What software/program for HD-DVD backup? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By fastman
post #1 of 18 Old 01-19-2012, 02:17 AM - Thread Starter
fastman's Avatar
I have a XBox external HD-DVD player and a few HD-DVD's.
I would like to back these up to Blu-Ray.
Questions if I may.
1) Can this be done with this player?
2) If so, what software can I use?
I did some searches and came up with nothing, but I remember it was being done no?
I need someone with a better memory then mine
Thanks in advance
fastman is offline
post #2 of 18 Old 01-19-2012, 04:36 AM
junglalien's Avatar
junglalien is offline
post #3 of 18 Old 01-19-2012, 05:11 PM - Thread Starter
fastman's Avatar
I will check those out, thanks.
fastman is offline
post #4 of 18 Old 01-19-2012, 06:30 PM
champer's Avatar
I still have the HDVD external drive as well for the 360. What software do you recomend downloading for windows 7 to recognize the drive to play them off the PC.
SONY 32XBR6
SAMSUNG 46C6500
BD 40
HD DVD 28
champer is offline
post #5 of 18 Old 01-20-2012, 05:33 AM
junglalien's Avatar
http://www.arcsoft.com/totalmedia-theatre/
post #6 of 18 Old 01-22-2012, 12:06 PM
bruceames's Avatar
Quoted: 521 Post(s)
Liked: 352
Thanks Junglalien. That program works perfectly.
bruceames is offline
post #7 of 18 Old 02-14-2012, 08:51 AM
adydula's Avatar
Hello, I was wondering rather than use dumphd and clownhd ...can you just an HD dvd to an iso file with anydvd hd and find a player that would play this iso and be able to select the DTS hd audio etc???/
Anyone do this yet?
Alex
adydula is offline
post #8 of 18 Old 03-12-2012, 06:02 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Adydula, tmt5 with a virtual drive.
MovieSwede is offline
post #9 of 18 Old 03-12-2012, 07:27 AM
Donnacha's Avatar
TMT5 plays HD DVDs for me (with HD audio bitstreaming) nicely on Windows 7
Donnacha is offline
post #10 of 18 Old 03-30-2012, 09:11 AM
stockwiz's Avatar
makemkv to just unload them to the drive where they will remain... now do I have to keep these discs as 'proof of purchase' ... I'd rather just throw the cases away maybe put the discs on a spindle with my blank DVDs.
stockwiz is offline
post #11 of 18 Old 06-28-2012, 02:48 AM
Flybear's Avatar
Questions if I may.
Thanks in advance
To backup my DVD fles. i will use this program: http://mac.softpedia.com/get/Video/Enolsoft-DVD-Ripper.shtml
Flybear is offline
post #12 of 18 Old 09-07-2012, 11:05 AM
iontyre's Avatar
Originally Posted by G-telware View Post
What actuallu tmt 5 is ?
GMATE | GMATE Plus
Total Media Theater version 5
Proud Galactic Imperialist
iontyre is offline
post #13 of 18 Old 08-06-2014, 01:46 PM - Thread Starter
fastman's Avatar
LOL, this post is 2 yrs old. I recently moved and threw out the HD-DVD player, but thanks.
Ph8te likes this.
fastman is offline
post #14 of 18 Old 01-05-2015, 11:32 PM
DavidEC's Avatar
I don't know if I need to post here or in the hardware forum..
But with WalMart/VUDU/Flixster Disc-2-Digital programs..
If I connect one of the XBox HD-DVD drives to my computer will the "D2D Software" see my HD-DVD's and allow me to convert them to UltraViolet/VUDU cloud stored movies?
]I know that I can take a hand full to my local Wal-Mart with a list and they just work off the list and convert them (if they are in the ''CLOUD'' interstructure)[
avid
DavidEC is offline
post #15 of 18 Old 01-22-2015, 02:37 PM
djos's Avatar
Quoted: 28 Post(s)
Liked: 24
Hi Folks, I know this thread is a bit ancient but is there any 1 stop solution for backing up HD-DVD's 1:1 to MKV (properly) yet?
I've tried MakeMKV and it's sooooooo close to being perfect except for 1 major show stopper, it leaves the 3:2 pulldown flags intact and there is no option to remove them - I've got over 80 movies to archive to my server and I just dont need any extra steps.
The impossible often has a kind of integrity which the merely improbable lacks.
djos is offline
post #16 of 18 Old 02-03-2015, 03:18 AM
djos's Avatar
Quoted: 28 Post(s)
Liked: 24
Thanks I'll give that a go.
Does it need anyDVD hd installed or does it do its own decryption?
djos is offline
post #17 of 18 Old 02-15-2015, 03:54 AM
djos's Avatar
Quoted: 28 Post(s)
Liked: 24
So clearly that guy was a spammer and his post was removed (software had nothing too do with hddvd backup or anything remotely similar).
Anyone else know an alternative to makemkv or even an easy to use tool to remove 3:2 pull-down flags from hddvd rips?
djos is offline
post #18 of 18 Old 07-26-2015, 09:52 AM
tomtastic's Avatar
Quoted: 702 Post(s)
Liked: 225
Run your raw file thru handbrake and it will remove flag.
This line intentionally left blank.
tomtastic is online now
Reply HD DVD Software
