HD-DVD Authoring to DVD -/+ Media - Page 50 - AVS Forum | Home Theater Discussions And Reviews
post #1471 of 1475 Old 04-02-2008, 02:39 PM
rezzy's Avatar
Quoted: 994 Post(s)
Liked: 754
Originally Posted by DCSholtis View Post
Anyone tried doing this using a Mac? If so how? I couldn't find how to searching each of the threads. Thanks.
UPDATE: Looks like this just got really affordable for you......
http://www.roxio.com/enu/products/to...ium/watch.html
I've yet to try it myself, though.
"I knew you'd say that"...*BLAM!*
rezzy is offline
post #1472 of 1475 Old 10-03-2008, 07:31 AM
Dobiedo's Avatar
Originally Posted by MovieSwede View Post
Is there any program that support HD DVD encoding with 23,976 fps or 24 fps.
Since I shoot in 25P, convert to 29,97 is not an option. But 23,976 is.
I use TmepgEnc4XP to convert TS stream with HD content to mpg files.
I try to keep as close to the original as possible.
I then use the Womble Mpeg Video wizard DVD to make my own HD DVDs.
The Video wizard has an option to make DVDs with a nonstandard format. So you can make vob-files in your VIDEO_TS map with bitrates of 30000 .
My Toshiba HD-EP10 reads this as regular DVD but you still have the high bitrates.
And I always use 25 fps. If I use 23,976 the picture does not flow.
Regards
Dobiedo
Dobiedo is offline
post #1473 of 1475 Old 10-18-2008, 04:38 AM
Ierdna_'s Avatar
Can someone tell me where can i find a link on how to capture a high definition MPEG2 video clip
Ierdna_ is offline
post #1474 of 1475 Old 10-18-2008, 05:51 AM
MovieSwede's Avatar
Quoted: 124 Post(s)
Liked: 87
Thanks Dobiedo.
Even if the reason to encode has gotten less important now.
MovieSwede is offline
post #1475 of 1475 Old 10-18-2008, 06:22 AM
allargon's Avatar
Quoted: 94 Post(s)
Liked: 59
Originally Posted by dts1 View Post
my post above was this, if i have a movie in wmv and want to convert it to mpeg2 which would you guys say would be a good converter to use.
thanks
i have a 720p file with dts sound that is in avi and wmv that i want to put onto a disc
thanks
AVS4You works VERY well for WMV to MPEG2. I can't speak for the sound, though.
http://www.avs4you.com/
Download the video converter for free. The unregistered version will put an annoying watermark in the middle of your screen.
http://www.avs4you.com/AVS-Video-Converter.aspx
allargon is offline
Reply HD DVD Software
