What's the deal with the A2 never showing subtitle or audio tracks selected? - AVS Forum
post #1 of 2 Old 12-10-2007, 07:56 PM - Thread Starter
nzk
nzk's Avatar
When you press the subtitle button, it will just tell you how to change them. It's trial and error, and it doesn't say anything like '[1/3] - English' like it does when playing SD DVD. Same goes for Audio, but it doesn't even give confirmation that you pressed the button. You just have to hope it went through. Am I missing something or is this a known problem?
nzk is offline
post #2 of 2 Old 12-10-2007, 08:33 PM
Robert D's Avatar
Press the info or is it display button on the remote first then when you press the audio button you will see the change on-screen.
Robert D is offline
Reply HD DVD Players
User Tag List
