** OFFICIAL - FIRMWARE VERSION 2.7 RELEASED!!!! for HD-XA2 (HD-XE1), HD-A20, HD-A2/D2 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 1264 Old 11-12-2007, 10:27 PM
et88b's Avatar
Originally Posted by mlkmgr View Post
thanks for the reply, but still no dice. i tried powering each (AVR, XA2, projector) on first, but no luck. the receiver shows 'stereo' in the display unless i switch to "cd" or other source and then back to "dvd". this is very frustrating!! anyone else experiencing difficulties?
I am sure you did this but I unplugged the power cord on the player and then reconnected to get everything to work.
et88b is offline
post #182 of 1264 Old 11-12-2007, 10:32 PM
airborn007's Avatar
Quoted: 133 Post(s)
Liked: 41
Just upgraded 2.7...We need forced 1080/24p, sometimes my XA2 still only displays 1080p from my tv display screen. I then would have to stop the movie and then restart, too bad there's no resume play.
LG OLED 55E6P & OPPO 203
Pioneer Elite PRO101FD & Panasonic UB900
Energy RC Mini 5.1, Denon, HSU Sub
Xbox One S & PS4 Pro
airborn007 is offline
post #183 of 1264 Old 11-12-2007, 10:37 PM
PRO-630HD's Avatar
Quoted: 220 Post(s)
Liked: 131
The last update was available within 2.5 hours of the release of the iso file via ethernet firmware update. I am sure tomorrow morning at the latest. Just tried again via ethernet port, no luck.
PRO-630HD is offline
post #184 of 1264 Old 11-12-2007, 10:37 PM
sharkcohen's Avatar
I'll be up for a while, I'll keep trying ethernet.
sharkcohen is offline
post #185 of 1264 Old 11-12-2007, 10:39 PM
Master843's Avatar
Has anyone checked to see if this resolves the Disk Error Code 408bc504 freezing/stopping problems that a lot of people were having? I haven't seen anyone mention it yet in this thread.
Master843 is offline
post #186 of 1264 Old 11-12-2007, 10:43 PM
sharkcohen's Avatar
I think people that get that error repeatedly should consider getting their player serviced by Toshiba.
post #187 of 1264 Old 11-12-2007, 10:43 PM
jim3860's Avatar
This may be slightly off topic here but are there any players avialable that output HBR formats including DTS MASTER through there analog outputs or is it strictly HDMI 1.3
REGARDS JIM
jim3860 is offline
post #188 of 1264 Old 11-12-2007, 10:46 PM
sharkcohen's Avatar
None of them can output decoded DTS-HD MA out the analogs because none of them can decode DTS-HD MA.
post #189 of 1264 Old 11-12-2007, 10:48 PM
stevesns69's Avatar
This is awesome!! I finished my update with no problems. I never burned an ISO before. That was pretty easy, just a waste of a disc though. I just didn't want to wait for the ethernet update, even though I checked all night. My Onkyo 905 is showing Dolby Digital Plus and TrueHD for the first time ever!! Now it's time to watch a movie. Thanks to the OP on the ISO tips!! Good luck everybody and enjoy!!
stevesns69 is offline
post #190 of 1264 Old 11-12-2007, 10:49 PM
mlkmgr's Avatar
i disconnected all power cords hoping this would solve my issue, but no luck. if i turn the "new" audio option off, sound resumes. i am still at a loss as to what could be wrong. this is a bummer!! i guess i will try toshiba tech support tomorrow sometime unless anyone else has an answer??? thanks again...
mlkmgr is offline
post #191 of 1264 Old 11-12-2007, 10:50 PM
jim3860's Avatar
Thanks I assumed the A35 could.
REGARDS JIM
jim3860 is offline
post #192 of 1264 Old 11-12-2007, 10:51 PM
ChrisW6ATV's Avatar
Jim-
All Toshiba players with 5.1 analog outputs have Dolby TrueHD HBR available through the analog jacks. No player yet has DTS-MA HBR available except the ones that can pass it compressed through their HDMI outputs (HD-A35 and now also HD-XA2).
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
post #193 of 1264 Old 11-12-2007, 10:51 PM
Frank D's Avatar
Quoted: 274 Post(s)
Liked: 77
All my XA2 previous upgrades where done via internet. This time I did it via the iso file. Everything went smoothly.
Funny thing though, at the end of the initial part of the update the tray opened up and my XA2 automatically turned off and then I took out the disk and then manually turned on the XA2 allowing it go to through the second step (tray closed within about 15 seconds automatically and proceded with second part of upgrade) and then the XA2 turned itself off automatically again. That was fine and exactly what I expected. Then I went to turn my XA2 on again manually and got a MSSG screen on the front display of the XA2. Was not sure what to do as my attached video screen (using small 480i screen via composite out from XA2 and had the front hard button set to 1) showed nothing (with intial and second step I had seen messages on it) so I hit OK on the remote and it went through a third upgrade step.
This third step was strange in that I thought the upgarde was only a two step procedure. Did anyone else get this third upgrade step?
Frank D is offline
post #194 of 1264 Old 11-12-2007, 10:52 PM
Robert D's Avatar
I burned an ISO CDR and it updated to "Step 5/5" and has been sitting there for like five minutes. Is this normal?
Robert D is offline
post #195 of 1264 Old 11-12-2007, 10:59 PM
unclewebb's Avatar
Just finished updating my A2 with the file HD-A2-2700U.
It took about 5 minutes to download, 1 minute to burn an ISO disc and just under 9 more minutes to complete the update.
The only thing I've noticed so far is that they've fixed the 2 channel light that used to come on even when it was playing back multi channel audio. Boot up time and disc loading time are the same as with v2.5. The A2 is a good machine without too many problems so I suspect most of the updates are likely for disc compatibility issues.
unclewebb is offline
post #196 of 1264 Old 11-12-2007, 10:59 PM
Patsfan123's Avatar
Quoted: 117 Post(s)
Liked: 69
Yes, do not worry, mine took about 15-20 mins to finish.
LG 65C6P | Onkyo TX-NR646 5.1.2 | Polk Audio Monitor70 Series II Floorstanding Fronts | CS2 Series Center | Monitor40 Series II Bookshelf Rears | Onkyo SKH-410 | eD A2-300
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D
Collection: Blu-ray
Patsfan123 is offline
post #197 of 1264 Old 11-12-2007, 11:00 PM
WilliamZX11's Avatar
Quoted: 25 Post(s)
Yes. Don't interupt it.
WilliamZX11 is offline
post #198 of 1264 Old 11-12-2007, 11:02 PM
lowenbotten's Avatar
Originally Posted by Gor18 View Post
you know everyone keeps telling me i am hearing the True HD out of my A2 threw my HDMI to my onkyo 705...but its just annoying and it always makes you wonder when all it says is HDMI pass threw or MCH PCM 5.1. I hate to spend 500 bucks on a A35 just to see true hd but you always wonder if you are really hearing it, till you see that true hd light up.
You don't seem to be understanding. The A2 will not pass TrueHD or DD+ unencoded to a receiver. It can't. The player is going to decode the audio and the receiver receives it as PCM. The player is decoding the audio instead of the receiver. That's the only difference. What you hear will be the same.
lowenbotten is offline
post #199 of 1264 Old 11-12-2007, 11:02 PM
cambrian's Avatar
Update completed successfully! It took about 20-25 mins.
Now if only my SR605 would get here and the PS3 would decode DTS-HDMA and I am in HDM heaven.
cambrian is offline
post #200 of 1264 Old 11-12-2007, 11:04 PM
jim3860's Avatar
Originally Posted by ChrisW6ATV View Post
Jim-
Thanks Chris. This explains a lot. I hope at some point they will have DTS-MA HBR available through the analog outs. I have a lexicon pre that has an 7.1 analog bypass on it and would love to not have to buy another pre/pro that has the decoding.
REGARDS JIM
jim3860 is offline
post #201 of 1264 Old 11-12-2007, 11:07 PM
TDKKP's Avatar
Anyone got luck with HDMI/DVI connection on A2? Mine is still not working with 2.7, I wish I haven't updated 2.5 that turned off my upconversion signal.
TDKKP is offline
post #202 of 1264 Old 11-12-2007, 11:09 PM
Robert D's Avatar
Wow I finally got the player to update then checked all the settings to make sure they were the same then enabled 1080p/24 and bit-stream out via hdmi. Put in the HD DVD title "Elizabeth" and whoa my Denon 3808CI receiver indicates "Dolby TrueHD" and sounds fantastic.
Robert D is offline
post #203 of 1264 Old 11-12-2007, 11:09 PM
crussell1492's Avatar
can anyone with a XA2 and Sanyo Z2000 confirm that 1080/24 works with 'forced' mode?
crussell1492 is offline
post #204 of 1264 Old 11-12-2007, 11:16 PM
lovingdvd's Avatar
Quoted: 2445 Post(s)
Liked: 414
Sorry, as disappointing as it is, there is no FORCED mode (yet) available on the XA2. I don't have any info on the Sanyo Z2000, but if it requires a forced mode you won't have that with the XA2.
lovingdvd is online now
post #205 of 1264 Old 11-12-2007, 11:17 PM
Gor18's Avatar
Can anyone tell me if the display menu during movie play back has changed on the A2 after the firmware update?
Gor18 is offline
post #206 of 1264 Old 11-12-2007, 11:17 PM
John Haghighi's Avatar
What about error 408bc504 message when attempting to play Transformers web enabled content, is that resolved with this update?
John Haghighi is offline
post #207 of 1264 Old 11-12-2007, 11:21 PM
mlkmgr's Avatar
is there an option i am missing for the "bitstream out via hdmi"? my XA2 only allows on and off for the "new" setting. thanks.
mlkmgr is offline
post #208 of 1264 Old 11-12-2007, 11:22 PM
Symbolic Hearse's Avatar
OK, so I got a reciever that doesn't decode the HD audio options. It does however, have Multi Ch input which I've been using with my XA2. Does the new Digital direct option effect me in any way. What about the 1080p/24 hz? I have a 720p television.
Symbolic Hearse is offline
post #209 of 1264 Old 11-12-2007, 11:25 PM
Zinje's Avatar
I have an older receiver with analog ins. Am i suppose to set the player for bitstream or pcm to get it to output truehd. Or is that bitstream fix just for hdmi?
Zinje is offline
post #210 of 1264 Old 11-12-2007, 11:27 PM
Same here. Also, do I have the digital direct audio mode set to on or off if using analog ins?
Reply HD DVD Players
