Calibration - DVE or Avia?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-05-2007, 01:25 AM - Thread Starter
frankoman77's Avatar
Which would you recommend? I have already calibrated my HDTV with the older SD discs and was wondering if getting the HD versions was worth it and which one was easier to use. Any help would be appreciated!!
frankoman77 is offline
post #2 of 8 Old 12-05-2007, 07:28 AM
Voyeur's Avatar
I have both the DVE HD-DVD and the Avia II. I like the DVE more. I think their tutorials are better. I think their color test is better as well.
Voyeur is offline
post #3 of 8 Old 12-05-2007, 11:04 AM
bflip1080's Avatar
DVE helped me get a much better picture from my new samsung. it was way easy to use. if you are familiar with calibration then you probably don't need to watch the sd side. if not then just watch the sd side and then flip itto HD and use the patterns and bingo.
Beauty, thy name is KURO.
bflip1080 is offline
post #4 of 8 Old 12-05-2007, 11:48 AM
Mavinwow's Avatar
Quoted: 405 Post(s)
Liked: 467
Is there really a difference between the HD and SD patterns on DVE? I have calibrated with the SD DVE through my HD-A2, would the HD-DVD be any different?
Samsung 55ES8000
Vizio 70 P Series, Calibration settings
CalMAN 5 Novice Walkthrough
Denon X4200, 5.1.4 setup
Mavinwow is offline
post #5 of 8 Old 12-05-2007, 12:13 PM
oni_dee's Avatar
Are there any retail US stores that sell either disc? I would order it online but I'm impatient.
oni_dee is offline
post #6 of 8 Old 12-05-2007, 04:26 PM
erkq's Avatar
Quoted: 599 Post(s)
Liked: 432
I picked mine up at Fry's. Got a Fry's around?
erkq is online now
post #7 of 8 Old 12-05-2007, 05:24 PM
piturra's Avatar
Well, as far as the Test Screens to Calibrate your Color/Tint with the BLUE Filter and Pluge Test Screen for Brightness, ... you'll get the same results between the SD DVD vs. HD DVD DVE.
The advantages of the HD DVD is the update 1080p Test Screens, ... vs. the 480 Test Screens upconverted to 1080p.
Here's one example:
SD DVD 480 upconverted 1080i
... vs. ...
HD DVD 1080p
Since the HD DVD is a Combo, ... I sold my SD DVD DVE @ eBay!
piturra is offline
post #8 of 8 Old 12-05-2007, 08:22 PM
wackii's Avatar
Or you can download the calibration disk for one of the member here http://www.avsforum.com/avs-vb/showthread.php?t=948496 Burn that iso file and calibrate your TV that way. I'm using that and got good results.
Al,
"When the opponent expand, I contract,
When he contracts, I expand,
And when there is an opportunity,
I do not hit--it hits all by itself."
- Bruce Lee
wackii is offline
Reply HD DVD Software
