HD-DVD Firmware links for all models - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 10-16-2008, 12:29 PM
HDKing's Avatar
How come I can't download any of these updates? When the downloads are done, the WinRAR says that it is damaged or corrupt.
HDKing is offline
Old 10-20-2008, 01:39 PM
DanO9ers's Avatar
Hi everyone. If you'd like to get rid of your onkyo hd805 please dropp me a line. thanks
DanO9ers is offline
Old 11-05-2008, 05:19 AM
DUCeditor's Avatar
To my surprise I received a disc in the mail yesterday with 4.0 for my A35. It is certainly to Toshiba's credit that they are still publishing updates ands (supposed) improvements for a now defunct product. But...
Has anyone loaded it? I've never updated the firmware for either of my players (other is an A3) because they seem to work fine as is in my system (no 1080P available, component only) and because so many problems have been reported following installation of later versions.
Thoughts? Experiences?
-don
DUCeditor is offline
Old 11-05-2008, 11:51 AM
Tedd's Avatar
Quoted: 1021 Post(s)
Liked: 377
And yet I have owned 6 HD DVD players (an A1, an XA2, an A30 and currently have 3 A35s) and have yet to ever receive a single upgrade disk.....
Tedd is offline
Old 11-13-2008, 09:23 PM
jdastas's Avatar
anyone know how to burn this using a mac... I don't know how to make an ISO disk,
jdastas is offline
Old 11-14-2008, 10:09 AM
Tom Thomas's Avatar
I made a copy of the steps from an earlier post and copied them below:
How to burn ISO disc images
Thu, Jun 22 '06 at 7:30AM PDT
Submitted by vocaro
Disc images are a fairly common packaging standard for large software programs. If you want to try out a new Linux distribution, for example, chances are you'll need to download a disc image in ISO format and burn it to a blank CD-ROM or DVD.
But ever since I began using Mac OS X, I've been perpetually confused about how to burn ISO images. I'm used to disc burning utilities that have an obvious, explicit command like "Burn ISO Image to CD." To make life even more confusing, OS X's Disk Utility does have a Burn command, but it becomes disabled when you click on the blank disc you'd like to use for the burn.
The problem here is that most Mac disc utilities, including the built-in Disk Utility, take a different approach when it comes to image burning. Instead of telling the program you want to burn an image, then choosing the file, you're supposed to do the reverse: You choose the file, then tell the program you want to burn it. So, to burn an ISO image to disc, here's what to do:
1. Insert a blank disc.
2. Start Disk Utility. (Applications/Utilities/Disk Utility)
3. From the File menu, choose Open Disk Image and select the ISO to be burned.
4. In the list of volumes, you will now see an item representing the ISO file. Select it.
5. Click the Burn button and follow the instructions.
To reinitialize the player
1. Update FW to 2.2
2. Clear Persistent Storage
3. Shutdown player
4. Unplug player
5. Press power on player (yes, AFTER unplugging)
6. Wait for about 1 minute
7. Re-plug power
8. Restart player and play the disc.
Tom Thomas is online now
Old 11-14-2008, 09:16 PM
jdastas's Avatar
Submitted by vocaro
1. Update FW to 2.2
3. Shutdown player
4. Unplug player
7. Re-plug power
Thank you much... worked perfectly!
jdastas is offline
Old 11-17-2008, 10:02 AM
Tom Thomas's Avatar
Glad it worked for you, I've been burning discs using these instructions from vacaro for several versions and it has always worked for me.
Old 11-18-2008, 08:50 PM
brokencosmos's Avatar
Hi Everyone,
I recently purchased some UK Region 2 Pal DVD's to play on my Toshiba HD-A2. I tried downgrading the firmware and then turning it into an HD-E1. Everything worked like it was supposed to, except that I wasn't getting an image, but was getting sound. Long story short, I ended up buying one of the cheap Philips region-free dvd players, and it works like a champ. I now want to turn my HD-E1 back into the original HD-A2 firmware, does anyone know if someone has written the HD-E1 to HD-A2 switch? I have tried searching through the various forums to no avail, and thought I'd try it out here, thanks for all of your help!
brokencosmos is offline
Old 11-22-2008, 04:53 PM
N8YWF's Avatar
Originally Posted by brokencosmos View Post
Hi Everyone,
Why not just leave it as is? It defaults to PAL when first turned on but it will still play any NTSC DVD (R1, R2 Japan & R3) you put in it no matter what region is. In the future maybe you will get a new TV that supports PAL.
The only pain in the butt is that you have to tap in the RCE fix on your remote when you want to play a RCE disc. Other than that you have a sweet region free player.
N8YWF is offline
Old 11-22-2008, 09:05 PM
bebop86's Avatar
On the mac- every time it downloads I get a "mounting failed"- and when i burn it I get an error message when I try to run it on the xa-2- How do you get it to not mount-?? thanks
bebop86 is offline
Old 11-25-2008, 02:08 PM
ggw2000's Avatar
Quoted: 540 Post(s)
Liked: 207
I have an RCA 5000 which I found out today that RCA doesn't support anymore (aholes). The problem is that I bought a new Mits DLP tv this past week and the RCA will not handshake with the set. I figured I would update the F/W and get on with life- but no.
I read at the beginning of this thread that the A1 F/W is essentially the same. I downloaded the latest (V4) zip file from the link provided. I unzipped it and tried to burn the .iso file as an image to a cd-r using roxio v9. But I keep getting an error that says there's a problem with px.dll, pxafs.dll, etc..
Can someone tell me what I'm doing wrong? I just updated my Sony BD player the other day w/o problem..
Thanks, Gerry
Sony XBR 75X850C - Marantz NR1501 AVR - Philips BDP-7501 UHD BD Player - ShieldTV Gen 2
ggw2000 is offline
Old 11-26-2008, 04:20 PM
flyersfan's Avatar
I've avoided Roxio software for years but can recommend ImgBurn. It's freeware and should burn an .iso image flawlessly.
flyersfan is offline
Old 02-05-2009, 04:04 AM
Emaych's Avatar
Quoted: 455 Post(s)
Liked: 187
So I have an HD-A1 and want to update the firmware. How to go about this? -- I see the modem port on the back and have found the UPDATE part of the menu and know the updates exist online...now how do I bring these all together?
Emaych is offline
Old 02-05-2009, 10:28 AM
Emaych's Avatar
Quoted: 455 Post(s)
Liked: 187
Thanks to all the members that helped. I called for the update CD this morning, so my fingers are crossed that all goes well and it does not destroy the functionality I now have!
Emaych is offline
Old 02-05-2009, 01:23 PM
Chingu808's Avatar
Quoted: 42 Post(s)
Thinking about picking up a Toshiba Model HD-A3KU from someone for a cheap price. I already have the HD-A2 4.0 firmware disc. Can this firmware disc also be used on the Toshiba Model HD-A3KU? I know stupid question.
Chingu808 is offline
Old 02-05-2009, 05:57 PM
sonydude1966's Avatar
Quoted: 14 Post(s)
That's a no.
sonydude1966 is offline
Old 03-30-2009, 12:59 AM
rokki's Avatar
Quoted: 13 Post(s)
Hi a have a preowned HD-E1 and heard about the upgraded 4.0 firmware and did that and have found out that it didn't make it region free the player i have is a New Zealand one.Is it possible to go backwards to the region free 2.5 software ? And how on earth would you do it .I also read that someone got his HD-E1 to output in 1080p 24 is this possible and again how on earth would i do it ? I have basic computer skills .Any help advice is greatly accepted.
rokki is offline
Old 03-30-2009, 03:32 AM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
http://cid-6948f2460bdd190c.skydrive...TY%20Australia
Will run on any current firmware. No need to revert to version 2.5 first. Re-apply version 4.0 afterwards.
Viking61 is offline
Old 04-01-2009, 02:37 AM
rokki's Avatar
Quoted: 13 Post(s)
Hi thank you so much worked like a charm.
rokki is offline
Old 04-01-2009, 04:08 AM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
Your player is now regionfree. Just be aware that some NTSC region 1 discs are in addition encoded with something called RCE. You will then have to enter the RCE hack which is:
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and 1
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
When player is turned off, this setting is cleared.
Viking61 is offline
Old 06-18-2009, 05:40 AM
MTAtech's Avatar
Quoted: 14 Post(s)
Does anyone know what issues the 4.0 firmware fixes? The Toshiba description is vague. I've got an HD-A30 and am wondering if they made changes to the audio area.
Also, some people seem to have trouble with the 4.0 update. Is that a fluke or is the 4.0 not really recommended?
MTAtech is offline
Old 06-22-2009, 05:48 AM
jasonone's Avatar
I trust Toshiba when it comes to laptops. The durability is unquestionable.
Do you have the quickest link for all of the firmwares?
"A successful marriage requires falling in love many times, always with the same person."- wedding wedding songs-
jasonone is offline
Old 06-22-2009, 05:59 AM
MTAtech's Avatar
Quoted: 14 Post(s)
View the first post in this thread.
MTAtech is offline
Old 06-22-2009, 06:04 AM
MTAtech's Avatar
Quoted: 14 Post(s)
I installed the v4 firmware on one of my HD-A30s over the weekend. I was hoping that it would fix the freezing that I was getting on the third disk of Battle Star Galactica, Season 1, but it did not. It's odd, because the disk is pristine condition with no scratches or smudges.
I'm going to test the disk on my other A30 when I get a chance to determine whether it's the player or the disk.
MTAtech is offline
Old 06-22-2009, 10:29 AM
Quentin2's Avatar
Quoted: 82 Post(s)
Liked: 33
MTAtech, I suspect it's the disc even though it appears pristine. I've had this happen with a handful of new discs and both of my A30s had trouble with these discs but not others. At the time I had firmware 1.1 and 1.3 on these units. Upgrading to 4.0 seemed to help a little but still problems. Overall 4.0 made both players work smoother and I'm glad I upgraded them but it doesn't help with disc problems a whole lot.
Anyway, I tried a recommendation in another thread of washing the disc and to my amazement it usually works. Just wash gently with a non filming detergent and rinse under very warm running tap water. Not saying this will cure every disc read problem but it's been extremely effective for me. There seems to be an invisible film on some factory fresh discs that a little soap will clean off.
2014 Samsung PN64H5000 Plasma Thread
2008 Samsung HLxxA650 DLP Thread/FAQ
Free Men Do Not Ask Permission to Bear Arms
Quentin2 is offline
Old 06-22-2009, 11:36 AM
MTAtech's Avatar
Quoted: 14 Post(s)
I'll try that Quenin. Can't hurt.
MTAtech is offline
Old 06-22-2009, 06:55 PM
Quentin2's Avatar
Quoted: 82 Post(s)
Liked: 33
Let us know if it helps, I think it will.
Quentin2 is offline
Old 06-22-2009, 07:35 PM
Chris Gerhard's Avatar
That is a known defective disc, apparently only the early pressings. I notified Universal and was instructed to return mine but unfortunately Universal was out of HD DVD replacements and I accepted the DVD set.
Chris
Chris Gerhard is offline
Old 06-23-2009, 06:17 AM
MTAtech's Avatar
Quoted: 14 Post(s)
Chris
Of course, I could just buy a new HD-DVD set for under ~$10. Or better, buy a new one for ~$10, exchange the old one with Columbia for a new std DVD and sell that one on Ebay or Amazon for ~$25.
MTAtech is offline
