Just got HD-A2 and cant figure out problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-22-2007, 01:24 PM - Thread Starter
MrDeflation's Avatar
I did a search on all the threads but didn't see my problem listed.
Just got an HD-A2 and hooked it up to my CRT SD TV while I am waiting on delivery of a HDTV Plasma. I just wanted to test the HD-A2 to see if it works properly in regular sd-dvd format.
I have it (correctly) hooked up via component cables and for the life of me I cannot even the get menu to appear.
A purple fuzzy scroll appears when the player is turned on. I can't get the menu to appear to even set the output at 480. I tried playing a known good dvd and I have the same purple fuzzy scroll screen and zero audio.
I don't know what else to try next.
Any ideas?
MrDeflation is offline
post #2 of 3 Old 11-22-2007, 01:29 PM
xradman's Avatar
Try composite cable to start out with. Do you know whether your component input on your CRT works and at what resolution? Also I'm sure you know this but, component is 3 video cables for red, green, and blue signal and composite cable is a single cable typically with yellow connector for video.
Addicted to shiny round discs with HD content
My Home Theater
My Movie Collection
BDP-83 EAP (second group)
xradman is offline
post #3 of 3 Old 11-22-2007, 03:12 PM - Thread Starter
Much thanks for the heads up.....
Sorry for the brain fart.
I had the composite cables connected to the component input on the CRT.
Fixed..... works awesome so far. I am able to play SD DVD's. Except I am still trying the get the HD-A2 menu to come on screen.
Thanks again and happy holiday!
Reply HD DVD Players
