Do anyone of you adjust your TV settings based on specific HD-DVD's?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-31-2006, 01:14 PM - Thread Starter
persiannight's Avatar
Just wondering if anyone of you adjust your contrast and brightness levels based on different HD DVD's??
I found I really had to boost my contrast level to get The Hulk to really pop and look 3-D.
persiannight is offline
post #2 of 6 Old 12-31-2006, 01:17 PM
rbunnell's Avatar
Yes, I have to sometimes do that with certain HD-DVD's. For instance, I have to slighly lower the contract when viewing Van Helsing because of some ghosting during some of the black colored scenes.
rbunnell is offline
post #3 of 6 Old 12-31-2006, 10:15 PM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
I have to change my brightness setting for most movies to get the optimal black levels for each movie. I find each movie has higher or lower black levels then my calibrated setting and I have to adjust to get the black level detail perfect.
conan48 is offline
post #4 of 6 Old 01-01-2007, 01:01 AM
HD-DVDwonder's Avatar
I set the sharpness from 50 to zero - on most discs w/ no loss in definition, in order to defeat edge enhancement. Could not get away w/ that on most SD
HD-DVDwonder is offline
post #5 of 6 Old 01-01-2007, 05:36 AM
underdog57's Avatar
Brightness tweak on a crt 1208/2 Barco .
Bob
keep at it , results are worth it !!
underdog57 is offline
post #6 of 6 Old 01-01-2007, 10:37 AM
thewretched22's Avatar
Some films i'll adjust my brightness, contrast, sharpness. But generally i leave them all the same.
HD DVD & Blu Ray Owner
thewretched22 is offline
Reply HD DVD Software
