Bough Babel Used: Froze up completely. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-21-2007, 01:00 PM - Thread Starter
adidadi's Avatar
Quoted: 96 Post(s)
Liked: 46
I had to eject the disc 4 times and obviously the movie was ruined as a result. Is it the disc or the software in the player. All other HDVD's have played alright until now. Prior to the software update I had some glitches. What is going on here?
Silence is overrated!
FS: Sony VPL VW5000ES. Two Weeks old REDUCED: $ 32,900.00
http://www.avsforum.com/forum/218-di...-ve5000es.html
adidadi is offline
post #2 of 12 Old 04-21-2007, 01:31 PM
BassTek's Avatar
I just rented it last night and watched the entire thing with no interruptions. I haven't heard any reports of Babel freezing up, you might want to clean the disc and try it again.
BassTek is offline
post #3 of 12 Old 04-21-2007, 02:00 PM - Thread Starter
adidadi's Avatar
Quoted: 96 Post(s)
Liked: 46
I cleaned it on a soft quilt, but no luck. Does it need to be properly cleaned in a disc cleaner?
adidadi is offline
post #4 of 12 Old 04-21-2007, 02:25 PM
BassTek's Avatar
You could use a disc cleaner, or go the cheap route and use dish soap as others have been doing with Children of Men and other problem discs. Rinse the disc with water, squirt on some liquid dish soap, wipe it around gently with your finger and then rinse and pat it dry with a cloth or paper towel. If that doesn't work it could be a defective disc, maybe that's why the guy got rid of it.
BassTek is offline
post #5 of 12 Old 04-21-2007, 03:04 PM - Thread Starter
adidadi's Avatar
Quoted: 96 Post(s)
Liked: 46
I used windex and tissue paper, then a soft cloth and it appears to have fixed the issue. How temporamental.thanks for the advice.
adidadi is offline
post #6 of 12 Old 04-21-2007, 03:18 PM
blackbody's Avatar
I would not buy any used HD-DVD. A tiny little scratch can render the disk un-playable. If you feel you must own a disc, buy it new. Otherwise rent it. I've rented numerous HD-DVD from NetFlix, and one out of every 4~5 discs do not play or freeze in the middle of the movie. HD-DVD have some serious flaws with their disc that needs to be addressed.
blackbody is offline
post #7 of 12 Old 04-21-2007, 04:44 PM
Odys's Avatar
You may have an issue with your player. Have you upgraded the firmware? I rent HD DVDs from Netflix all the time and I've never had to clean the disc since a couple of upgrades ago. Most discs look very scratched, but they play flawlessly on my A1.
Odys is offline
post #8 of 12 Old 04-22-2007, 08:49 AM
JaylisJayP's Avatar
Although the price of these high def movies used at Gamestop or similar outlets is enticing, it's something like this that has me extremely leery. You just don't know what condition you're getting. And I highly doubt these places are testing blu-ray or HD DVD movies before they take them as trade in.
Not saying that's the reason for the Babel disc freezing up, but who knows.
Blu-ray = 775
JaylisJayP is offline
post #9 of 12 Old 04-22-2007, 09:56 AM
Customgamer1's Avatar
Well I rent HD-DVD's from Netflix all the time and have yet to get a disk that will not play.
I have a A1 with 2.1 and maybe it's my location but the disks I get from netflix are all in good shape with only small scratches or none at all. Other than that I give netflix 5/5 stars for great disks!
On the dvd's I rent I also have never had a bad copy of a disk or one that would not play.
For either format I can't remember a time that there was a disk I could not play. Maybe it helps living next to Milwaukee since it's not as big as others with a lot more traffic?
Customgamer1 is offline
post #10 of 12 Old 04-22-2007, 11:32 AM
vcuram's Avatar
I've bought about 15 used HD-DVDs from Movie Stop since Christmas. I haven't had one problem yet, even with Children of Men. All of their used products are guaranteed for life and the EB Gamer card takes 10% off all used movies. I get all my discs for $10-12. I'm glad lots of people stay away from the used discs, that means more for me!
vcuram is offline
post #11 of 12 Old 04-22-2007, 11:32 AM
blackbody's Avatar
My problem with HD-DVD may be due to my player (XA1, latest firmware) but I doubt it. I have absolutely no problem playing new discs. Some rentals with scratches play without problem but some with couple minor scratches do not. The last disc I had problem with, Derailed, looked pristine (after cleaning it with Windex) with only a couple small scratches along the edge. Yet the disc would freeze right after the studio logo. In recent days, discs I receive from NetFlix have truly gone down the hill; I receive discs that are badly scratched and sometimes cracked. What do people do with their rentals anyway?
post #12 of 12 Old 04-22-2007, 11:42 AM
lovebuzz#836's Avatar
Could be a faulty disc, maybe the reason the original owner wanted to get rid of it. This is a big deal for me and why I don't have a whole lot of discs. I watch each one to make sure that it is not defective before moving on to another. This is also how I know older movies that fail had deteriorated over time.
lovebuzz#836 is online now
Reply HD DVD Software
