HD-DVD Authoring to DVD -/+ Media - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 1475 Old 06-04-2006, 02:09 AM
Gary Murrell's Avatar
Thanks Brosnan for all your hard work
-Gary
Gary Murrell is offline
post #452 of 1475 Old 06-04-2006, 08:27 AM
cal87's Avatar
Quoted: 30 Post(s)
Liked: 29
For those interested, the INHD tune-up is on alt.binaries.hdtv.repost on 6/2
Another little tidbit. I have found that MF5 works a lot faster when I have the source files on my secondary "D" drive (the main program is installed on the "C" drive).
cal87 is offline
post #453 of 1475 Old 06-04-2006, 09:54 AM
Mooneyass's Avatar
Can anyone recommend a free news reader? Also, I'd be more than happy to host these files if they are not copyrighted so if someone has them PM me so we can arrange to upload them to my server.
Wes
I hate Sony. I love BD. I hate Sony...
My Blog
Mooneyass is offline
post #454 of 1475 Old 06-04-2006, 10:53 AM
Hyrax's Avatar
Quoted: 91 Post(s)
Liked: 46
Originally Posted by brosnan View Post
Some of you may be interested to know about this site: http://www.microsoft.com/windows/win...d/default.aspx
It offers some tools for and examples of interactive content for HD-DVDs.
Brosnan -
I downloaded this a few weeks ago, but have yet to install it. If you've gone through the documentation, can you tell me if it tells you how to access content on the Internet?
If I read the HD-A1 documentation correctly, it is possible for disks to contain links to Internet sites for various purposes, including playing trailers. I'm thinking that this feature could be used to play movies on your local network. Thus, you could just load your HD movies onto your computer and play them without needing to burn disks. Now all I need to do is figure out how to do it
Hyrax is offline
post #455 of 1475 Old 06-04-2006, 11:28 AM
brosnan's Avatar
Originally Posted by Hyrax View Post
Brosnan -
There's no explicit mention of this in the help files (viewable here ). But the XML format examples contain things like
which make me wonder if you could point to remote URLs.
Mike
brosnan is offline
post #456 of 1475 Old 06-04-2006, 01:47 PM
come on guys some one cough it up, thanks a bunch Cal, but I don't use newsgroups
someone must have the HDNet test pattern .ts file for someone to host ? I had it but can't find it
this would be a great way to test our Toshiba's and even compare the HDMI to Component output
-Gary
post #457 of 1475 Old 06-04-2006, 02:50 PM
Joseph Clark's Avatar
Quoted: 272 Post(s)
Liked: 319
-Gary
Gary,
I'm set up to record them this coming week. I used to have them for a while on my 921, but it went in the trade-in for the 622. Check me later this week if you don't have them by then. I'm goint to be burning an HD DVD of the patterns as soon as I get them.
Joe Clark
Joseph Clark is offline
post #458 of 1475 Old 06-04-2006, 03:50 PM
Hyrax's Avatar
Quoted: 91 Post(s)
Liked: 46
Thanks for looking at it. I think you're right; it certainly does imply you can point to remote URLs. I need to check it out and perhaps get on some programming forums.
Hyrax is offline
post #459 of 1475 Old 06-04-2006, 05:45 PM
WiFi-Spy's Avatar
Quoted: 355 Post(s)
Liked: 677
For all the mac users that want to convert the 1080p QT trailers to work on a HD DVD:
Open QT trailer with Mpeg Streamclip
Export to Quicktime, using Apple intermedite Codec 100% quality.
Use these settings for export:
note the X/Y Settings in the Zoom section
Set this 1.33 if the trailer is 2.35:1
Set this to 1.0 if the trailer is 16x9
Make sure you enter 23.97 for the frame rate
after the export is done open Compressor (comes with FCS)
Select HD DVD Mpeg2 as output fromat
Make sure you select AIFF as the audio format (there is a bug in the Dolby output that results in no audio)
picture of configuration:
then just bring the m2v and AIFF into your DSP4 HD DVD project!
BTW the Mpeg2 is 19Mb/s VBR with 27Mb/s Peak, so it should be transparent to the QT file.
Tyler Pruitt - Technical Liaison at SpectraCal
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #460 of 1475 Old 06-04-2006, 06:04 PM
Thanks Joe, you are a godsend
-Gary
post #461 of 1475 Old 06-04-2006, 06:46 PM
joewmaki's Avatar
Gary, I have the full TS file (1.25 gig) as well as the 3 different patterns in mpg (.35 - .5 gig) pulled out with VideoRedo. I burned a test disk with 3 chapters (1 for each pattern). I just need to have a place to upload them.
-Gary
...joe
joewmaki is offline
post #462 of 1475 Old 06-04-2006, 08:56 PM
Mooneyass's Avatar
I'd be more than happy to host them, PM me.....
My Blog
post #463 of 1475 Old 06-04-2006, 09:53 PM
Thanks to another Joe, we are getting close guys , Mooney will host them, send him that PM
-Gary
post #464 of 1475 Old 06-04-2006, 10:19 PM
Mooneyass's Avatar
We should all post torrents as soon as we get it too. Just looked at my hosting and I get 200GB/month so I'd guess we'll use it up pretty quick.
My Blog
post #465 of 1475 Old 06-04-2006, 10:30 PM
edit
-Gary
post #466 of 1475 Old 06-04-2006, 10:47 PM
WiFi-Spy's Avatar
Quoted: 355 Post(s)
Liked: 677
why is the pattern that big? is their nulls?
WiFi-Spy is offline
post #467 of 1475 Old 06-04-2006, 10:53 PM
bigbucky's Avatar
Did anyone else do the firmware update and lose the ability to play your "homemade" HDDVD's over HDMI like I did? They start to play and I get the dreaded "HDMI Error 1" message.
bigbucky is offline
post #468 of 1475 Old 06-04-2006, 11:11 PM
UHD Addict
aaronwt's Avatar
Quoted: 5229 Post(s)
Liked: 3129
I'll have to check. I didn't try any after the update.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #469 of 1475 Old 06-05-2006, 12:14 AM
Quoted: 272 Post(s)
Liked: 319
Wow, this would be a killer for me. It's the main reason I bought the A1. I haven't done an update and if this is how they "update", I never will.
Joe Clark
post #470 of 1475 Old 06-05-2006, 12:20 AM
subbedout's Avatar
I updated my player last night and the first disc I played was one I'd burned earlier with MF5...
subbedout is offline
post #471 of 1475 Old 06-05-2006, 07:25 AM
Mooneyass's Avatar
Crap, I havent checked yet either......
My Blog
post #472 of 1475 Old 06-05-2006, 08:08 AM
Marc D Carra's Avatar
Quoted: 38 Post(s)
Liked: 44
That's what I was afraid of, and why I will never 'update' I'm enjoying my home-made HD-DVDS far too much.
Marc.
MDC
Marc D Carra is offline
post #473 of 1475 Old 06-05-2006, 09:58 AM
The Trout's Avatar
My burned HD-DVDs have played just fine.
Okay, that's a partial lie - my single-layers played just fine. My dual-layers played fine for the first layer and then crapped out at the layer change. Then again, I've only burned, like, two dual-layer discs, so I don't consider this a deal breaker. It also could've been an isolated incident with just that disc.
The Trout is offline
post #474 of 1475 Old 06-05-2006, 11:44 AM
Joe Linn's Avatar
I'm still battling the video skipping on my HD DVDs that I described earlier. I thought maybe the Ulead forum would be a good place for help with that. If you want to see something that will make you never look for help there, check out this thread: http://phpbb.ulead.com.tw/EN/viewtopic.php?t=14328 . I described my problem (several short video skips per minute). I exlained that they were not present in my source mpeg file. I explained that I got VS10 to just mux and not re-encode. I explained that if I viewed the EVO files directly from hard disk, they skipped in exactly the same places so I think it is unlikely that the problem is with reading the DVDs.
First I got told that this was impossible. Then I got told that DVDs cannot spin fast enough to carry HD data. I repeated that I could play the EVO files directly from hard disk and they skipped also. I got told if I wanted to play files on my PC, I should just play MPEG files and not EVO files. I explained I was playing them for diagnostic purposes. An especially "helpful" person posted that although he hadn't read this entire thread, I had clearly misunderstood because this AVS thread was about burning Divx files as data to a DVD and playing it with a Linc player. I presisted trying for help, explaining what this thread was about and what I was doing. The "helpful" guy posted again that he tried the steps I outlined and got the same skipping when he viewed the EVO file. But he said he needed to rename the EVO to MPG, which is not legit, so that was my problem. He also said that any burner program would downres the EVO file and even so the data rate was too high for a standard DVD. He concluded with "This may turn out to be another Internet "legend" that will soon be disproved."
The folks on that thread have been much more intent on proving that I was trying to do something that I shouldn't be doing rather than on helping with the problem. That is unfortunate.
So I'm back here with a couple questions. For the folks who are generating files with no skipping, is anyone using Video Studio or is everybody using Movie Factory? Somebody at the Ulead forum suggested that their EVO creation code might be different between the two products.
Second, is there anyone who is NOT having skipping problems willing to try a couple seconds of my video and to see if they are able to generate files without skipping? I could either mail a data DVD with the mpeg file or if there is somewhere I could FTP it, I could do that.
And last, if anyone would be inspired to post to the Ulead thread explaining this isn't an urban legend, perhaps someone will take the thread seriously and try to help.
Joe
-edit-
ps. Since I wrote that, other folks have joined and tried to find solutions. The one guy still keeps insisting it can't or shouldn't be done.
Joe Linn is offline
post #475 of 1475 Old 06-05-2006, 03:25 PM
Quoted: 272 Post(s)
Liked: 319
Joe
-edit-
Joe,
I skimmed that Ulead support area, too, and it didn't look to be that helpful.
To answer your questions, I'm using MF5, not VS10, so I don't know if they are substantially different in how they go about creating the files. I use Adobe Premiere for all my editing and create .m2t files from within Premiere.
I don't know how much help a couple of seconds would be in diagnosing your problem. I'd be happy to test some of your file footage, but you'll probably have to send me at least a couple of minutes.
I think there is a solution to your problem, so don't give up. You should be able to get satisfactory results. I think I said it earlier in the thread: if I had tried a couple of my failed clips first, I might have given up on this process. Overall, though, it's very valuable and I love it. However, I'm still having the most trouble with movies. I tried to create an HD DVD of some of the Star Wars Sith movie from HBO last Saturday. I captured a clip of a minute + and it went through the process just fine and looked great. When I tried to do a one hour section, it took 5 hours to create some 12 chapter stops and at burn time it told me "The MPEG program stream is not compatible with this DVD engine."
I think what I need here is someone with a lot more technical expertise than I have with MPEG formats to take a look at the files and see if there are substantial differences between files that succeed and files that don't. It could be that the only difference is how MF5 chooses to handle certain files. I just don't have to tools or the expertise to diagnose the problem.
Balazer, are you still reading this thread?
Joe Clark
post #476 of 1475 Old 06-05-2006, 04:13 PM
RickD_99's Avatar
Quoted: 115 Post(s)
Liked: 90
I updated the firmware on my HD-A1 to 1.2 over the weekend and just played my homemade disk (created with firmware 1.0) of Batman Begins (from HBO-HD) and it played just fine over HDMI.
LG 55C6P OLED Display
Oppo UDP-203 UHD Blu-ray Player (0215B firmware)
ELAC unifi B5 Speakers
NAD C316BEE Stereo Amplifier
Sony HT-CT660 Soundbar
RickD_99 is offline
post #477 of 1475 Old 06-05-2006, 04:17 PM
1st on the Block's Avatar
No, so far all my burnt HD DVDs have worked and the dual layer discs play 1st try instead of ejecting and trying again and again.
Pete
The endless pursuit of perfection..or my idea of it anyways........
1st on the Block is offline
post #478 of 1475 Old 06-05-2006, 04:22 PM
I'm using VS 10+. When VS does not re-encode I have no problems. When it re-encodes from 720p or 1280x1080i, I get lip synch issues, video stutter and skips every few seconds. I'm not sure if I want to update the software because I have Blu-ray creation capabilities and image creation in my version.
Pete
post #479 of 1475 Old 06-05-2006, 07:28 PM
niceguy321's Avatar
Do you guys still want the test pattern? I have it and am willing to upload it, I have plenty of space and Bandwidth.
niceguy321 is offline
post #480 of 1475 Old 06-05-2006, 07:37 PM
Quoted: 272 Post(s)
Liked: 319
Hey, Pete,
Since you have Blu-ray capability, could you do a test and see what sort of files MovieFactory 5 likes? Does it handle native .ts files? If so, is it more or less forgiving than it is for HD DVD? I'm really curious about this. It would make Blu-ray disc creation one step easier, and one day I'm going to have a combo player (if both formats survive).
Joe Clark
Reply HD DVD Software
