Who has handshake issues with HD DVD player (DVI or HDMI)? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 01-20-2008, 01:34 PM
mrspeakers's Avatar
XA2 -> Firefold 2m HDMI -> Integra 9.8 -> firefold 20' hdmi -> 46xbr4
Video fine, audio is fine usually, but sometimes it syncs to multichannel instead of bitstream. Have to restart everything to get bitstream to work.
Scientific Atlanta 8000 cable -> 2m firefold DVI-HDMI -> Integra 9.8 -> firefold 20' hdmi -> 46xbr4
No picture to the Sony. Integra says it is synced, Sony says unsupported signal format
Scientific Atlanta 8000 cable -> component -> Integra 9.8 -> firefold 20' hdmi -> 46xbr4
Works fine. Settled for this for cable, a bit fuzzier, but it beats no picture
Dan
Writing about music is like dancing about architecture.
mrspeakers is offline
Old 01-20-2008, 04:21 PM
cozmogeek's Avatar
Quoted: 26 Post(s)
HD-A20 -> Westinghouse TX-47F430S no signal at all with HDMI
BUT when I add my Onkyo 805 in between it works fine.
cozmogeek is offline
Old 09-08-2009, 11:01 PM
leem6453's Avatar
HDA2 -> 3 in 1 HDMI Switcher -> Panasonic 42" Plasma = Signal for about 5-10 minutes then no picture. Works fine over component.
HDMI works fine for everything else (2 dvd players and PS3).
leem6453 is offline
Old 09-09-2009, 12:31 AM
sonydude1966's Avatar
Quoted: 14 Post(s)
Only a 19 month interval between posts.
sonydude1966 is offline
Old 09-09-2009, 09:51 PM
leem6453's Avatar
Do I have the record?
leem6453 is offline
Old 10-11-2009, 05:59 PM
Alano2's Avatar
Motorola DCT3412 Comcast cable box and DVR
and
Panasonic DMP-BD60 Bluray Player
using HDMI into
Denon AVR-2310CI AV Receiver
using HDMI into
HDMI2DVI adapter
using DVI into
Panasonic TH-42PA20 Plasma HDTV
Sound plays through the Denon when the TV is off.
Sound does not play anywhere when the TV is turned on.
Picture is fine for both sources.
The sound does work if I use the optical audio cable from the cable box or the Bluray to the receiver, but I only have 4 digital audio inputs.
Alano2 is offline
Old 10-11-2009, 06:14 PM
Splicer010's Avatar
Liked: 39
and
using HDMI into
using HDMI into
HDMI2DVI adapter
using DVI into
This is for HD DVD only.
Splicer010 is offline
