Uh oh - cloudy discs (disc rot?) - anyone else ? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 45 Old 08-31-2007, 01:24 PM - Thread Starter
MJeeves's Avatar
Originally Posted by kevxross View Post
Put it in a ziploc bag with some silica gel packets... see if the fog starts to disappear...
It definately looks like moisture of some kind... agreed.
I may try and use silica gel in the room where they are stored too.
I have no reason to make this up guys. I'm just concerned that some of my discs may go the same way. And then what?
M.J.
MJeeves is offline
post #32 of 45 Old 08-31-2007, 05:02 PM - Thread Starter
MJeeves's Avatar
Originally Posted by cadbury8 View Post
dont get all worried as its probably just an isolated incident. you got a bad disc with an air bubble in it.
have you checked your other discs?
Yes. Checked all my other HD-DVD's and BluRays too. All look fine except "AMERICAN WEREWOLF" which is "cloudy" beyond belief and "JOHN CARPENTER'S THE THING" which looks a little "patchy". Cleaned up O.K. though.
M.J.
MJeeves is offline
post #33 of 45 Old 09-01-2007, 01:38 AM
BerserkerTails's Avatar
You could always try contacting Universal... They may be able to send out a replacement disc.
...This thread got me worried though. I had to run to my copy of American Werewolf, and make sure it was okay.
BerserkerTails is offline
post #34 of 45 Old 09-01-2007, 04:00 AM
ECH
ECH's Avatar
There are no photos of the actually problem.
ECH is offline
post #35 of 45 Old 09-01-2007, 05:25 AM
Topweasel's Avatar
That looks like a picture from the DVD side. The HD side has a more bluish instead of yellowish hue.
Sorry should have read farther before posting..... I like the Gel silica Idea. Any chance you were one of the clean in tap water people.
Topweasel is offline
post #36 of 45 Old 09-01-2007, 05:31 AM
DavidEC's Avatar
Originally Posted by MJeeves View Post
Hello,
I was hoping some of you may be able to help me please...
I just reached for my "AMERICAN WEREWOLF IN LONDON" HD-DVD Combo disc to watch. When I got the disc out of the case I noticed that the HD-DVD side was all "cloudy". ::::
You might want to look at my post under "Unleashed" about plastic injectors and my take on the 'Universal' disc troubles???
--David
DavidEC is offline
post #37 of 45 Old 09-01-2007, 06:18 AM - Thread Starter
MJeeves's Avatar
No I've NEVER washed any of my discs. A little gentle wipe with a damp soft cloth to get rid of stray fingerprints is as heavy handed as I get.
M.J.
MJeeves is offline
post #38 of 45 Old 09-01-2007, 06:22 AM
Slim GoodBooty's Avatar
Could be a problem with the glue is letting moisture in. I have CDs like that and they play. I can't be sure that an HDDVD would, though.
Slim GoodBooty is offline
post #39 of 45 Old 09-03-2007, 05:56 AM - Thread Starter
MJeeves's Avatar
Thanks guys. I'll keep an eye on my other discs. Meanwhile I've sent "AMERICAN WEREWOLF" back to where I got it from. I will also inform Universal.
I may invest in some "de-humidifying"...?
M.J.
MJeeves is offline
post #40 of 45 Old 09-03-2007, 11:06 AM
ocd_guy's Avatar
My "Miami Vice" HD DVD has a spotty / cloudy coating on the high definition side too. After various attempts to capture a visible image on a digital camera, I gave up! You can see it when the disc is angled slightly under bright light. Disc still plays fine.
-Murray
R.I.P. Lou Ashby
ocd_guy is offline
post #41 of 45 Old 09-04-2007, 06:32 AM
LexInVA's Avatar
Quoted: 634 Post(s)
Liked: 259
-Murray
Consider yourself lucky. Mine won't work past a certain chapter.
LexInVA is offline
post #42 of 45 Old 09-04-2007, 07:15 AM
bigbarney's Avatar
Quoted: 165 Post(s)
Liked: 61
From what I am seeing in the sample pics, it looks very much like a separation problem. The plastic laminate cover is separating from the disk itself. I don't know if you have seen the transparent window decals that are placed on automotive windows, but when they separate the window is no longer very see-through at the point of separation (the glue layer becomes visible)
This can happen to ALL disks. Sometimes it's just defective... sometimes it's uneven heating, and/or improper storage that will do it. You can see it on a lot of older CD's for example.
bigbarney is offline
post #43 of 45 Old 09-04-2007, 07:22 AM
tteich's Avatar
... but don't forget to make photos first, and post them here. Just as a reference for us for things to come...?
Laserdiscs: ~350
HiVision LDs: 42
HD DVD count: 379 / still 20 on the wishlist
tteich is offline
post #44 of 45 Old 07-28-2012, 03:50 AM
Vriess's Avatar
Guess it's good Blu won the format war
Vriess is offline
post #45 of 45 Old 07-28-2012, 03:34 PM
Rich86's Avatar
Quoted: 133 Post(s)
Liked: 67
My experience with my large HD-DVD collection is . . . looking at the data surface doesn't mean much. I've had pristine looking discs fail, and cloudy looking discs play perfectly time after time.
I've had problems with a number of Warner titles as well as 1 each from Rhino & Magnolia. In all cases, they appear to have been manufactured by cinram under contract with Warner as the distributor.
Now THOSE I would be wary of!
The good news is that the applicable movie studios replaced every one of my bad titles with a new HD-DVD (Rhino & Magnolia) or a blu-ray (Warner).
A long-time audio/video addict!
Rich86 is offline
Reply HD DVD Software
