order of the phoenix hd dvd audio quality - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-26-2010, 04:51 PM - Thread Starter
Lkr
Lkr's Avatar
I was watching Harry Potter and the Order of the Phoenix on HD DVD last night with my 360 drive. I set the audio to TrueHD even though it only outputs at DD 5.1 on the 360. I didn't notice a difference between that and normal DD 5.1 while watching. However, the center channel seemed to be VERY quiet. Is this a problem with the disc or is the 360 via optical not as good as outputting audio as say a PS3 while watching The Dark Knight in comparison? My sound system was at volume level 13 for TDK the whole time, where for Harry Potter, I would have to set it to 30 to hear dialogue fine, and then turn it back down to 23 because it was too loud for everything else.
Lkr is offline
post #2 of 5 Old 11-27-2010, 03:51 PM
Hector.B's Avatar
My HD-DVD sounds perfect via my toshiba A35. Amazing dolby trueHD soundtrack.
Hector.B is offline
post #3 of 5 Old 11-27-2010, 05:25 PM - Thread Starter
Lkr
Lkr's Avatar
I think it may be that the 360 is only outputting at DD 5.1 over optical and it is compressed. But for whatever reason, uncompressed audio that is decoded on the PS3 and then passed on as LPCM works fine on the center channel for me as 5.1. Not a big loss for me as I only own 5 HD DVDs, I'll try another one next time though and see if I have the same issue.
Lkr is offline
post #4 of 5 Old 11-28-2010, 09:30 AM
Hector.B's Avatar
Definitely ditch the xbox 360 drive...get an a30 its the only one thats affordable for now...the quality is a huge leap above the xbox
Hector.B is offline
post #5 of 5 Old 11-28-2010, 04:27 PM
ti-triodes's Avatar
Quoted: 349 Post(s)
Liked: 495
Sounded great on my XA2.
ti-triodes is offline
Reply HD DVD Software
