How do I get the best audio out of my A2? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-13-2007, 09:40 AM - Thread Starter
Clever_User_Name's Avatar
I have a non-HDMI based receiver. Do I need to upgrade my receiver to optimize my audio? Since it has no multi-channel analog outs and I can't accept a PCM signal over HDMI, am I out of luck for lossless?
Methinks I have no choice but to buy a new receiver or pick up an A1, A35 or XA2.
HD DVD, I hardly knew you....
The disc toll:
Blu: 85
Red: 107
Clever_User_Name is offline
post #2 of 9 Old 11-13-2007, 09:43 AM
ssabripo's Avatar
Quoted: 60 Post(s)
Liked: 35
for lossless, yes, you are out of luck.
you can still get DTS over optical (downmixed from truHD and DD+ to DTS @ 1.5mpbs), and your receiver should be able to decode this.
ssabripo is offline
post #3 of 9 Old 11-13-2007, 09:47 AM - Thread Starter
That's what I thought.
Darn. More cash outflows in the forecast.
The disc toll:
Blu: 85
Red: 107
post #4 of 9 Old 11-13-2007, 09:48 AM
dlhoppe's Avatar
Optical/Coaxial can be a problem for certain older AVR's. There's been many posts regarding garbled center channel and such. I believe it had something to do with the high bit-rate DTS from the A2. You might want to try it first and see what you get before jumping the gun on a new AVR. My setup is not high-end by any means, but my Yamaha does a really nice job with the DTS stream from my A2. Don't knock it until you've heard it.
dlhoppe is offline
post #5 of 9 Old 11-13-2007, 09:49 AM
JOHNnDENVER's Avatar
Are you really disappointed with the DTS that newer audio is converted to by the player? For the vast majority of people even more audiophle types, this is amazing audio already.
JOHNnDENVER is offline
post #6 of 9 Old 11-13-2007, 09:52 AM
dlhoppe's Avatar
By the way, without some really good speakers and reasonable acoustic properties in your viewing area, you may not be able to hear the advantages of the lossless stuff via a new AVR anyways. Food for thought....
dlhoppe is offline
post #7 of 9 Old 11-13-2007, 10:12 AM - Thread Starter
Have to admit, it sounds pretty darn good as-is, but I am completely unreasonable when it comes to upgrade-itis.
Plus, I now have three HDMI source inputs, so some switching wouldn't be so bad.
But, I hear what you all say - and don't disagree. I will likely get little benefit form the lossless format over the high bitrate DTS output in my current configuration/room.
The disc toll:
Blu: 85
Red: 107
post #8 of 9 Old 11-13-2007, 10:14 AM
ssabripo's Avatar
Quoted: 60 Post(s)
Liked: 35
Dissappointed? not necessarily.
Did I expect "better" sound from 1.5mpbs available bitrates sampled from higher bitrate and lossless original sources? Absolutely!
I already addressed this to you earlier:
http://www.avsforum.com/avs-vb/showp...4&postcount=27
and some final comments:
http://www.avsforum.com/avs-vb/showp...1&postcount=32
again, the conclusion for me is that it is a good audio track, and not "bad" at all per se......but it could have been so much more! It's just very obvious that they just threw something together pretty quickly for those trying to use the optical out, and didn't implement a good algorithm.
A good analogy: encoding MP3's at CBR @ 128kps, instead of VBR @ 256 with LAME encoder.
ssabripo is offline
post #9 of 9 Old 11-13-2007, 10:15 AM
dlhoppe's Avatar
LOL! I know exactly what you mean. I love upgrading too.
In that case, I think you should go out and find a really cool AVR! Have fun shopping.
dlhoppe is offline
Reply HD DVD Players
