Hulk Error Code - AVS Forum
post #1 of 27 Old 12-24-2006, 07:32 AM - Thread Starter
AVS Club Gold
Art Sonneborn's Avatar
Liked: 44
Finally had the time to sit down with my kids to watch The Hulk and I got an error code. 4094C 202. Disc won't play.
I have 2.0 installed , what is this ?
Art
My HT
iRule rules my theater
"If she's amazing she won't be easy,if she's easy she won't be amazing"
Bob Marley
Art Sonneborn is offline
post #2 of 27 Old 12-24-2006, 07:41 AM
AVS Club Gold
Alan Gouger's Avatar
Art I had the same thing happen to me but a different title. I had played King Kong UK version with no trouble. The next day I popped it in and got the same message. I unplugged the player and tried it again same thing. I took a cotton cloth to the disc ( not that I saw any prints or scratches ) and gave her a quick cleaning and that did it, it worked.
Happy holidays!!
Alan Gouger is offline
post #3 of 27 Old 12-24-2006, 08:12 AM - Thread Starter
AVS Club Gold
Liked: 44
Well, that didn't work. Off to Best Buy , hope they have one left to exchange.
Art
My HT
Bob Marley
post #4 of 27 Old 12-24-2006, 08:23 AM
AVS Club Gold
Art
Sorry to hear this. I hope thats not a sign of whats to come of my King Kong UK disc
post #5 of 27 Old 12-24-2006, 08:33 AM - Thread Starter
AVS Club Gold
Liked: 44
Fifty titles and hundreds of plays this is my second error code. The first was thinking I could play Kong without 2.0.
I'll check in later with any news.
Art
My HT
Bob Marley
post #6 of 27 Old 12-24-2006, 08:39 AM
Blasst's Avatar
Liked: 26
Hopefully you'll find another copy Art. I can only imagine what "The Hulk" will look like on your setup. Enjoy, and Merry Christmas, and since Alan is around, Cheers to the best AV forum on the internet!
The Mod Squad: New vs. Classic TV Series Opening https://vimeo.com/63119329
Blasst is offline
post #7 of 27 Old 12-24-2006, 08:50 AM
rboster's Avatar
Liked: 53
I had this issue with V for Ven. and had the disc replaced. I had 2.0 FW and tried cleaning the disc., but no luck. The second disc worked just fine.
Ron
"Retired" AVS Moderator
rboster is offline
post #8 of 27 Old 12-24-2006, 09:37 AM
Honey1's Avatar
I still have 1.4 and the Hulk played without any problem.
Honey1 is offline
post #9 of 27 Old 12-24-2006, 12:36 PM - Thread Starter
AVS Club Gold
Liked: 44
Second disc does the same thing. Only two possibilities I can see: 1) my 2.0 from a burned CD from the internet is incompatible 2) a bad run of discs at that store
Art
My HT
Bob Marley
post #10 of 27 Old 12-24-2006, 12:45 PM
rboster's Avatar
Liked: 53
Just to follow up Art....my 2.0 FW was direct from Toshiba....since I couldn't get an ethernet download to work with my player. I even took it into work and had the IT guys try with no luck.
rboster is offline
post #11 of 27 Old 12-24-2006, 01:03 PM
MRJAZZZ's Avatar
I have the same problem with KONG, since I updated to 2.0. Tried two versions, still won't play now. Error code0.8/.......something or another.
CHEERS, TC
PS, wonder if a non HDMI feed will work. Have to try the component out to check.
MRJAZZZ is offline
post #12 of 27 Old 12-25-2006, 06:11 AM
patrick99's Avatar
I got this error code on KK yesterday after previously playing it with no serious problems. I have 2.0 installed. No problems with Hulk. Strangely, the error code on KK appeared only after I loaded, selected a scene and then paused.
patrick99 is offline
post #13 of 27 Old 12-25-2006, 09:05 AM
mikey p's Avatar
Art
Wow, that title worked very well here, and has one of the best PQ's I've seen on HD DVD. Maybe your player has issues? BTW: nothing works like the real thing for firmware, Merry Christmas.
It is "WOW" TV!
mikey p is offline
post #14 of 27 Old 12-25-2006, 09:10 AM - Thread Starter
AVS Club Gold
Liked: 44
OK, three hours of assembly and the toys are done ! I bet it's the firmware,it isn't direct from Toshiba.
Art
My HT
Bob Marley
post #15 of 27 Old 12-25-2006, 10:41 AM
Honey1's Avatar
After reading of all the problems encountered by some after installing firmare 2.0, I decided to stick to 1.4. I therefore spent my Christmas having King Kong, Miami Vice and The Pianist (French release) and being unable to watch them (as indicated above, my HD-A1 did play the Hulk!); I still have to try the Matador. I am now really contemplating upgrading to the HD-XA2 when it's released (I skipped the A2 because it does not have analog outputs).
Honey1 is offline
post #16 of 27 Old 12-25-2006, 10:57 AM
MrMcGoo's Avatar
Art,
The two times an error code popped up on my A1, cleaning the laser pickup cured the problem immediately. I use a phillips CD cleaner with the brushes and a bottle of cleaning solution.
IMO, the Toshibas need a regular cleaning to read disks well. I have cleaned the laser pickup several times with no ill effects. If the A1 does die, I have the four year warranty which would mean a new machine.
Bill
MrMcGoo is offline
post #17 of 27 Old 01-01-2007, 11:25 AM
Borbus's Avatar
The reason Hulk won't play on some players is because there is a text file on the root of the filesystem. That is out of HD-DVD spec. The text file seems to contain the volume and title key of the HD-DVD...
Borbus is offline
post #18 of 27 Old 01-01-2007, 12:06 PM
Jeff Williams's Avatar
The error is specifically referring to an AACS problem. I wonder if that extra text file is causing an issue for some? Borbus, are saying that the keys are in a plain text file on the disc? That's a HUGE mistake on there part.
Blu-ray Insider -- Compression and Authoring
Jeff Williams is offline
post #19 of 27 Old 01-01-2007, 02:14 PM
Borbus's Avatar
It seems to contain something that says it's the title key... here's some of the text file:
// Directory Settings
[COMMON]
IN.ROOT=G:\\TheHulk\\TheHulk
OUT.ROOT=G:\\AACS_output\\TheHulk
// Volume ID Setting
[VID]
VID.UNQ_NO=271020061204020202020202
// Title Key Setting
[TKF]
TKF.BIN_FILE=
[DKF]
DKF.DK=554E4956455253414C5F48442D445644
Borbus is offline
post #20 of 27 Old 01-01-2007, 02:27 PM - Thread Starter
AVS Club Gold
Liked: 44
Three diffrent discs did the same thing in my player but the last disc played in an A2 at Best Buy but not on mine. I ordered a 2.0 from Toshiba which should have been here by Friday or Saturday but didn't make it.
If that doesn't correct it I don't know.
Art
My HT
Bob Marley
post #21 of 27 Old 01-01-2007, 08:02 PM
That looks to be exactly what it should NOT be. The key itself may not be the one for the feature. It can be for say the opening Universal logo, but still it looks to be the missing link that is needed for the BackupHDDVD program that has made big news lately. I think I will rent Hulk and do some testing.
post #22 of 27 Old 01-06-2007, 02:19 PM
AVS Club Gold
Kosty's Avatar
Could that key be an encrypted value? It can't be the unencrypted plain text key???
"A lot of good arguments are spoiled by some fool who knows what he is talking about." - Miguel de Unamuno
follow me on Twitter
Kosty is offline
post #23 of 27 Old 01-06-2007, 04:51 PM
jim_r's Avatar
Just FYI, you don't need FW 2.0 to play Hulk. I've got 1.3 and was able to play it all the way through. I even saw that new progress bar when I hit RW or FF. Although, I suppose installing an unofficial release of FW 2.0 could still be causing this if there were some last minute changes in the official release.
jim_r is offline
post #24 of 27 Old 01-06-2007, 09:14 PM
Forceflow's Avatar
If it tells you the encrypted key on error, then AACS really is toast. I really doubt it though...that seems way too mind boggling...
***Warning*** Do not look into laser with remaining eye!!
Forceflow is offline
post #25 of 27 Old 01-07-2007, 12:34 AM
Hexcode's Avatar
Both are not encrypted.
The second value is the ASCII code for "UNIVERSAL_HD-DVD".
Hexcode is offline
post #26 of 27 Old 01-07-2007, 06:12 AM
Michael Grant's Avatar
Something tells me that's not the key
Michael
Michael Grant is offline
post #27 of 27 Old 01-07-2007, 08:02 AM - Thread Starter
AVS Club Gold
Liked: 44
I used the internet 2.0. My thought at this point is the Toshiba version may be different. All I know is the Hulk won't play in my player it runs the logo then gives the error code.
Interstingly ,I got a notice from Toshiba that the 2.0 discs are back ordered !!!!!
Art
My HT
Bob Marley
Reply HD DVD Software
User Tag List
