1.1 firmware and am connecting to my display via component. I have the player set at 1080i for HD and 480p for SD. Have watched 300, Bourne Identity, Transformers, and We Are Marshall in HD and a few Backyardigan's movies in SD (for my daughter).
Had an audio sync issue with We Are Marshall, but returned it for a new copy and it works fine, it is a combo disk also.
fuzzatch is offline
post #6 of 77 Old 11-12-2007, 11:54 AM
Hmm I wonder if this is a HDMI vs component issue...
HD-DVD - 15
BluRay - 30
post #7 of 77 Old 11-12-2007, 11:57 AM
khwiggins2's Avatar
I do not get that error.
Tosh HD-A35 w/ 1.1/1.1 firmware -> HDMI -> Denon AVR-3808ci w/ latest firmware -> HDMI -> Tosh 72HM195 1080p set, but only accepts 1080i input.
Previously had HD-A1, since getting the new player, have played Transformers, Batman Begins, Serenity, Soprano's, MI:3, Matrix, Terminator 2 (import), Two Jakes (SD), Numbers (SD) and more that I can't think of off the top of my head.
"We've done the impossible, and that makes us mighty!" - Captain Malcolm Reynolds
khwiggins2 is offline
post #8 of 77 Old 11-12-2007, 12:01 PM
devotiondoubt's Avatar
Is there a reason you have not updated your firmware?
devotiondoubt is offline
post #9 of 77 Old 11-12-2007, 12:24 PM
SirJohnFalstaff's Avatar
I have received this error 4 times in 12 movies, but only 2 of those can be repeated. I have a Toshiba HD-A35 with 1.1/1.1 firmware, contected via HDMI to a Denon AVR-3808CI also with the latest firmware, connected via HDMI to a Panasonic PT-AE900U projector. I'm running everything in 720p.
Good disks (all non-combo):
300
Bourne Identity
Pitch Black
The Chronicles of Riddick
Transformers
Troy: The Director's Cut
The Matrix Reloaded
Disks that displayed error (all non-combo):
Batman Begins (non-repeatable after cleaning)
Lady in the Water (non-repeatable after cleaning)
The Matrix (repeatable)
The Matrix Revolutions (repeatable)
Besides this error, I have never experianced any other problems with my A-35 such as lock-ups, audio drop-outs, etc...
"Not throwing my hands up or my dress above my ears don't mean I ain't awestruck." Al Swearengen
SirJohnFalstaff is offline
post #10 of 77 Old 11-12-2007, 12:53 PM
psblake's Avatar
hd-a2 2.5 firmware via component and have not had an error yet.
Love my DEF TECH!
psblake is offline
post #11 of 77 Old 11-12-2007, 01:25 PM
Neal LosAngeles's Avatar
Your poll doesn't ask about 1080p. I have the A30 with 1.1 firmware outputting on 1080p and I've had the player lock up with this error code for EVERY DVD we have tried--about 10 so far including 8 brand new out of the box and 2 standard def. So Toshiba is sending me a prepaid FedEx label to ship it to them for repair or replacement.
Neal LosAngeles is offline
post #12 of 77 Old 11-12-2007, 01:33 PM
hypoh's Avatar
Got the error once (I've only had it for under two weeks) with my HD-A2 / Firmware 2.5 / at 1080i output. It was with a used King Kong disc that was pretty roughed up in my opinion. Locked up around the one hour mark; took it out and washed it and was able to finish the movie.
hypoh is offline
post #13 of 77 Old 11-12-2007, 01:46 PM
HT Nut's Avatar
Brand new A3 errors on both 1.0 and 1.1 firmware playing a virgin copy of The Reaping. I took it out of the cabinet and went back to my XA-1 which has never given the error code.
Jerry the HT Nut
HT Nut is offline
post #14 of 77 Old 11-12-2007, 02:32 PM
coolhand's Avatar
Quoted: 66 Post(s)
Liked: 37
OF COURSE YOU ARE ALL HAVING PROBLEMS.
Version 1.0??? Version 1.1??? Seriously??? The current firmware is 2.5
Before you do ANYTHING ELSE go to
http://www.avsforum.com/avs-vb/showthread.php?t=876566
And update your firmware.
EDIT: All apologies for the tone. After doing a small amount of research it looks like this is a problem on the G3 models. Good luck to all. Hopefully they will fix this via firmware quickly.
coolhand is offline
post #15 of 77 Old 11-12-2007, 02:32 PM
pittkid333's Avatar
A3 with 1.1 - 1080i
Played fine = Transformers, Alpha Dog, Bourne Identity, Bourne Supremecy, Blades of Glory, The Break Up, V for Vendetta...
Locked up = License to Wed at two different point...15 min's in and 1:10 in...Exchanged the disc and the new one played fine
pittkid333 is offline
post #16 of 77 Old 11-12-2007, 02:33 PM
pittkid333's Avatar
1.1 is the current firmware for our A3's
post #17 of 77 Old 11-12-2007, 02:34 PM
khwiggins2's Avatar
They're referring to 1.1 for Gen 3 players. That's the latest. 2.5 is for Gen 2 players.
post #18 of 77 Old 11-12-2007, 03:00 PM
The Toshiba tech told me that 1.1 is the latest version for the A30.
post #19 of 77 Old 11-12-2007, 03:32 PM - Thread Starter
AV99GT's Avatar
Yes! I received the player on Friday night, and only had component cables. So Friday night I watched Bourne at 720p through the cables. I was not able to upgrade the firmware, and I have been reading the different posts where for some people the 1.1 upgrade didn't solve the problem. I though what the heck, worst thing is it lock-ups.
I received my HDMI cable from monoprice saturday afternoon. That is when I swapped over to the HDMI cable but still have it at 720p. I than watched all 4 movies including Bourne again. No problems at all.
I am turning the TV on first than the player.
I thought maybe it is a 1080i problem but looks like some people have it at 720p as well
AV99GT is offline
post #20 of 77 Old 11-12-2007, 03:58 PM
user0001's Avatar
A2
firmware 2.1
user0001 is offline
post #21 of 77 Old 11-12-2007, 03:58 PM
The firmware might not solve the problem but it could help some other item before it becomes an issue.
Why were you not able to update? Just curious.
post #22 of 77 Old 11-12-2007, 05:04 PM
fuzzatch's Avatar
Don't know, but I will be getting an HDMI->DVI cable soon, so if I get this error whith this setup I will post it here.
fuzzatch is offline
post #23 of 77 Old 11-12-2007, 05:59 PM
rblack20148's Avatar
HD-A2, 2.5, only happened with Letters from Iwo Jima.
Restarted the player and the error hasn't occurred since.
rblack20148 is offline
post #24 of 77 Old 11-12-2007, 06:23 PM
chris0's Avatar
A35, 1.1
When it was on 1.0 I got the 408bc504 error on 3 different brand new discs, one (Miami Vice) at the exact same spot every time. The others, Bourne Identity and Knocked Up, were hit and miss. Since 1.1 I have not had the error, but have some dropouts with bitstreaming DD+.
Pics from my TV here and here.
chris0 is offline
post #25 of 77 Old 11-12-2007, 09:13 PM
DocT's Avatar
A20 with 2.5fw at 1080p/24 via HDMI. The Matrix freezes up at chapter 20.
DocT is offline
post #26 of 77 Old 11-13-2007, 09:16 AM - Thread Starter
AV99GT's Avatar
Well I tried the 1080i setting, Bourne played with no problem at all. I also watched only a bit of Blood Diamond no issue, but I didn't watch it through.
Now I am really curious as to why this is happening, since I didn't update the firmware.
All my discs are brand new, and no marks at all.
I bought my player from BBFB which was upgraded to an A3, although I did have to wait. Maybe this shipment was a revised build, Too bad there is no manufacture date sticker on this machine.
I didn't updated the FW b/c I didn't have internet connection at the time, also I want to burn a disc just in case. But when it worked with no problems I am wondering if I should do it or not.
AV99GT is offline
post #27 of 77 Old 11-13-2007, 10:11 AM
Ok so I just got off the phone with Toshiba HD-DVD customer support. Here is what I was able to get out of them which took some work because they wanted me to be in front of my unit and I am currently at work (don't tell my boss ) :
First thing Sandy (nice lady) said to do was to unplug the unit for 2 min. Her explanation was that since these units are effectively compunters they need to be rebooted after an update. She claims this has helped a couple of customers she has delt with.
The second bit of info that I got from her was that they feel this is a disc issue. Apparently there is a VERY large number is complaints with Universal discs. She was also aware of complaints with the movie Transformers specificly. She was indicating that these are bad discs causing the issue.
The third tidbit I got from her was that I (we) should be powering on our displays before the HD DVD player. She wasn't sure why this was working (this is from customer feedback) but her thought on it was that because of all the communication that can and maybe does go on between equipment via HDMI that the player being on before the display is causing an issue. I would have written this off but there are people that report no issues and say they are hooked up via component cable (AV99GT above for instance). I may try unplugging my unit and hooking it up with component cables to see if that resolves the issue.
So maybe we need to have a different poll...who is getting the errors and not and then what method of hookup are you using?
HD-DVD - 15
BluRay - 30
post #28 of 77 Old 11-13-2007, 10:31 AM
Katiesdad's Avatar
Toshiba A3 at 1080i 1.0. I have an Olevia 720P LCD.
I watched Transformers and V for Vendetta with no problems. I started watching Goodfellas and had no problems. Then I tired watching it again the next day from where I left off and I got the error. I tried starting from different points and always got the error. Then I cleaned the disc using a soft cloth and it played fine to the end. I still have 300 and the Bourne Identity that I haven't watched yet and I should be receiving my first DH-DVD from Netflix soon. That should be the real test.
I updated the player to 1.1 yesterday, but haven't watched any movies on it yet.
Katiesdad is offline
post #29 of 77 Old 11-13-2007, 10:32 AM - Thread Starter
AV99GT's Avatar
[quote=Grasschopper;12203999]
QUOTE]
I only have been turning the TV on first than the player. I was hooked up to componet for just one movie, than I got my HDMI cbale and that is what I have been running.
AV99GT is offline
post #30 of 77 Old 11-13-2007, 10:41 AM
I have an LCD projector that I let warm-up for about 5 minutes before starting my AVR and HD-DVD player. I can't see this causing the errors I've been encountering.
Reply HD DVD Players
