Firmware 2.0 for A3/A30/A35 out (dont update if you use 1080p24 it causes jaggies!) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 700 Old 02-12-2008, 08:41 AM - Thread Starter
sudetta's Avatar
http://tacp.toshiba.com/tacpassets-i...ngfirmware.asp
WARNING: This update ads jaggies on MPEG4/AVC discs like 2.8 did on the XA2. Do not upgrade if you use 10080p24!!!
sudetta is offline
post #2 of 700 Old 02-12-2008, 08:49 AM
dmcfan's Avatar
Just went to Toshibas site and it isn't there and this link doesn't state what file this is for. I would not trust this link.
dmcfan is offline
post #3 of 700 Old 02-12-2008, 08:50 AM
Super_Coo's Avatar
I just used that link and it works for me... what's the updates?
Here I was waiting for 1.4 and 2.0 comes out?
HD DVD - 10
BLU-RAY - 3
Super_Coo is offline
post #4 of 700 Old 02-12-2008, 08:51 AM
Jon Spackman's Avatar
Cool. wonder what it does??
Just enjoy HD in whatever form you can (Sat, Cable, D-VHS, OTA, HD DVD, or BD).
Jon Spackman is offline
post #5 of 700 Old 02-12-2008, 08:51 AM
BGLeduc's Avatar
Quoted: 1682 Post(s)
Liked: 1539
Link worked fine from here. And the download does appear to be 2.0.
That said, I am not finding any mention of what it does, not that those lists are usually very informative.
Brian
#JB17
BGLeduc is online now
post #6 of 700 Old 02-12-2008, 08:54 AM
BluLover's Avatar
The link works. You just have to check the box that says "I agree to the terms and conditions contained in the Master End User License Agreement above" before you can download.
BluLover is offline
post #7 of 700 Old 02-12-2008, 08:57 AM
Super_Coo's Avatar
I just downloaded it but I'm at work... no readme in the zip file so I have no clue what it does. All I know is that I have never had a problem watching HD DVD's on my A3 yet I'm still scared everytime I watch a movie after reading all of the messages of people having so many errors... hopefully this will be a good fix for everyone!
HD DVD - 10
BLU-RAY - 3
post #8 of 700 Old 02-12-2008, 09:05 AM
jdelatl's Avatar
i read it here so decided to turn on the player and download the new firmware. It's definitely doing it so we'll see what all it does
jdelatl is offline
post #9 of 700 Old 02-12-2008, 09:09 AM
roboconnell's Avatar
yes please tell us what it does.
My low-ball hope: make the eject button work faster than 15 seconds on my A3!!
roboconnell is offline
post #10 of 700 Old 02-12-2008, 09:17 AM
mosman22's Avatar
I am a little confused. I just went into my A35 setup and choose update. Under update it said 1.3/1.1. I already have 1.3 yet is it downloading the 39 steps. Is it possible i am just redoing the 1.3 fw or does the fact that it is downloading mean it is an updated fw 2.0 not the same i have already.
mosman22 is offline
post #11 of 700 Old 02-12-2008, 09:22 AM - Thread Starter
sudetta's Avatar
It tells you what version is allready installed. So now you're updating to 2.0
sudetta is offline
post #12 of 700 Old 02-12-2008, 09:25 AM
mosman22's Avatar
Nice, that is what i assumed. I can't wait to test this thing out. Many A35 owners are have having handshakes issues with HBR and the tech i talked to a couple months age said Tosh was working on a fix and it should be included in the next fw update. I really hope it is.
mosman22 is offline
post #13 of 700 Old 02-12-2008, 09:30 AM
wildchild22's Avatar
Quoted: 29 Post(s)
I just received my a35 downloaded and installed 2.0 and I cant get 24hz playback
wildchild22 is offline
post #14 of 700 Old 02-12-2008, 09:37 AM
jdrouette's Avatar
Just installed 2.0. It adds a menu in Video called "Frame Rate", from which you can select "Auto" or "24 FPS". Great!
Unfortunately, it still does not work with my Samsung T6187s. Even after re-initializing the player, setting to 24 FPS, my TV only displays 1920x1080 60hz when it displays 24hz from my PS3. Weird.
It also hasn't fixed the problem I had playing my French "Pan's Labyrinth" which plays fine on my A2.
What a tease this firmware was.
jd
jdrouette is offline
post #15 of 700 Old 02-12-2008, 09:44 AM
Hi jd - with the player off, how long after pressing eject does the tray open?
I'm hoping as a bare minimum this has been made faster...
have you noticed any other effects?
post #16 of 700 Old 02-12-2008, 09:49 AM
latinrage69's Avatar
the new firmware provides 1080/24p, improved network connnectivity, improvements to hdmi/hdcp issues, and supposedly fixes the pixelization problems during playback.
here's a link
just click support on the top and then firmware 2.0 update on the left of the page.
latinrage69 is offline
post #17 of 700 Old 02-12-2008, 10:02 AM
CalgaryCowboy's Avatar
Just updated. So is this forced 24? I don't have a tv that does that now but being able to force 24 gives me option on a new PJ without worrying about a proper HDMI handshake.
My review comparisons of Energy RC-70s to Veritas V6.3 http://www.avsforum.com/avs-vb/showt...8#post21199418
CalgaryCowboy is offline
post #18 of 700 Old 02-12-2008, 10:02 AM
jdrouette's Avatar
I count 35 seconds from pressing "on" to the tray opening.
Otherwise, I found no other changes or improvements in the few spot checks I've made since updating.
jd
post #19 of 700 Old 02-12-2008, 10:03 AM
mpotturi's Avatar
jd
It sounds like a problem with your Samsung T6187. My pioneer TV say 1024p when it plays 1024p/24Hz from A35 (fw 1.3). My pioneer TV is actually 720p with a capability to accept 1024p/24Hz. It plays beutifully.
mpotturi is offline
post #20 of 700 Old 02-12-2008, 10:08 AM
jdrouette's Avatar
I know some TVs require "forced" 24 fps playback, as mine does. If I force 24 fps from the PS3 I get 24hz, if I set to "auto", I get 60hz. However, even setting the A35 to "forced" 24 fps gets me 60hz. Clearly, the TV does 24hz with at least one player, so I can only assume it's dependent on the player.
For the record, the HD DVDs I've tested are Superman Returns and Eyes Wide Shut. I also tried one DVD; Tess. All show up as 60hz.
post #21 of 700 Old 02-12-2008, 10:14 AM
tonngo0's Avatar
Still looking for firmware to make this a region free player for DVD.
tonngo0 is offline
post #22 of 700 Old 02-12-2008, 10:21 AM
jorgerod's Avatar
Time to replace the Sticky Thread !!!!!!
Jorge
Audio Enthusiast, HD Videophile.
jorgerod is offline
post #23 of 700 Old 02-12-2008, 10:23 AM
akadennis's Avatar
glad 2 see we are still getting fw updates considering the current state of HDDVD. i will be downloading this when i get home :-)
akadennis is online now
post #24 of 700 Old 02-12-2008, 10:28 AM
moviegeek's Avatar
It allows you to play Blu Ray 2.0.
moviegeek is offline
post #25 of 700 Old 02-12-2008, 10:29 AM
applejackaz's Avatar
Good news for me! The A35 now plays BBC Die Fledermaus.
applejackaz is offline
post #26 of 700 Old 02-12-2008, 11:11 AM
Gary Murrell's Avatar
-Gary
Gary Murrell is offline
post #27 of 700 Old 02-12-2008, 11:43 AM
Jgatie's Avatar
Gee, that would be the first true 2.0 player available. Who'da thunk it?
Jgatie is offline
post #28 of 700 Old 02-12-2008, 11:50 AM
jzoz01's Avatar
My player is downloading right now! I wonder what updates will be for the A3, since it doesn't support 1080p24.
jzoz01 is offline
post #29 of 700 Old 02-12-2008, 11:56 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 321 Post(s)
Liked: 6089
As usual, "if it ain't broke, don't fix it" may apply. There's usually somebody or two that ends up with a "brick".
larry
Eu estou aqui e você é meu sofá
PooperScooper is offline
post #30 of 700 Old 02-12-2008, 12:23 PM
joemama127's Avatar
larry
Exactly...my A30 has been flawless with the preloaded 1.3 since the day I got it a month ago. Being in the computer hardware business I have learned not to provoke the hardware gods unless you really need to.
"The quickest way to get over your fear of plasma is to actually own *one"- joemama127
*or 3 :)
joemama127 is offline
Reply HD DVD Players
