Where to buy HD-DVD 2 Disc Case? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2008, 08:49 PM - Thread Starter
crspyjohn's Avatar
search this on ebay "5 X AMARAY SWING TRAY 14mm HD DVD CASE BLU-RAY CD PS3"
They come out to $5 per case shipped. I might order some and sell the 3 extra at $5 each on the forum.
crspyjohn is offline
Old 02-26-2008, 09:20 PM
candyman56's Avatar
Hopefully someone could find a place that sells these.
candyman56 is offline
Old 02-26-2008, 10:09 PM - Thread Starter
crspyjohn's Avatar
where do you buy foam dots? nvm found on ebay "CD DVD Mounting Sticker Hub Center Free Ship"
Old 02-27-2008, 05:29 PM
baboyizm's Avatar
Originally Posted by HD 335 View Post
These aren't 2 disc HD DVD cases, but you can get single disc ones on ebay
NO HD DVD logo cases - Ebay Item 320221622876
WITH HD DVD logo cases - Ebay Item 150206681794
I need these for the Hollywood Video deals i'm hunting down.
baboyizm is offline
Old 02-27-2008, 06:11 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
I've made a lot of homemade HD-DVDs (burned on regular DVD-Rs) that span 2 or sometimes even 3 discs.
The replacement cases from DVDInternational have a center hub that can easily accomodate 2 discs, even three if you rest the third on top of the other two and then close the case...the disc doesn't move at all.
Also, I've put the third disc in a paper holder and tucked that under the clips where the booklet/paperwork normally go.
So, basically, you can get away with single disc cases...
Theater 1: LG OLED55E6P 4K TV, Samsung UBD-K8500 UHD Blu-ray player, Oppo UDP-203, Dune HD Solo 4K
Theater 2: Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D (CFW), Dune Base 3.0 / Smart units, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is offline
Old 02-27-2008, 06:13 PM
Xylon's Avatar
I also need theose HD DVD cases. I scored 15 HD DVD titles from Hollywood Video and they dont have the original case anymore.
Xylon is offline
Old 02-27-2008, 07:21 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
I'm not sure why finding replacement cases is such a mystery for everyone. I just went on google and searched "replacement hd-dvd cases" and got plenty of hits...eBay, etc...in fact, the first hit is DVDInternational where I buy mine from...expensive...but they have the hub that accomodates multiple discs easily.
fatherom is offline
Old 02-27-2008, 07:54 PM
johnny15's Avatar
what hub?....and where do you get the insert?
I'm to the point where I'd put my Reds in a Blu case if they even had 2-disc cases......
johnny15 is offline
Old 02-27-2008, 08:19 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
The hub is the little thing inside the case that the disc snaps onto...the cases from DVDInternational are the kind with a certain type of hub that can handle more than one disc...you just push firmly and it will stay on. These are the same kind of cases that do NOT have the little flap/door that keeps the case closed.
I'm not sure what you mean by insert, but if you're talking about where I put the 3rd disc, I take a paper CD holder (I have a pile of leftovers from somewhere...I can't remember where) and cut it to just hold the disc, but still fit inside the inner door of the case.
Here's a photo (there's 2 discs on the center hub):
fatherom is offline
Old 02-27-2008, 09:41 PM
HD 335's Avatar
You can get these hubs, they work well.
https://www.fastenation.com/class.php?id=30
HD 335 is offline
Old 02-28-2008, 12:32 AM
Axiom Divine's Avatar
Originally Posted by rr6966 View Post
I'd love to have 5 disc case. I'd use it for Battlestar Galactica!
This might be a bit "ghetto" but it works. What I did was use single hd dvd case and added a foam cd dot on the blank panel. I'd rather have a 2 disc hd dvd case, but the foam dots work fine for now.
Ghetto works for me
Axiom Divine is offline
Old 02-28-2008, 02:50 AM - Thread Starter
crspyjohn's Avatar
If you read the thread at all, we are looking for a TWO DISC case thats holds one disc on each side, not stacking them on each other. Of course your method works, but thats not what I want or some other members want.
Old 02-28-2008, 03:33 AM
lgans316's Avatar
Quoted: 74 Post(s)
Liked: 46
Instead of buying an empty case for $2 how about buying buying the 2-disc collectors edition HD DVD titles at the same rate say around May or June and use them as replacement cases.
Blu-ray : 340
lgans316 is offline
Old 02-28-2008, 03:59 AM
DjfunkmasterG's Avatar
I more or less did what the poster with the pic did, but I didnot cut my sleeve to fit. I inserted it just fine and case closed. I did this for all the 2 disc films I have that I got from HWV.
writer and director DEADLANDS 2: TRAPPED
HD-DVD 321(Crank, The Prestige, No Reservations, Happy Gilmore)
Blu-Ray 75 (Gladiator/Braveheart)
DjfunkmasterG is offline
Old 02-28-2008, 06:44 AM
johnny15's Avatar
These things looks pretty cool.....I may have to try them!!!
Edit:
Ok, after closer review, with the link above, you have to purchase at least $50 worth of product from that site....that's at least 400 hubs!!!!
I did a google search for "clear cd hub" and found a few sites that you can order them reasonable from. You can also find white and black ones too. I'd like clear that way I can put them in a Red or Blu case and should look clean and neat.
Here are the links:
http://www.shop4tech.com/item1470.html
http://www.cd4sale.com/Black_CD_Hub_p/hub-c-100.htm
johnny15 is offline
Old 02-28-2008, 07:03 AM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
Ummm...excuse me, but I've read every post of this thread. I was responding to other people who asked about single disc cases, and I simply mentioned that you can put more than one disc in them...
Yeesh...
Chris
fatherom is offline
Old 02-28-2008, 08:10 AM
sl@cker's Avatar
25 clear mounting hubs for 6.99 plus free shipping:
http://cgi.*********/25-Clear-CD-DVD...QQcmdZViewItem
**edit - link doesnt seem to be working. just go to ebay and search for "dvd mounting hub". then scroll down.
sl@cker is offline
Old 02-28-2008, 08:46 AM
Finch106's Avatar
Walmart sells the mounting hubs by their blank dvd's and cds. They are by memorex, and you get 5 for 2.47 or something. I just bought some even though I ebayed and got 25 for $7, I needed to see if the box would close, and it does. Go by walmart!
Finch106 is offline
Old 02-28-2008, 08:49 AM
sl@cker's Avatar
now we just need to find 5 disc hd dvd cases.. for Blade Runner
sl@cker is offline
Old 02-29-2008, 08:10 AM
JoeBel's Avatar
Quoted: 38 Post(s)
search user: uanashformat on eBay and the listing is: "10 New HD-DVD Cases Double (for 20 DVD's) RED"
Joe
JoeBel is offline
Old 02-29-2008, 08:14 AM
sl@cker's Avatar
does anyone know, are single and double hd dvd cases the same size? If so, ordering 25 mounting hubs for 6.99 would make more sense, as it turnes any single hd dvd case into a double hd dvd case..
sl@cker is offline
Old 02-29-2008, 06:12 PM
guyincognitoo's Avatar
The retail two disk cases are the same size, going by my copy of Transformers.
guyincognitoo is offline
Old 03-01-2008, 02:15 AM
Finch106's Avatar
uanashformat is the seller, but I don't need 10 2-disk cases, I need probably 4 or 5 to be safe, but just 1 would be fine. These firesales at Hollywood Video are killing me with their standard size cases. I need one for beowulf, anyone willing to part out 4 or 5 of them? I emailed uanashformat and they said they will have some next week sometime.
Finch106 is offline
Old 09-22-2010, 08:36 PM
narcopolo's Avatar
Is he still looking after two and a half years?
narcopolo is offline
