Brothers Grimm - Spanish Edition - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-25-2010, 04:34 AM - Thread Starter
whatisk's Avatar
I'm hoping someone here can help me out as I've drawn a total blank.
In relation to the Spanish HD-DVD of Brother's Grimm, I'm sure there was a way to turn off the Spanish subtitles while having the English dialogue.
I'm hoping someone with the disc could remind me of the trick, or confirm that I am mistaken.
Cheers.
whatisk is offline
post #2 of 4 Old 07-25-2010, 08:37 PM
bruceames's Avatar
Quoted: 521 Post(s)
Liked: 352
Cheers.
While the movie is playing, push the subtitle button on your remote and then the right direction arrow. That will turn them off.
bruceames is offline
post #3 of 4 Old 07-27-2010, 11:18 PM
sjitalian's Avatar
Cheers.
i have the spanish version hd-dvd of underworld evolution and you have to let the movie start then bounce back to the beginning and pause movie then go to menu to shut off subs.doing it the easy way with this disc doesnt work.hopefully with bro.grimm you wont have to.if you go to exploited cinemas website and find the underworld spanish release there are instructions on how to get rid of forced subtitles fot that disc.if it comes to it this may also work for your disc.good luck.
sjitalian is offline
post #4 of 4 Old 07-28-2010, 07:43 AM
bruceames's Avatar
Quoted: 521 Post(s)
Liked: 352
Like I said, no need for tricks with Brothers Grimm Spanish. I tested it myself before typing in my previous response.
Reply HD DVD Software
