Firmware 2.8 for A2/A20/XA2 out! - Page 30 - AVS Forum | Home Theater Discussions And Reviews
post #871 of 879 Old 06-29-2008, 11:36 AM
sulli2p's Avatar
Downloaded firmware version 3.0 to my A2 last night via the ethernet connection, upgrading from 2.8. Not sure what's in it, but played the historically troubled Planet Earth, Disk 3, Jungle, Chapter 4, and it played through without a hitch, first time ever.
sulli2p is offline
post #872 of 879 Old 06-29-2008, 01:36 PM
Scarpad's Avatar
Quoted: 67 Post(s)
Liked: 37
Does it speed up boot time any? I've been staying at 2.3 but it just takes so long to get to the menu of the disk.
Scarpad is offline
post #873 of 879 Old 06-29-2008, 01:38 PM
Ted_K's Avatar
About 30 seconds to "No Disc" message on my A2 w/3.0.
Ted_K is offline
post #874 of 879 Old 06-30-2008, 05:08 AM
wingzz's Avatar
Well this is great, I updated my xa2 via the ethernet last night, the unit turned off after and opened the tray, I restarted it and the door never closed and it stayed on welcome for a long time, then it got an error msg of something like 20087033 and thats all that comes up now, the welcome then the error, I tried to unplug it for a hour and that did nothing, any ideas???
"There are only two ways to live your life.
One is as though nothing is a miracle.
The other is as if everything is." Einstein
Now Format Neutral
wingzz is offline
post #875 of 879 Old 06-30-2008, 08:34 AM
sharkcohen's Avatar
There is a 3.0 thread.
sharkcohen is offline
post #876 of 879 Old 06-30-2008, 08:36 AM
moviegeek's Avatar
Push and hold the power button on your player for 10secs,if that doesn't help then hit Setup->General->Maintenance->Initialize.
If neither help then call Toshiba because it's bricked.
moviegeek is offline
post #877 of 879 Old 07-20-2008, 03:59 PM
BRAISKI's Avatar
Quoted: 16 Post(s)
I just got a Refurb A2, should I upgrade the Firmware?
Denon 2809CI
C: Def Tech - CLR2002
F: Def Tech - BP2002TL
S: Def Tech - BP1.2X
SB: Def Tech - PM400
Sub: Plan to get the SVS-SB1000
BRAISKI is offline
post #878 of 879 Old 07-20-2008, 05:05 PM
sonydude1966's Avatar
Quoted: 14 Post(s)
I haven't read any reports of any downsides to updating the A2 to firmware 3.0. Whenever I take my A2 out of backup status (the closet), there's a 3.0 update disc waiting for it.
sonydude1966 is offline
post #879 of 879 Old 07-27-2008, 03:03 PM
faberryman's Avatar
Is the "jaggies" problem with firmware 2.8 and 3.0 for the XA2 only for HD-DVDs or for upconverted SD-DVDs as well?
faberryman is offline
Reply HD DVD Players
