XA2 and 8.5G DVD+R DL Discs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-12-2008, 02:03 PM - Thread Starter
Yoeddy1's Avatar
I was thinking of backing up a SDVD with my Dual Layer burner using a 8.5 gig dual layer DVD+R disc. Anyone know if this player will support this type of media? I'm looking to put it on a component video connected setup and to use the REON upconversion, I need to make a backup and use a blank.
Any comments would be appreciated.
Yoeddy1 is offline
post #2 of 9 Old 01-12-2008, 04:26 PM
dayvo's Avatar
I've been using dual layer DVD+R for authoring stuff and my XA2 plays them without a problem. Ironically enough, they're Sony DVD+R's.
dayvo is offline
post #3 of 9 Old 01-12-2008, 05:33 PM
DarthJedi's Avatar
I am trying to get this to work in my player; how are you burning your disc? My xbox plays them just fine but my XA2 says it can't play because it is not a DVD format. I put the right HDDVD_TS folder and used udf burning with nero; what could I be doing wrong?
May HD be with you always
DarthJedi
XBOX LIVE: ForceFields
DarthJedi is offline
post #4 of 9 Old 01-12-2008, 05:46 PM - Thread Starter
Yoeddy1's Avatar
HOLY NEAR HI DEF!!! I just finished Star Wars III Revenge of the Sith, and burned it using a Dual Layer +R disc...by Sony, and kept everything as the original. DVDShrink and DVDDecryptor are used. Didn't deselect anything as I didn't want any compression. I cannot believe how good the REON chip is! I have a VisionFC4 on order too and should be here next week.
For those that are trying to get upconversion and only have a component connection, give this a shot!
This accomplishment pushed me away from Bluray even more. Having the XA2 and the ability to enjoy my SDVD's upconverted with REON will tide me over for a long while...meanwhile, I can still buy more HDDVD's.
Yoeddy1 is offline
post #5 of 9 Old 01-13-2008, 01:55 AM
swifty7's Avatar
dvd+R DL media not working properly with my A2, is there something I need to do?
I'm using verbatim DL media bitset to ROM.
swifty7 is offline
post #6 of 9 Old 01-13-2008, 07:19 AM
allargon's Avatar
Quoted: 52 Post(s)
Liked: 44
Your booktype should be set to DVD+R. The search button is our friends.
allargon is offline
post #7 of 9 Old 01-13-2008, 07:24 AM
Sarcoptic's Avatar
I don't think there is a booktype issue with the XA2...mine plays both whether its set on DVD-ROM or DVD+R. The biggest issue with dual layer media is there is crappy media (3/4 of what is out there) and good media. I always buy Verbatim and never have issues...
Sarcoptic is offline
post #8 of 9 Old 01-13-2008, 09:53 AM
swifty7's Avatar
thanks for the info but why doesn't it work with ROM booktype? how can it tell difference?
very strange.
thanks again.
swifty7 is offline
post #9 of 9 Old 01-13-2008, 01:05 PM - Thread Starter
Yoeddy1's Avatar
The Sony DL + media that I used has burned 5 DVD's perfectly. I watched Titanic SE with my family last night...the picture was mindblowing.
Yoeddy1 is offline
Reply HD DVD Players
