Anyone have HDMI>DVI problems with 2.7 on A2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-09-2008, 05:56 PM - Thread Starter
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
Hi guys,
I just bought an A35 and am about to put my A2 into storage just in case the A35 fails in the future now that it looks like HD DVD will die.
Since I don't know when my A2 will see the light of day again I want to upgrade it to 2.7 (from 2.5) before storing it. I recall someone losing the HDMI>DVI connection with 2.7; was this an isolated case? I have the following equipment:
Toshiba HDA2
Toshiba 57HDX82 (DVI HDCP input)
Monoprice 4X1 HDMI switch
Any feedback would be greatly appreciated.
EVT is offline
post #2 of 10 Old 01-09-2008, 06:09 PM
westgate's Avatar
Originally Posted by EVT View Post
Hi guys,
Toshiba HDA2
this isnt the reply u want but i'd thought 'chime' in anyway.
im leaving my a2 at fw 1.1. it works great except for some black crush/color space issues w my dvi equipped hd pj. do u get same/similar issues w your a-2 hdmi-dvi hdtv?
as i understand g3 players not to have the hdmi-dvi issues, i may soon be getting an a3,a30 or a35.
westgate is offline
post #3 of 10 Old 01-09-2008, 07:28 PM
TrevorS's Avatar
It depends on the equipment combination -- my A2 has no problem with either of two Display DVI-D inputs. I'm running 2.7.
TrevorS is offline
post #4 of 10 Old 01-10-2008, 04:10 PM
jruser's Avatar
Quoted: 66 Post(s)
My HD-A2 is limited to 720p when connect to either DVI port of my Westinghouse LVM-42w2.
Over HDMI it works fine at 1080i.
If anybody knows a way to fix this, let me know.
jruser is offline
post #5 of 10 Old 01-10-2008, 04:25 PM
StuJac's Avatar
No problem here into a Panasonic "old style" 32hdtv that uses dvi.
Pan 46PZ85U, Marantz SR5003, TiVo Premier, TiVoHd + 1tb, A2 (fs), PS3, Pan DMR E-95 (fs), JVC DVD-A, Polk & Infinity, Harmony One
StuJac is offline
post #6 of 10 Old 01-10-2008, 04:26 PM
JustAsk's Avatar
Can't help! My A2 is component out.
HD-XA1, HD-A2, BDP-S300 and DMP-BD55K owner
JustAsk is offline
post #7 of 10 Old 01-10-2008, 06:23 PM
TreyS's Avatar
My A2 worked with 2.7 using my HDMI to DVI cable but it still has the black crush/ colorspace issues (lack of shadow detail) as 1.1 had.
TreyS is offline
post #8 of 10 Old 01-10-2008, 08:25 PM - Thread Starter
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
Thanks for the input guys,
I went ahead and updated my A2 to 2.7 and everything works fine; in addition, I updated my A35 to 1.3 and it works fine too.
EVT is offline
post #9 of 10 Old 01-10-2008, 10:53 PM
TrevorS's Avatar
That's great -- always nice to hear about things that work out !
TrevorS is offline
post #10 of 10 Old 01-12-2008, 08:53 PM
westgate's Avatar
thats the main reason im keeping my a2 at fw 1.1. its played everything ive put into it, so far.
'if it aint broke....'
westgate is offline
Reply HD DVD Players
