Convert HD-DVD to digital - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 05-05-2012, 06:30 PM - Thread Starter
jmauld's Avatar
Is there a simple way to convert my HD-DVD collection to a digital format?
I have a Xbox hddvd player that I can use to read the discs with my pc, but I haven't found any software that I'm positive will rip the discs?
jmauld is offline
post #2 of 23 Old 05-05-2012, 10:45 PM
junglalien's Avatar
AnyDVD HD
junglalien is offline
post #3 of 23 Old 05-06-2012, 12:19 PM
Rich86's Avatar
Quoted: 134 Post(s)
Liked: 67
DVDFab Passkey (lite version is free).
Clown-BD to process (also free).
A long-time audio/video addict!
Rich86 is offline
post #4 of 23 Old 05-07-2012, 06:27 AM
bruceames's Avatar
Quoted: 524 Post(s)
Liked: 358
If you're looking for simple, AnyDVD HD is as simple as it gets.
bruceames is offline
post #5 of 23 Old 05-07-2012, 05:24 PM - Thread Starter
jmauld's Avatar
I was able to use AnyDVD HD to remove the protection, and create a .iso file.
It looks like the movie is split into two separate files. I don't care about the menus. What can I use to join those two files and create a single .mkv file?
jmauld is offline
post #6 of 23 Old 05-07-2012, 08:56 PM
junglalien's Avatar
It should have been 1 file and why do you want to make .mkv?
post #7 of 23 Old 05-08-2012, 05:56 AM - Thread Starter
jmauld's Avatar
Any idea why it came up as two files? It is split into two files on the disc as well.
I just picked MKV because it is supported by my Blu-Ray player. My intentions are to rip these and play them from a NAS. Is there a better format that I should be using?
Also, someone pointed me to use MakeMKV. That seems to work well, and doesn't appear to require any other software. Unless AnyDVD HD is working completely in the background, which I don't think it was because I didn't get the 20 day warning.
jmauld is offline
post #8 of 23 Old 05-08-2012, 08:34 AM
bruceames's Avatar
Quoted: 524 Post(s)
Liked: 358
I believe it's split into 2 files because there are 2 layers on the disc. I've noticed that there are (nearly) always 1 file on single layer discs and 2 files on dual layers discs.
If you want to convert to something that'll play on a Blu-ray player, then check out this thread.
http://www.avsforum.com/avs-vb/showthread.php?t=1354525
post #9 of 23 Old 05-08-2012, 01:01 PM
Rich86's Avatar
Quoted: 134 Post(s)
Liked: 67
HD-DVD typically has 2 .evo files for the main feature, as I recall (feature_1 & feature_2). I do not believe AnyDVDHD will convert anything - so you get what was on the source disc decrypted. If you want to make a BD, MKV, DVD, etc. from your hd-dvd you need something else in addition to AnyDVDHD or DVDFab Passkey. I used DVDFab Passkey and Clown-BD when I experimented with this process. DVDFab Passkey had a bug in it at the time - since fixed. I used AnyDVDHD as a test. It worked fine. See link below for comments & notes.
look here . . . http://forum.doom9.org/showthread.php?t=134227&page=19
Rich86 is offline
post #10 of 23 Old 05-08-2012, 01:34 PM
Canuck-eh!'s Avatar
Posted previously in the HD DVD Players section
It takes apporx. 2 hours per title from beginning to end. I use a 5-year old Dell dual-core based computer, XP, 4Gb memory, 2Tb secondary installed HDD for the process. Software installed includes AnyDVDhd from SlySoft, ClownBD (full install including tsMuxeR, eac3to, BDSup2Sub, ImgBurn, Java runtime). Go to www.mediasmartserver.net/wiki/index.php/Clown_BD for a tutorial on how to run ClownBD. I follow all the steps with the following exceptions: I deselect 'Use ImgBurn' on the main screen, on "eac3to 3rd Pass" screen I deselect ALL subtitles, select only 1 audio type and channels, select "Movie Output Format" as Blu-ray. At that point once you select next, it will take a long time to convrt (up to 1.5 hours). When complete, I navigate to the Clown_BD folder created and navigate to the BDMV/stream to see the size of the stream file.
The reason I deselect ALL subtitles, etc. is to get a perfect copy of the movie that will fit on the BD-R. In most cases, the extras, etc. are really not necessary. I have done this for 30+ movies so far, not counting the ones that are > 25 Gb. I'll watch for bargain deals on the others down the road.
Canuck-eh! is offline
post #11 of 23 Old 05-09-2012, 08:15 AM
SergeMonrois's Avatar
HD DVDs are dead. Why do you need this?
SergeMonrois is offline
post #12 of 23 Old 05-09-2012, 09:56 AM
Canuck-eh!'s Avatar
In response to SergeMonrois, I have a large number of HD DVDs personally and don't see a need to double-dip for the Blu version. I can use my software and purchase 25GB BDRs inexpensively and convert them. I can also leave a copy on my media server. I like a physical backup. Yes, it takes time, but I just run the conversion in the background. In most cases, the Blu version is no different from the HD DVD version video-wise. jmauld's wish to convert his current library is not far fetched.
post #13 of 23 Old 05-09-2012, 02:32 PM
Mizu_Ger's Avatar
I've been backing up the few HD DVDs I have left (Apollo 13, The Thing etc, films which have better PQ than the Blu-ray releases, no DNR) to BD25's quite easily.
  1. Place disk into drive with AnyDVD HD running
  2. Open EVOdemux and chose the first feature .evo file
  3. Demux the video and audio to hard drive
  4. Use vc1conv to remove the 29fps flags so that video stream will be recognised as 23.976fps
  5. Use tsMuxer to mux the video and audio into Blu-ray format
  6. Use imgburn to create .iso and burn to BD25
This gives a film-only Blu-ray with DD+ audio. I have 2 BD players (and a Dune HD) and all support DD+, so doesn't cause me a problem.
Mizu_Ger is offline
post #14 of 23 Old 05-09-2012, 03:40 PM
Rich86's Avatar
Quoted: 134 Post(s)
Liked: 67
Actually, my HD-DVD players and titles are very much alive & well.
And the ability to make back-up copies of my HD-DVD titles or convert them to a different format for increased playback flexibility is very useful.
That's why we need this capability.
Rich86 is offline
post #15 of 23 Old 05-21-2012, 11:36 AM
Mizu_Ger's Avatar
Has anyone converted Apollo 13 and U-571 from HD-DVD to Blu-ray? Both have audio sync problems and the DD+ track needs to be offset. For Apollo 13 +500ms looks to work for me, I am working on the DTS and DD+ for U-571 now.
Has anyone done these 2 films? What offsets did you use?
Mizu_Ger is offline
post #16 of 23 Old 06-29-2012, 09:48 PM
tienvg's Avatar
I would love to back up my copy of The Eagles Farewell Tour to BD. However, my computer skill is very lacking. If anyone has this in their collection and decide to put this on BD, I would love to make a trade for this.
tienvg is offline
post #17 of 23 Old 06-30-2012, 09:20 PM
DavidEC's Avatar
I have read where ""SOME"" Wal-Marts are accepting the "HD-DVD"s for conversion to the "VUDU" "Cloud" movie collections for the $2 each price?
Has anybody here been able to do this and on the "VUDU" site there has been no ''OFFICIAL'' comment or policy.
:David
DavidEC is offline
post #18 of 23 Old 07-08-2012, 09:04 AM
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
:David
I posred rhis quesrtion to the Wal-Mart clerk a few days ago...he didn't even know what HD-DVD was. But next time I go Ihere , I might just bring a disc with me and see what happens.
cinema13 is offline
post #19 of 23 Old 07-22-2012, 03:02 AM
jd213's Avatar
If you're just reusing the HD DVD's DD+, I believe eac3to will automatically add the appropriate delay when demuxing/converting. If you happen to have the BD and want to use its DTS-MA (this allows you to have lossless and still fit on a BD-25, when I tried converting the DD+ for Apollo 13 to LPCM, it wouldn't fit), another poster said -431ms will work: http://www.avsforum.com/t/1243394/apollo-13-comparison-pix/300#post_19996540
jd213 is offline
post #20 of 23 Old 07-27-2012, 12:33 AM
jra166's Avatar
Quoted: 12 Post(s)
Just ordered a 360 HD-DVD player to back-up my HD-DVDs on hard drive. I have already backed up my standard def DVD collection to hard drive except for my PAL region 2 DVDs. I have read that the HD-DVD player conforms to the region of the 360 console for DVD playback, but when it is plugged into my PC, will I be able to back up my REGION 2 standard DVD's? Thanks.
jra166 is offline
post #21 of 23 Old 08-12-2012, 09:50 PM
DavidEC's Avatar
:David
The convert to digital program ends August 31st..
I took 12 HD-DVD's and 3 Blu-Ray's with the printed list as if they were BluRay and the clerk did not even question the disc's.. just sat down at her computer and entered the data, then was to of stamped the disc's but the first two she chose were "Flippers" and could not find a spot to stamp "converted" so gave up and just bagged my discs back up and handed them back to me.
Basically I just did my "series" movies such as Mission Impossible, Mummy, The Scorpion King, Matrix.
Since not all of my disc's are available at VUDU I could not convert too many more.
:David
DavidEC is offline
post #22 of 23 Old 09-04-2012, 03:13 AM
Ivan Walker's Avatar
Sounds good, but do they contain certain kind of limitations? Like time you can use, ads, or something like that? smile.gif
Ivan Walker is offline
post #23 of 23 Old 09-04-2012, 05:20 PM
Rich86's Avatar
Quoted: 134 Post(s)
Liked: 67
Nothing that I have seen.
Rich86 is offline
Reply HD DVD Software
