Which hd-dvd player is best for my setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-27-2007, 08:56 AM - Thread Starter
ivan15's Avatar
Hi,
I am thinking to get a hd-dvd player but not sure which player is better for my set up. Hd-A3 or Hd-a35? I have a Onkyo 705 receiver and a Benq w500 in my home theater.
thanks
ivan15 is offline
post #2 of 6 Old 11-27-2007, 09:35 AM
K-Dawg's Avatar
705 will process bitstream audio from A-35. Anchor bay, Deep Color, 24p are of no impact on you (right now).
A-3 will handle PCM just fine to 705.
A35 future proof - A3 great out of the box and saves you money
Take your pick.
K-Dawg
"People vote with their dollars!"
K-Dawg is offline
post #3 of 6 Old 11-27-2007, 10:03 PM - Thread Starter
ivan15's Avatar
Do I need a HDMI cable that compatible with 1.3 between HD-A35, receiver and projector to experience the new 1.3 feature (deep color ?)
thanks
ivan15 is offline
post #4 of 6 Old 11-27-2007, 10:10 PM
Tspeer's Avatar
thanks
I don't believe so. All decent HDMI cables should have the bandwidth. Get the 24awg from monoprice.
I Bet You Wish You Could! - Roger Wilco
Directions for updating your Onkyo xx5 receivers firmware. **Newly updated 7-22-2009**Re-uploaded 2-23-2015**
Something from damninteresting.com
Tspeer is offline
post #5 of 6 Old 11-28-2007, 07:33 AM
Jgatie's Avatar
thanks
You can't "experience" Deep Color. No mainstream sources display Deep Color, and not many displays take advantage of it. At this time it is vaporware, outside of a few HD cameras.
Jgatie is offline
post #6 of 6 Old 11-29-2007, 07:31 PM
Digity8's Avatar
Doesn't the w500 'accept' 1080p24? would getting a player that outputs that make a difference?
Digity8 is offline
Reply HD DVD Players
