Firmware 2.0 for A3/A30/A35 out (dont update if you use 1080p24 it causes jaggies!) - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 700 Old 03-04-2008, 06:25 PM
joe221's Avatar
Quoted: 29 Post(s)
Originally Posted by Panny Man View Post
Sorry here is the link below
http://www.avsforum.com/avs-vb/showthread.php?t=999557
Thanks BTW, I was able to successfully go back to 1.3
Joe in West Los Angeles, CA
joe221 is offline
post #452 of 700 Old 03-05-2008, 08:02 AM
atlantaM3's Avatar
loaded 2.0 firmmware, now sound is very low compared to what I remember with 1.3. Has anyone else noticed this?
Does anyone have a link to the 1.3 version so I can replace it?
J
atlantaM3 is offline
post #453 of 700 Old 03-05-2008, 08:15 AM
shaft103's Avatar
Sorry if this has already been discussed in the thread, but is the 2.0 firmware any good for the A3? I know its a bad idea for the A30 & A35 if you use 1080/24 but are there any known issues with the A3?
Thanks for your help!
shaft103 is offline
post #454 of 700 Old 03-05-2008, 08:37 AM
Pointyskull's Avatar
I did the 2.0 update on my A3 this past weekend.
Hadn't been experiencing any problems up to that point.
Upgrade went fine.
Eamus Catuli!
Zerstörung durch Fortschritte der Technologie
Pointyskull is offline
post #455 of 700 Old 03-05-2008, 01:33 PM
Hankus's Avatar
Originally Posted by OhioLefty View Post
The AVR will not show the TrueHD lights unless you send your audio via Bitstream which the Toshiba A3 can not do. Something only the Toshiba XA2 and A35 can do (Onkyo 805 also). TrueHD on the A3 sent via HDMI to the AVR will be seen as MultiChannel.
I'm confused here. My D3 which is supposedly the same as the A3 and outputs Dolby TrueHD 5.1, just not through the HDMI connection. My AVR is a SONY STR-K900 which only does HDMI pass through, so I have to use the TOSLINK in this case which can be configured either Bitstream or PCM. I'm sure you can do the same with the Onkyo, can't you?
Hankus is offline
post #456 of 700 Old 03-05-2008, 01:38 PM
BasicBlak's Avatar
If you're using TOSLink, you're not outputting TrueHD--you're outputting standard Dolby Digital @ 640kbps (or 2-channel PCM if you choose). For the A3/D3/A20/A30, Dolby TrueHD is decoded internally and output as multi-channel PCM via HDMI only.
Panasonic PT-AX200U
Da-Lite Model B 106" HCMW
Sony KDS-60A3000
VIP 3D Theater Plus Converter w/ MonsterVision Max 3D Eyewear
Onkyo TX-SR805 (v1.08 w/DSP & HDMI Updates)
Oppo BDP-103
Sony PS3 Slim (v4.50)
Toshiba HD-A35 (v4.0)
Polk Audio RTi8 / CSi5 / FXi3
Boston 595x Subwoofers
My DVD Collection
BasicBlak is offline
post #457 of 700 Old 03-05-2008, 01:46 PM
Jgatie's Avatar
He's not talking about bitstreaming DD via optical, he's talking about bitstreaming HD audio (TrueHD/DD+/DTS-HD) via HDMI to an HDMI 1.3 capable receiver (like his Onkyo). Only the XA2 and A35 can bitstream HD audio.
Jgatie is offline
post #458 of 700 Old 03-05-2008, 03:55 PM
SLYDoggie's Avatar
Quoted: 42 Post(s)
I've been running on V2 on my A3 for a couple of weeks now with no issues. The good news is that I have not had a single lockup or freeze while watching a SD or HD movie since the update. I did my update via the Ethernet connection so it wouldn't have done the update if it wasn't specifically designed for the A3.
Regards, Steve
Projector/Receiver - Sony VPL-VW1100ES 4K PJ & Sony STR-ZA5000ES 4K Dolby Atmos AVR
Media Devices - Sony FMP-X10 4K Media Server, Samsung UBD-K8500 4K Blu-Ray, and Roku Ultra 4K Broadband
Screen - 145" Dragonfly, 1.2 Gain, 16:9, Matte White Fixed Screen
Theater Remote/Cables - Universal MX-890 RF Remote, Monoprice Certified 18Gb HDMI Cables
SLYDoggie is offline
post #459 of 700 Old 03-05-2008, 06:54 PM
bfocussvt's Avatar
Quoted: 16 Post(s)
Half true, he could output 2-channel TrueHD over TOSlink as the bandwith is almost equivalent to DD or DTS.
- Barry
bfocussvt is offline
post #460 of 700 Old 03-05-2008, 07:36 PM
BasicBlak's Avatar
No... High-res audio is not spec'd for S/PDIF. Via TOSLink (or coax), the best you can hope for is core DD640 and core DTS1.5. TrueHD, whether 5.1 or 2.0, can only be output on non-A35/-XA2 Toshibas as LPCM via HDMI/analog outs. Peruse the Dolby website, as it's pretty clear on this.
http://www.dolby.com/consumer/technology/trueHD.html
Panasonic PT-AX200U
Sony KDS-60A3000
Oppo BDP-103
My DVD Collection
post #461 of 700 Old 03-06-2008, 08:14 AM
spongebob's Avatar
Quoted: 38 Post(s)
On my A3, I got bad jaggies only @ 720P on Planet Earth HDDVD. 1.3 ad no issues. This was only @ 720P, 1080i ws ok.
bob
spongebob is offline
post #462 of 700 Old 03-06-2008, 08:15 AM
spongebob's Avatar
Quoted: 38 Post(s)
J
output? hdmi, toslink?
bob
post #463 of 700 Old 03-06-2008, 01:48 PM
Tag66's Avatar
Big thanks to whoever it was that modifed the A30 1.3 firmware and made it available for download! It worked like a charm in downgrading from 2.0.
Tag66 is offline
post #464 of 700 Old 03-06-2008, 04:42 PM
spongebob's Avatar
Quoted: 38 Post(s)
bob
also, check your audio settings. they default to auto level or........
bob
post #465 of 700 Old 03-10-2008, 12:55 AM
TheNinja's Avatar
I'm still a little confused after reading this thread.
I have a A30. I upgraded to FW 1.3. This unit is hooked up the highest end Vizio 47" LCD Full HDTV. It would primarily be used for upconverting player of Standard DVDs. Is my TV even capable of 24...the website doesn't say other than "Full HDTV at 1080p)? Should I bother to upgrade to 2.0? Would there be a noticable difference in SD upconvert quality?
TheNinja is offline
post #466 of 700 Old 03-10-2008, 11:26 PM
dooshorama's Avatar
if anyone is interested to get the original unmodified 1.3 firmware from toshiba, links:
A30: http://tacp.toshiba.com/tacpassets-i...-A30-1300U.zip
A35: http://tacp.toshiba.com/tacpassets-i...-A35-1300U.zip
A-3 : http://tacp.toshiba.com/tacpassets-i...D-A3-1300U.zip
i've verified these as of 3/11/08 1:25AM EDT.
note that to roll back from 2.0, you will need to perform the previously mentioned HEX mod yourself.
dooshorama is offline
post #467 of 700 Old 03-12-2008, 11:22 AM
cal87's Avatar
Quoted: 30 Post(s)
Liked: 29
I have had my A35 for about two weeks. I got it for the superior 1080p24 output. It came with firmware 1.3, and obviously I do not want to update to 2.0
I have had two instances of the picture freezing - once at the end of Transformers, once in the middle of 300. The picture would momentarily freeze, then would restart with the audio out of sync. A simple pause and play would get everything back to normal. Have not been able to reproduce it or see it on any other occasion.
Has any one had this type of problem, and have had it corrected with firmware 2.0?
I want to know if there is hope for a future firmware with proper 1080p24 and no freezing. Still trying to decide whether to keep the A35 or Onkyo for my main system.
cal87 is online now
post #468 of 700 Old 03-12-2008, 11:45 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Originally Posted by cal87 View Post
Has any one had this type of problem...
Yes. I've had hang-up problems with the A30, and FW version 1.3. It's happened with four out of about 16 Netflix rentals. In our case there was a complete lock up. The last two times it happened I restarted the HD DVD disks with the A30 set to output 1080i instead of 1080p@24Hz. In both cases the movie played through the "bad" spot without a problem. I've never had a problem with the few new HD DVDs that we've watched.
htwaits is online now
post #469 of 700 Old 03-12-2008, 11:18 PM
rider45's Avatar
Does anybody know if "ENEMY AT THE GATES" works yet on a A-3 with this fw update?
Thx
rider45 is offline
post #470 of 700 Old 03-13-2008, 01:40 AM
iamian's Avatar
Quoted: 49 Post(s)
Liked: 41
Couldn't playback Bullitt rented from BB, says it's not a DVD.
iamian is online now
post #471 of 700 Old 03-13-2008, 10:12 AM
Rowan's Avatar
Are your sure its not the Blu-ray version? That DVD comes in all three flavors.
Rowan is offline
post #472 of 700 Old 03-13-2008, 10:17 AM
iamian's Avatar
Quoted: 49 Post(s)
Liked: 41
Yes, and I washed & loaded, player locked up on loading and I had to unplug it.
post #473 of 700 Old 03-13-2008, 11:04 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
We got the HD-DVD version of Bullitt from Netflix yesterday. I just tried the first two chapters, and Bullitt played on our A30 outputing 1080p@24Hz with DD+ audio.
post #474 of 700 Old 03-13-2008, 12:15 PM
Claw97000's Avatar
Thx
No, it doesnt.
Claw97000 is offline
post #475 of 700 Old 03-13-2008, 12:19 PM
corwiniii's Avatar
I got that message 50% of the time with Netflix HD-DVDs on my A35. Luckily many were combos, but some were not. SD always played fine.
corwiniii is offline
post #476 of 700 Old 03-13-2008, 12:55 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
The next time that happens try setting the A35 to 1080i. I've done that twice and both times there was no hang up at the bad spot.
post #477 of 700 Old 03-13-2008, 01:29 PM
corwiniii's Avatar
In all my cases the bad spot was loading the disc! But, I'll give that a try, although I don't know when I'll ever get another Netflix HD-DVD.
post #478 of 700 Old 03-13-2008, 06:41 PM
5harkology's Avatar
Thx
It won't play on my A30
5harkology is offline
post #479 of 700 Old 03-14-2008, 09:14 AM
pteittinen's Avatar
Originally Posted by aaronwt View Post
I uploaded the A30 and A35 firmware that I downloaded from the links in this thread. So it's at the following link along with the XA2 firmware.
Thank you very much for this.
I won't pay a cent for UHD Blu-rays made from 2K masters by upscaling.
pteittinen is offline
post #480 of 700 Old 03-14-2008, 11:12 PM
Tycoonbrad's Avatar
Is there going to be any new firmware updates to HD-Players in the future or are we stuck with 2.0?
Tycoonbrad is offline
Reply HD DVD Players
