Firmware 2.8 for A2/A20/XA2 out! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 879 Old 01-23-2008, 01:26 AM
Sirluckyj's Avatar
Originally Posted by MidnightWatcher View Post
Everyone, remember to re-initialize after a firmware update. This will set everything back to default so make a note of what your settings were prior to reinitializing the player.
Why do we need to re-initialize? I've never done this on other updates.
Jim
Sirluckyj is offline
post #92 of 879 Old 01-23-2008, 01:40 AM
v1rtu0s1ty's Avatar
Originally Posted by mrspeakers View Post
They added support for bitstreaming 7.1, I believe. 2.7 supported 5.1. Correct?
What about for A2? I did update this evening but I didn't notice any changes in the menu.
v1rtu0s1ty is offline
post #93 of 879 Old 01-23-2008, 02:17 AM
Sirluckyj's Avatar
I have an XA2 and a Pio Elite Pro-150FD TV. I upgraded to 2.8 Set the XA2 to "up to 1080p/24" and frame rate to "Auto". I put in a Video Concert HD DVD and my Pio showed 1080p/60. Put in a movie which is supposed to be 1080p/24 and the Pio showed 1080p/60. If "Auto" is working, should not the Pio show 1080p/24? I guess I don't understand what "forced" means. Help!
Jim
post #94 of 879 Old 01-23-2008, 02:28 AM
Will Munshower's Avatar
Thats the way I see it. I guess we didn't see this coming...Bonus!
Samsung KS8000 65"
Denon AVR-X2300W 5.1.2
DIRECTV HR54 Genie Server (UHD)
NVIDIA Shield
X-Box One S
Toshiba HD-XA2 (Yup...I'm still using one!)
Will Munshower is offline
post #95 of 879 Old 01-23-2008, 02:47 AM
Robert D's Avatar
Jim
I have the Pioneer Pro 150FD and to get the hdtv to accept and display 1080p/24 at 72hz (3:3 pull down), the display settings must be set to "picture/pro adjust/purecinema/film mode=advance. Also for best results enable "pure and dot by dot".
Robert D is offline
post #96 of 879 Old 01-23-2008, 02:50 AM
arty100's Avatar
What firmware did you have before?
I had 2.7 which took two steps.
As others have stated here 2.8 loads in one step which faked me out.
arty100 is offline
post #97 of 879 Old 01-23-2008, 04:52 AM
Sirluckyj's Avatar
I have my pro-150 set as you suggested. If I set the XA2 to a frame rate of 1080p/24, my pio shows 1080p/24. What I am saying is the "Auto" does not automatically select 24 hz on the XA2. The Pio is OK.
Jim
post #98 of 879 Old 01-23-2008, 04:59 AM
Frank Derks's Avatar
Quoted: 359 Post(s)
Liked: 284
I think that with 'auto' the negotiation with the display device determines the output of the player.
The problem can be that some displays do not (properly) report back to the player that it can do 24Hz. Or that the receiver in between is messing up the player display negotiation.
The '24p' setting bypasses the negotiation and forces the player to output 24Hz.
Stereo is simply Multichannel light.
Frank Derks is offline
post #99 of 879 Old 01-23-2008, 05:02 AM
franke69's Avatar
not on mine,it doesn't....
Don't panic-nothing is under control...
franke69 is offline
post #100 of 879 Old 01-23-2008, 05:29 AM
cybersoga's Avatar
Does this new firmware fix any of the following bugs:
1. Forced 24p output for those screens that display 24p but don't negotiate as supporting it in its EDID?
2. Automatic switching between 60p and 24p as the content is encoded on the disc?
3. 24p to 60p conversion with 3:2 pull down and no deinterlacing artifects?
cybersoga is offline
post #101 of 879 Old 01-23-2008, 06:05 AM
cam
cam's Avatar
Since I am out on a business trip, I can not test these myself. But from what I have read from various reports, the answer are:
1) Yes, there is a forced 24p output.
2) No, no automatic switching between 60p and 24p.
3) no report on this.
On the automatic frame rate, may be many of us mis-understood this option. "Auto" means the player will do negotiation with the display device, then determine the frame rate automatically, rather than determine the frame rate depends on the source material automatically.
cam is offline
post #102 of 879 Old 01-23-2008, 06:46 AM
Schwa's Avatar
Quoted: 1018 Post(s)
Liked: 1082
YES. You must always remove the disc otherwise it will brick your player. If you get out of this one unscathed I'll be amazed. If not, you'll need to send the player in to Toshiba.
Nope, not this time. I accidentally left a disc in one of my XA2's and the update went fine.
Schwa is offline
post #103 of 879 Old 01-23-2008, 07:29 AM
MidnightWatcher's Avatar
Quoted: 37 Post(s)
Liked: 25
That's VERY good. Maybe Toshiba did something to get around this. I've seen some folks we've left discs in and they ended up having to send the unit to Toshiba to be updated.
MidnightWatcher is offline
post #104 of 879 Old 01-23-2008, 07:48 AM
akadennis's Avatar
Toshiba needs to release an update for their 3rd generation series. An auto mode for 24p would be great in addition to fixing playback problem with Bourne Ultimatum
akadennis is offline
post #105 of 879 Old 01-23-2008, 08:03 AM
Quoted: 359 Post(s)
Liked: 284
Had that BU problem (2.7) (And also second disc of Alexander)
The player stopped after the pg screen with an error msg.
After I initialized it crashed the player completely once and after a power down cylce the problem was over.
Both BU and 2nd Alexander discs play correct now.
post #106 of 879 Old 01-23-2008, 08:17 AM
Ferdopa's Avatar
Hi.
The firmware works perfect on XE1 (European model); I updated it few minutes ago.
Ferdopa is offline
post #107 of 879 Old 01-23-2008, 08:27 AM
kevinuk's Avatar
Originally Posted by Ferdopa View Post
Hi.
So are you saying the American firmware for the xa2 Works on the XE1?
Cheers.
Kevin
kevinuk is offline
post #108 of 879 Old 01-23-2008, 08:30 AM
mrspeakers's Avatar
Well, it doesn't work. I have a 24fps display, but on Auto for output it just sticks at 1080p. 2.7 made me manually toggle between 1080 and 1080/24, this still makes me do it.
The idea of a source detection and a display detection that don't interact seems like a kludge. This is making the video almost as complex as HDMI audio.
Dan
Writing about music is like dancing about architecture.
mrspeakers is offline
post #109 of 879 Old 01-23-2008, 08:44 AM
vksf01's Avatar
No need, when it's forced I get 24. I just wish Auto worked, as I do like concert videos. Having to stop the video and enter setup to change the output is a PITA. Maybe auto will be like 24fps and lip sync, 2nd release will work.
yeah, maybe i should start a version 2.9 wishlist....
vksf01 is offline
post #110 of 879 Old 01-23-2008, 09:07 AM
Ferdopa's Avatar
Yes
Ferdopa is offline
post #111 of 879 Old 01-23-2008, 09:14 AM
iblumberg's Avatar
I want to repeat something I noticed about 24p and auto under 2.8 on the XA2.
My display does report that it supports 24p and successfully worked with 2.7 to display 24p when the XA2 was set up for it.
Now, under 2.8, when the XA2 is set for auto, and it is displaying the set up screen for the player with no disc in the player, it does indeed send 24p to my screen. When I start up Harry Potter 5 (the only HD DVD I currently own) the XA2 switches to 60p.
I have a theory about the problem. My theory is that the player "auto" detects the source material frame rate and sets it immediately when the disc starts up and it does not check or change this setting after the initial setting. Unfortunately, most commercial discs contain all sorts of intro matieral that is likely recorded in 30p, causing the player to go to 60p mode, so once the disc starts we are stuck.
I hope Tosh will fix this in the future.
Ira
iblumberg is offline
post #112 of 879 Old 01-23-2008, 09:15 AM
schroedk's Avatar
Originally Posted by The Main Event View Post
The update is currently in process via ethernet, but I forgot to remove my disc in my XA2. Will it cause any problem?
It very well could cause problems, but you might get lucky. I'm usually very good about taking the disc out, but about 3-4 FW updates ago I realized right after starting the download that I hadn't checked the tray. 45 minutes of panic ensued, but everything actually worked fine. I still wouldn't recommend it, since a lot of players do brick when a disc is left in.
Don't mess with anything now, don't hurry the player up, just let it go through its natural cycle. When it powers down, hit "eject" rather than power, that way when it powers up again, it'll hopefully eject the disc and go through the installation routine okay.
Good luck!
Two things are infinite: the universe and human stupidity. And I'm not sure about the universe. -- Albert Einstein
schroedk is offline
post #113 of 879 Old 01-23-2008, 09:24 AM
kevinuk's Avatar
Yes
Thanks for that.
kevinuk is offline
post #114 of 879 Old 01-23-2008, 09:30 AM
johnny15's Avatar
Has anyone seen any point to update the A2 with this??....seems like most of the benefit is for the higher end models with this update.
johnny15 is offline
post #115 of 879 Old 01-23-2008, 09:36 AM
Zetmor's Avatar
You don't really need to reset settings, because the procedure doesn't tell to do so.
But ... IT people usually reset settings after a firmware upgrade because ITs experienced issues not doing it : imagine a setting in version x allowing 5 values. You set it to 5. Imagine the new version has only 4 possible values. It's set to 5 in the player memory. It can crash the player. But that was in jurassic times. Now a good firmware, well programmed, shouldn't have that kind of problem (it's easy to avoid : when a setting is going to have a lesser maximum value in next firmware version, it's easy to change the memory used by simply not using the old address, and using a new address that has always been at 0 by default).
So. Me thinks you don't need to reset setting. But if you see a setting displaying a weird thing, remember that it could be it : simply reset all settings if it happens.
Zetmor is offline
post #116 of 879 Old 01-23-2008, 09:52 AM
wlagarde's Avatar
1) No - at least not on my A20.
wlagarde is offline
post #117 of 879 Old 01-23-2008, 09:53 AM
wlagarde's Avatar
That is you can select forced 1080p/24 mode in the setup menus but the player continues to put out 1080p/60
wlagarde is offline
post #118 of 879 Old 01-23-2008, 10:05 AM
cam
cam's Avatar
Ira
Your theory could be correct, but then it actually brings up a problem: There are potentially many ads and previews that could be in either 24fps or 30fps, and if the player keeps sensing this source frame rate all the time, then the output will toggle between the two, as far as I know, most display will go blank (black out) when the input resolution/frame rate changes, so it will be very annoying before the main movie starts.
What I tried to say is that this auto on the source material doesn't work in practice because the player can't determine which part of the source is the main movie, all it gets is a top menu from the disc, and goes ahead to play whatever the user chooses.
cam is offline
post #119 of 879 Old 01-23-2008, 10:10 AM
Jon Spackman's Avatar
Its not a forced 24. look at the posts from people who have a display that does not handshake for 1080p24, they get 1080p60 or 1080i60. Its not forced.....
Its more like if your display handshakes for 24p then it converts everything HD to 1080p24, and it your display does not, then you get the highest it can handshake for on all HD discs (video and film)
Just enjoy HD in whatever form you can (Sat, Cable, D-VHS, OTA, HD DVD, or BD).
Jon Spackman is offline
post #120 of 879 Old 01-23-2008, 10:37 AM
jwebb1970's Avatar
Liked: 38
Was about to ask the same thing.
Any A2 owners experience ANY differences/improvements w/ 2.8 in any player/performance aspect?
Money does not buy happiness. It can, however, buy you a giant boat that you can pull up alongside happiness. - David Lee Roth
jwebb1970 is offline
Reply HD DVD Players
