XBOX 360 HD-DVD & Firmware Updates ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 09-01-2007, 07:49 PM - Thread Starter
TokyoShoe's Avatar
Does anyone know how to update the firmware of an XBOX 360 HD-DVD Drive when used with an HTPC? I found some firmware updates that you download and burn to CD/DVD... but they are for updating the firmware via an XBOX. Anyone have any ideas how to update the firmware from a PC (specifically Windows Vista) ?
I've officially gone PURPLE, thank you LG!
My Growing Video Collection
TokyoShoe is offline
post #2 of 18 Old 09-01-2007, 07:55 PM
Alpha Emeritus's Avatar
it would have to be through windows/microsoft update. there is a driver available, but it would probably have to be updated for it to work with newer release dvds.
try updating it through xbox live on a 360 and then using it on the pc.
HD DVD:16 Blu Ray:0
I took the RED pill.
Alpha Emeritus is offline
post #3 of 18 Old 09-02-2007, 08:01 AM - Thread Starter
TokyoShoe's Avatar
That's just the drivers for the hardware. I believe there is actual firmware on the drive that needs to be updated as well, yes?
post #4 of 18 Old 09-02-2007, 09:13 AM
Chris Rein's Avatar
When you log into Xbox Live, there "could" be an update for the dashboard depending upon how long you haven't connected to Live.
Now, once you are all set with the dashboard, throw in a HD-DVD into your drive. It will then connect to the network and probably get you an upgrade or two since you haven't done it yet.
That should take care of it all.
Chris Rein is offline
post #5 of 18 Old 09-02-2007, 09:17 AM - Thread Starter
TokyoShoe's Avatar
That's the complication, I am using this with an HTPC.. not an XBOX 360. I do not even own an XBOX. So, am I going to have to haul this thing over to a friend's house to update the firmware?
post #6 of 18 Old 09-02-2007, 09:21 AM
Chris Rein's Avatar
According to this, I guess.
http://www.xbox.com/en-US/hardware/x...nload.htm#disc
You might want to give it a shot.
Have you tried the HTPC area here on the forums? I'm sure somebody has had the same issue.
post #7 of 18 Old 09-02-2007, 09:50 AM
DJ79's Avatar
Which issues are you hoping to fix with this update?
DJ79 is offline
post #8 of 18 Old 09-02-2007, 10:08 AM
the same things you'd fix by updating the firmware on any other hd dvd player. he'll be able to play all the new release hd dvd's and access the features on every disc.
being that its meant for use with the xbox 360 i would guess that this is the route to take. lug it to a friend's and bring along the installation disc that came with it in the box. update after putting a new release hd dvd in the tray. (should be and automatic prompt)
HD DVD:16 Blu Ray:0
post #9 of 18 Old 09-02-2007, 10:42 AM
Nox
Nox's Avatar
Have you searched through: one and only 360 HD-DVD Drive thread & LINKS ?
EDIT:
From what I understand, the HD-DVD drive doesn't need updating. The playback for any HD-DVD including new releases and extras are all handled within the software, like PowerDVD.
-David
Nox is offline
post #10 of 18 Old 09-02-2007, 01:07 PM
TrueHD's Avatar
My first HD DVD add-on was defective, so I exchanged it after about 3 weeks. When I plugged the new one in, I didn't need to update the new add-on. So I would assume any update is really being applied to the 360 and not the add on.
TrueHD is offline
post #11 of 18 Old 09-02-2007, 02:10 PM
this could be because they refurbished your defective drive and sent it back to you. or it could also be that there was not yet an update available and it came later, in the future, and you downloaded it then.
i also had a bad experience with my first add-on. the power supply connector broke off inside of the drive, a case of poor workmanship. and i had to be supplied with a totally new drive.
as a result, despite being told exactly what you said (though it came from an xbox support rep), i had to reinstall with the original install cd i had kept from the first (hardware drivers) AND update via xbox live (firmware update) before i was able to watch my movies normally. i think it is a case of both being software and hardware related. and i suspect that if he plans to use it on a pc, even though it is not officially supported by microsoft in this manner, the best way to keep it updated is through xbox live...as it is the way that it has been endorsed to stay up to date with the releases.
HD DVD:16 Blu Ray:0
post #12 of 18 Old 09-02-2007, 02:49 PM
jzanitsch's Avatar
The 360 HD-DVD firmware patch is actually just putting a patch on the 360 itself, since all of the HD-DVD decoding is being done by the 360. Therefor, you don't need the firmware update if you are using the 360 HD-DVD drive on an HTPC. The only updates you need to worry about are to your HD-DVD playback software.
jzanitsch is offline
post #13 of 18 Old 09-05-2007, 10:04 PM
Andy Pennell's Avatar
jzanitsch is correct: the update is for the player software only, so if you use the drive on a PC it won't make any difference. The drive firmware has yet to have any update.
If you are having trouble playing titles, give feedback to the authors of whatever software you ar using on your PC (after making sure you are running the latest version).
HD DVD Veteran
Andy Pennell is offline
post #14 of 18 Old 09-05-2007, 11:52 PM
nm88's Avatar
I have never updated any firmware on my 360 HD-DVD (w/HTPC) and it can read every single disc, including problematic ones. (I suspect it doesn't even have any firmware that can be updated.) However, PowerDVD properly decoding them is an entirely different matter.
nm88 is offline
post #15 of 18 Old 09-06-2007, 07:13 AM
Jonny_eh's Avatar
For even more clarification: When people here talk about an HD DVD firmware update for the 360, the firmware sits and runs on the 360, not the drive. The drive just blindly reads data off the discs, and has never had a firmware update for it (at least not yet).
Jonny_eh is offline
post #16 of 18 Old 09-06-2007, 07:22 AM
dad1153's Avatar
Quoted: 2210 Post(s)
Liked: 1364
Send a message via Yahoo to dad1153
Over the weekend my copy of "The Host" would not play on my HD-DVD add-on; as soon as I clicked on anything in the menu screen it would kick me back to the XBox 360 dashboard screen. This is the first movie that has given me playback issues, everything else (even "Children of Men," "Hollywoodland" and "The Good Sheperd") has played fine. I'm not a subscriber to XBox Live. Do I have to burn the latest HD-DVD update to the 360 on a CD-R for "The Host" to play on my add-on drive? Doesn't the "300" HD-DVD combo come with the latest 360 update that uploads it automatically when putting the HD side into the add-on drive? Just checkin'.
dad1153 is offline
post #17 of 18 Old 09-06-2007, 07:31 AM - Thread Starter
TokyoShoe's Avatar
Thanks a lot for all the clarifications on this , gents. I'll just have to make sure and keep up on my PowerDVD updates!
post #18 of 18 Old 09-06-2007, 09:32 AM
jared701's Avatar
That's been bugging me for awhile. It is NOT a firmware update (for the hd dvd drive) Firmware is information on the hardware itself. What they are doing is simply updating the software on the 360 (which may be considered the 360's firmware). I've been told on this forum multiple times that my trouble with power dvd was because I hadn't updated the hd dvd add on's firmware and even that that drive 'wouldn't work' with a PC less than a week ago.
jared701 is offline
Reply HD DVD Software
