Making Toshiba players region free. - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 125 Old 02-26-2008, 07:14 AM
redbill's Avatar
Originally Posted by Lutter View Post
Alright, I went from 2.7 -> 1.3US -> 2.501EU -> 2.7US and now PAL/NTSC DVDs play from all regions (have tried R1/R2 of both kinds) which is great... but I am no longer getting audio though my HDMI output, although I am still getting video.
Lutter, did you need to edit the 2.501EU FW? I know you need to edit the 1.3 to force the update, but I can't find a straight answer if you need to edit the 2.501 to match your player model. thanks
redbill is offline
post #122 of 125 Old 03-03-2008, 06:18 AM
meli15's Avatar
I WENT FROM 2.8 US TO 1.3 US UP TO 2.5 UK AND 2.51 REGIONFREE UK AND BACK TO 2.8 UK........ALL WORKS PERFECT.ONLY 1.3 HAS TO BE HEXEDITED ALL OTHERS REMAIN THE SAME..................HOPE THIS HELPS
meli15 is offline
post #123 of 125 Old 03-12-2008, 06:52 PM
redbill's Avatar
I seem to have a PAL problem. I have an A2, onkyo 705 (receiver), samsung 4695 (lcd hdtv). I downgraded from 2.7 to 1.3, and then to the E1 hacked 2.5.1. (I also went to US 2.8 afterwards once, and once w/o). Both times I can play HD-DVD, NTSC region 1, but not region 2 PAL. The player seems to accept it, but my TV displays "Not Supported Format". The A2 plays it - I get sound, but the picture is does not show up. So the region hack worked & PAL hack worked, but my TV does not seem to accept PAL. Which is weird, because I have a separate (non-upconvert) all-region player that works fine. any ideas? thanks!
redbill is offline
post #124 of 125 Old 03-12-2008, 07:09 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
I think the A2, even when made region free, is still outputting PAL at 50Hz. So your TV would need to be able to accept 50Hz signals. The A2 hack only helps with region encoding, not with PAL vs. NTSC.
I think multi region regular DVD players convert the PAL signal to NTSC output for NTSC displays.
Theater 1: LG OLED55E6P 4K TV, Samsung UBD-K8500 UHD Blu-ray player, Oppo UDP-203, Dune HD Solo 4K
Theater 2: Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D (CFW), Dune Base 3.0 / Smart units, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is offline
post #125 of 125 Old 03-12-2008, 10:18 PM
redbill's Avatar
thats what i was afraid of. i figured my TV would be smart enough to handle the 50Hz, but I guess not... well, at least it didn't break the non-PAL signals..
redbill is offline
Reply HD DVD Players
