HD-DVD's on PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 04-01-2013, 11:20 AM - Thread Starter
failedjedi's Avatar
I can't seem to find any playback software for HD DVD on PC. I tried Power DVD but apparently you need a specific version and I couldn't find that. I found references to VLC plugins but was never able to actually find a working download link. Anyone actually have any working software that can play HD DVD on PC and can share the exact version number and piece of software.
failedjedi is offline
post #2 of 14 Old 04-01-2013, 11:40 AM
shazadhosein's Avatar
Search for TotalMedia Theatre 3 (version 3.0.1.195) or TotalMedia Theatre5. Both are by arcsoft.
shazadhosein is offline
post #3 of 14 Old 04-01-2013, 12:35 PM - Thread Starter
failedjedi's Avatar
Thanks, I'll give it a try.
post #4 of 14 Old 02-08-2015, 06:24 AM
racprops's Avatar
Quoted: 26 Post(s)
Try this: Find the folder you have the movie in.
Open it and find the first VIDEO_TS.VOB try double clicking on it.
I find normally this will launch my Power dvd 14 and play the movie.
Or sometimes power DVD does not link and play I right click and choose Media Player Classic which can be found on the internet and it will play the movie.
Rich
racprops is offline
post #5 of 14 Old 02-11-2015, 08:15 AM
DavidinCT's Avatar
Quoted: 283 Post(s)
Liked: 86
TMT 6 plays them back too but, it's no longer available, it's been discontinued. Only way you can get TMT3 or 5 is some questionable site, it's not freeware...and you cant get it direct any more. The webpage is no longer up for the product.
I was looking at PowerDVD 14 ultra to see if it would play back HD-DVD, I will try the demo on my HTPC to see if it works...maybe tonight if I get the chance.
Yea, I still have some movies around and No need to replace them with a Blu-ray if I have the HD-dvd, as the quality is just as good.
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
post #6 of 14 Old 02-11-2015, 08:53 PM
Worf's Avatar
Quoted: 562 Post(s)
Liked: 299
Or better, even. You have to remember during the war HD-DVDs were using VC1 or AVC video codecs whereas Blu-Ray used MPEG2 and were often hobbled by 25GB single layers since dual layer Blu-ray came out nearer to the end.
I just bought a catalog movie from that era and am looking to see if it was available in HD-DVD for that reason. It did oddly have dual layers but only Dolby digital audio (nothing better - no DD+, TrueHD, or DTS...).
Worf is offline
post #7 of 14 Old 02-12-2015, 06:02 AM
DavidinCT's Avatar
Quoted: 283 Post(s)
Liked: 86
I was thinking about ripping my HD-DVD movies, I thought they all came with DTS-HD/DD-HD audio formats on them, crap, now I have to double check.
If no HD audio, I will have to replace them, dam...(it's kind of a big deal for me)
-Dave
MCSE 2003
post #8 of 14 Old 02-12-2015, 08:44 PM
Worf's Avatar
Quoted: 562 Post(s)
Liked: 299
Well, I know a few that had superior mixes on HD-DVD - not lossless, but better. There are lists of HD-DVDs that can tell you which are superior to the Blu-ray. And now we have a couple of years of lost movies where the only playable one is not as good quality as it could've been.
As for HD-DVD playback, apparently I have a copy of WinDVD 9 which was the last version that supported it. My PowerDVD versions are too new. But I do have Xbox360s and my old HD-DVD player. Maybe I should check eBay to see if I can find some nice HD-DVD player cheap...
Worf is offline
post #9 of 14 Old 02-13-2015, 06:28 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
PDVD 9 was the last version to include HDDVD support as I recall. TMT is another option. You could just playback the EVO files in VLC after decryption.....
qz3fwd is offline
post #10 of 14 Old 02-13-2015, 09:28 PM
Worf's Avatar
Quoted: 562 Post(s)
Liked: 299
I have PDVD 9, and my LG multi reader came with tmt3 but only with 2 channel audio. And you cannot buy TMT anymore - it's no longer supported nor for sale.
Though I admit to not realizing VLC would work, as I do have AnyDVD HD.
Worf is offline
post #11 of 14 Old 02-14-2015, 04:52 PM
wuther's Avatar
Quoted: 642 Post(s)
Liked: 181
I found Home Cinema (http://www.mpc-hc.org/) to be the best player for decrypted HD-DVD files (via DumpHD), it handled the multi-audio tracks well.
wuther is offline
post #12 of 14 Old 02-14-2015, 08:43 PM
Worf's Avatar
Quoted: 562 Post(s)
Liked: 299
Any of these support the menu system /extras?
One thing that the HD-DVDs often had over Blu-Ray was extras ...
Worf is offline
post #13 of 14 Old 02-14-2015, 10:12 PM
wuther's Avatar
Quoted: 642 Post(s)
Liked: 181
Home Cinema, and probably VLC, can only read the evo files. I do not know of any free software that supports the menus or converts them but the extras are in the evo (or should be) files and are playable but you will have to figure out what each file is by yourself.
wuther is offline
post #14 of 14 Old 09-18-2015, 12:56 AM
73ChargerFan's Avatar
That's easy, though, because the extras have file names that are human readable.
On topic, I'm using TMT 6 but it doesn't work with Win10. Sticking with Win7, which is the best imo.
73ChargerFan is offline
Reply HD DVD Software
