Does your Blu-Ray player support bitsteam over HDMI and do you have it set to do so? Just to let you know Linear PCM is the better choice for HD audio over HDMI. You should be looking into making your Blu-Ray player output BD's over PCM instead of getting your HD-A30 to output HD DVD's over DD or DTS.
HDM doesn't use basic DTS or DD; I guess BDM does use "older" audio codecs. In any case since your receiver doesn't support the "newer" audio codes just let your A30 convert them to PCM to your HMDI receiver and your good to go.
If you ever plan to upgrade your receiver I would check out the Onkyo 705 or 805 that also supports HD-DTS MA decoding via HDMI, but you will need a HD DVD player like the A35 or XA2 to bitstream HD-DTS MA, since all other models will not.
I posted this in another thread. There is a bizarre connection in these players between audio and video settings. I am connected to a prepro via bitstream over the optical connection. When resolution is set to "up to 1080i" the player will output only Dolby 2.0, not Dolby 5.1. Changing resolution to "up to 1080p" enables the Dolby 5.1 output. Makes no sense, but that's the way it works.
"these Players"?? Which ones? What firmware? Sounds like the HDMI is set to Downmix the HDMI audio to 2.0, double check the HDMI Audio setting.
I have the A1 connected both Optical and Analog with 1080i video out on the HDMI and I never had the Optical playback audio at DD 2.0 on a HDM or DVD 5.1. Correction prior to firmware 2.0 on the X/A1 TrueHD was 2.0 but ever since firmware 2.0 and above it's been 5.1.
Kabillyhop - I have an A3 connected to my TV over HDMI at the up to 1080i resolution and audio over toslink to a non-HDMI receiver. It works just fine. I have set HDMI = Downmixed PCM and SPDIF = Bitstream. Of course, the A3 doesn't offer a 1080p option.
BIslander - I used to have an A3 and it worked exactly like you say. I exchanged it for an A30, same settings, and couldn't get the 5.1 to work until I changed the video resolution.
This setting is found in the back of the manual. If you choose anything less than 720P, the output will be only 2.0 for HD discs. It doesn't make sense but that's how its done. Why should video have any effect on audio.
I hadn't noticed that in the manual.. so I guess 1080i is considered as less than 720p. Agree with Angelo - despite the mention in the manual, this is a firmware bug.
It is in the back of the manual. On HD discs, if you choose 480P, 2 channel pcm is what will be outputted (sp?). Switch to 720P or 1080i and the higher codecs will be sent via pcm. Not a firmware bug but the way it is designed, why, I'm not sure. I guess they figure that if you bought HDDVD, you are going to output higher resolutions. I think it has something to do with downconverting the digital resolution.
Have you tried PCM over the optical? I have my A1 both coax and HDMI with the HDMI output set to auto. With a HDDVD it sends PCM to my pre-pro and either DD or DTS with a SD disc.
So if u have older rec that can only do DD (no DD+/DTS), u can't get DD w/ any current HD-DVD player via optical for HD-DVD discs playback. Is this correct?
Guys, I can confirm in order to hear the NEWER codecs it has to outputted thru HDMI.....WHY. Higher bit rates!!!!! I have both the A2 and A30. THe A30 is connected to the Yammy 3800 and decodes all the new codecs. What is funny is when I output thru HDMI/set at auto/ SPDIF @ Bitstream I will get only DD+ 2 channels...weird . When I reset the A30 for PCM it will do regular dolby only.
Do you have the A30 hooked up both optical an HDMI? If so, when playing back a HDDVD it may be getting the audio through the optical instead of the HDMI.
No, with HD DVD via optical you either get 1.5Mbs DTS (2nd gen. players) or 640k DD (3rd gen. players). So buy a 3rd generation player and you can use your DD only receiver.
Hi all. I am thinking about getting an HDA30 now. I have a Denon AVR3805, so if I hook it up with the tos-link will I still get DD 5.1 and DTS 5.1? I wanna make sure before I make my purchase.
From the A30 via optical, you will get standard DD/DTS from SD DVD, DD@640kbs from TrueHD/DD+ on HD DVD and DTS from DTS-HD/MA on HD DVD.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
