Case turning cover art pink or red? - AVS Forum | Home Theater Discussions And Reviews
Old 05-30-2010, 05:40 PM - Thread Starter
Brian81's Avatar
Has anyone else had issues with the coverarts turning red from the cases bleeding red into them?
I haven't noticed it on any of the thick stocked Universal inserts but I've had my Transformers (Paramount), Reservoir Dogs (Dutch Filmworks), and King of California (First Look) turn pink from the case. I don't know if these were bad cases and swapping them out will stop it from getting worse, or if the paper they are using is reacting to the case and it doesn't matter if I switch the case to another of the same type of case.
I think if I could go back, I'd put a separate piece of paper behind the insert and the red plastic of the case.
Brian81 is offline
Old 05-31-2010, 08:46 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Yes-I noticed this on several titles a long time ago.
I used to bother me, but not anymore since theres not much I can do about it.
qz3fwd is offline
