HDA30 can't get it to output DTS or DD - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 02-19-2008, 08:04 AM
Jgatie's Avatar
There's no way you got DTS out of an HD DVD using optical over the A3. The A3 only puts out DD @ 640kbs over optical from HD DVD. Unless you were viewing (1) An SD DVD with a DTS soundtrack or (2) an HD DVD with a DTS-HD soundtrack (there's only one non-import - Pan's Labyrinth), then the output was most definitely DD.
Jgatie is offline
post #32 of 33 Old 11-29-2009, 06:18 AM
robetclo2516's Avatar
Like it was said, the HD-A3 and A30 cannot output DD+, DolbyTrueHD or DTS HD and DTS MA. Those players don't support HDMI v. 1.3 and it is needed. I own a Duo HD Samsung BD-UP5000 an all HD DVD HD soundtrack are send to my receiver. The HD-A30 the output is only PCM but you don't loose from DD+ or DolbyTrue HD as the player can decode them and send them uncompressed through PCM 5.1.
robetclo2516 is offline
post #33 of 33 Old 11-29-2009, 11:28 AM
Jgatie's Avatar
You do realize this thread is almost 2 years old, right?
Jgatie is offline
Reply HD DVD Players
