Best CD/SACD player < $1000??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 159 Old 05-18-2008, 04:09 PM - Thread Starter
rodH's Avatar
OK, I think I am ready to get something in that $1k range that plays CD and SACD discs. I will leave DVD A/V to another player. I could either use the DAC in the player or just use it as a transport and use the DAC in my McIntosh MX132.
Any advice is appreciated, THANKS!!!
rodH is offline
post #2 of 159 Old 05-19-2008, 10:22 PM
Bill Dietz's Avatar
Oppo 980 will do just fine, especially if you're using your Mac's DAC in which case spending any more than that would be absurd.
Bill Dietz is offline
post #3 of 159 Old 05-19-2008, 10:53 PM
Baccusboy's Avatar
I own the Oppo 980H, and it works very well sending via DSD. You can send it via PCM and it sounds about the same. The only difference I noticed is in channel levels between the two. Balance that out, and there is virtually no difference. The confusing thing about the Oppo (which is in the manual) is that you have to set the output by clicking the HDMI button before you get any high-resolution 5.1 channel sound. The upscaling must be set at 720p or above for the multi-channel to work, and there is no actual menu selection for it. You have to use the remote or the button on the front of the player.
I have no other basis for comparison -- other than my PS3. I'm sure you'll find a lot of people saying that analogue outs on other brands will sound better. That may be so. I have no idea, though.
Other companies I hear talked about include the Marantz 7001 player, Cambridge audio's Azure series (various models at different prices), and some Denon players.
"Any reviewer that didn't rail against this [Young Guns Blu-ray encode] should be sued, and Lionsgate should be ashamed of themselves. " - msgohan
Baccusboy is offline
post #4 of 159 Old 05-20-2008, 09:10 AM - Thread Starter
rodH's Avatar
Thanks for the reply guys.
What If I am NOT using HDMI cables to my pre/pro, is this method still going to work?
rodH is offline
post #5 of 159 Old 05-20-2008, 09:18 AM
ldgibson76's Avatar
Quoted: 14 Post(s)
Hello "rodH"
I found something you may be interested in.....
http://www.audioadvisor.com/prodinfo.asp?number=NAT585
As you will see if you haven't already clicked unto the link, this player is normally msrp'd at $1299.00. For $499.00, it's a great deal on a surperb
product. And it addresses what you want out of a SACD/CD player!
Tell me what you think.
Regards.
"Chance favors only the prepared mind." Louis Pasteur
Ldgibson76
Current Ensemble
ldgibson76 is offline
post #6 of 159 Old 05-20-2008, 12:35 PM
WilliamZX11's Avatar
Quoted: 25 Post(s)
You may also want to look at this one:
http://www.audioadvisor.com/prodinfo.asp?number=PACD200
Normally $1500.
WilliamZX11 is offline
post #7 of 159 Old 05-20-2008, 01:46 PM
Stereophile's Avatar
Kindly Refer To #5 & #6 Links.
Is There Any One Knows Which Of The Following Is
Performing Better:
Nad - T585
Parasound - Pacd200
Many Thanks,
Stereophile is offline
post #8 of 159 Old 05-20-2008, 03:34 PM
Quoted: 25 Post(s)
I have not heard either one, but I did see them on display at a local dealer. I would pass on the NAD due to build quality, tray seemed very flimsy to me. The NAD does not list Divx/Xvid as a format it will play either, although that might not matter to some.
post #9 of 159 Old 05-20-2008, 04:33 PM
ldgibson76's Avatar
Quoted: 14 Post(s)
Performing Better:
Nad - T585
Parasound - Pacd200
Many Thanks,
No doubt! The Parasound D200 is the better player and buy! Not to mention that it's built to the 9's! What the hell was I thinking?!
Regards.
Ldgibson76
Current Ensemble
post #10 of 159 Old 05-20-2008, 07:15 PM
darkninja67's Avatar
Which brand is the Parasound based off of? I think someone said the Halo D3 was similar to a Denon.
darkninja67 is offline
post #11 of 159 Old 05-20-2008, 08:14 PM - Thread Starter
rodH's Avatar
That parasound looks pretty dang nice, and a great price.
I just have a couple questions regarding the universal player:
1. I already have a Sony scd-222ES sacd/cd player carosel, would this player really sound much better? the reason I wanted to go dedicated was to get better CD/SACD playback.
2. I wasn't really looking for a "universal" player, since I was going to buy a BR player by the end of the year that would handle all the DVD duties, so I was thinking it might be better to just invest the money into a cd/sacd player of slightly better quality.
THOUGHTS????
rodH is offline
post #12 of 159 Old 05-20-2008, 08:18 PM
Kal Rubinson's Avatar
Quoted: 773 Post(s)
Liked: 542
THOUGHTS????
Yeah but I wouldn't recommend a hi-rez audio player that didn't output MCH via HDMI today.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #13 of 159 Old 05-20-2008, 08:52 PM
ldgibson76's Avatar
Quoted: 14 Post(s)
You're such a killjoy!
Ldgibson76
Current Ensemble
post #14 of 159 Old 05-20-2008, 09:23 PM - Thread Starter
rodH's Avatar
I wont be using audio HDMI, my McIntosh doesn't support it, I just want to use it for CD/SACD and even DVD-A using analog and digital. No need for HDMI.
Kal, any experience with this player, I have read a couple reviews comparing it to the Oppo universal, sounds like the Oppo is better at picture (which I don't care) and this is better at Audio.????
rodH is offline
post #15 of 159 Old 05-20-2008, 10:15 PM
Dear Kal:
Most Hi end preamp does not have HDMI input. If I want a good
CD and SACD player, under $1,000 budge which one you would recommend ?
I value your expertise.
post #16 of 159 Old 05-20-2008, 10:20 PM
Originally Posted by ldgibson76 View Post
No doubt! The Parasound PACD200 is the better player and buy! Not to mention that it's built to the 9's! What the hell was I thinking?!
Regards.
Many thanks for your information.
Best regards,
post #17 of 159 Old 05-20-2008, 10:28 PM - Thread Starter
rodH's Avatar
before I pull the trigger, i'd like to hear some more opinions regarding this Parasound VS the oppo 983 (which is still a couple hundred less and MUCH smaller) with emphasis on audio.
rodH is offline
post #18 of 159 Old 05-21-2008, 05:48 AM
Quoted: 773 Post(s)
Liked: 542
Dear Kal:
They will, eventually.
Kal Rubinson
post #19 of 159 Old 05-21-2008, 07:04 AM
ldgibson76's Avatar
Quoted: 14 Post(s)
hello "rodH".
If the emphasis is on audio, then when it comes to the Oppo player of choice, it should be the DV-980H, not the 983. The technology in the 980 leans more to audio performance than video. It's still has good video performance, but audio is the virtue. Why? The DSD capability.
http://oppodigital.com/dv980h/dv980h_comp.asp
At $169.00, there's isn't a word or phrase available to me right now to describe the value this player offers!
That being said, although value is the strong point, that doesn't mean that it's an overall better buy than Parasound D200.
http://parasound.com/nc/d200.php
Now, at $599.00 this is a tremendous value also. You can consider this a hi-end product because a lot of the technology is past down from the flagship Halo model. The build quality alone, in my opinion puts this ahead of the Oppo. It's a beast. If the size of the D200 is not compatible with your setup, then I would suggest the NAD T585 at $499.00.
http://nadelectronics.com/products/d...sal-DVD-Player
Although, not the build quality of the Parasound, but a formidable player in it's own right.
And finally, if money is the virtue, than the Oppo is the obvious choice. Nothing to be ashamed about if you choose this player.
They all share similar technology at different levels.
I hope this helps.
Regards.
I hope this helps.
Ldgibson76
Current Ensemble
post #20 of 159 Old 05-21-2008, 07:46 AM - Thread Starter
rodH's Avatar
thanks for your insight, the oppo is tempting, BUT I am primarily interested in the unit for SACD/CD music and it will replace a Sony ES changer, so I bet I don't get an increase in SQ over that with the Oppo. I would think the Parasound would be a step up as a dedicated player and/or transport. The fact that it has HDMI and video would just be a slight added bonus.
dang, decisions.
Regarding HDMI for the pre/pro as KAL mentioned, yes, i can get one to replace my Mc, but the MX136 just went to $10k for the unit, so that upgrade isn't happening any time in the next several years for me.
hello "rodH".
I hope this helps.
Regards.
I hope this helps.
rodH is offline
post #21 of 159 Old 05-21-2008, 08:55 AM
davidimdpt's Avatar
hello "rodH".
I hope this helps.
Regards.
I hope this helps.
Okay so it seems if we have a budget of about $1,000.00, then for audio first and video second, then these are the best choices from first to last
1. Onkyo DV-sp1000
2. Parasound Halo D3
3. Parasound - Pacd200
4. Nad - T585
5. Oppo 980
Please correct me if I am off.
Supporter of whatever looks and sounds good to me
davidimdpt is offline
post #22 of 159 Old 05-21-2008, 09:23 AM
Quoted: 773 Post(s)
Liked: 542
1. Onkyo DV-sp1000
4. Nad - T585
5. Oppo 980
Only for use with analog outputs.
Kal Rubinson
post #23 of 159 Old 05-21-2008, 09:34 AM - Thread Starter
rodH's Avatar
and what about digital?
rodH is offline
post #24 of 159 Old 05-21-2008, 09:42 AM
davidimdpt's Avatar
+1
I have everything through HDMI at this point
post #25 of 159 Old 05-21-2008, 10:08 AM - Thread Starter
rodH's Avatar
+1
Actually, I guess for me, digital doesn't even matter, my Mc pre/pro will probably have a decent DAC. I guess the hot topin on the forum is if all CD players sound the same using a digital signal.
rodH is offline
post #26 of 159 Old 05-21-2008, 10:37 AM
ldgibson76's Avatar
Quoted: 14 Post(s)
+1
So if HDMI is not that important, and the budget is $1000, the choice is obviously......the Marantz SA8001!
Hello again "rodH"
Are we making this harder than it needs to be!?!
The Parasounds and the NAD models can be had on the cheap, well over 50% off the list. That makes them the logical choice! But if you don't need hdmi and you want to be able to keep your McIntosh as a relevant part of your system, then go with the Marantz and get it over with! Plus it to utilizes the DSD technology, so you don't lose your quality when listening to SACD's in 2 channel over toslink or coax digital connection. The only down side, if you want to consider it as such, is that 5.1 connectivity is not part of it's feature set.
http://us.marantz.com/Products/1644.asp
http://us.marantz.com/stereophile.09...ntz.SA8001.pdf
Now, when you look at the specs of the Marantz, DSD is not shown in the initial description. You have to go into the specs page and you will see it listed in the format playback section. I guess Marantz felt it wasn't something to brag about, as if it's a no-brainer to have this feature!
Did I just make this more confusing?!
Regards.
Ldgibson76
Current Ensemble
post #27 of 159 Old 05-21-2008, 10:54 AM - Thread Starter
rodH's Avatar
Hello again "rodH"
Regards.
so wait, when listening to the other players, I am NOT using DSD? but it is being converted via the digital converter?
I thought the best way to use SACD (and dvd-a) is to hook it up via analog, so you never lose the resolution (the signal resolution isn't being limited based on what the DAC can handle, it is just passing the analog signal straight through the processor. Is this NOT how the other players listed work?).
If not, what players pass a true DSD signal and is that analog or digital?
rodH is offline
post #28 of 159 Old 05-21-2008, 11:15 AM
TreyS's Avatar
Make sure you are sitting down before you click this link!
http://us.marantz.com/Products/1947.asp
Back to reality, I just bought a used oppo 981 and have my first SACDs on the way. Looking forward to listening to them.
That SA8001 looks like a nice choice for you though.....
TreyS is offline
post #29 of 159 Old 05-21-2008, 11:15 AM - Thread Starter
rodH's Avatar
here is what the parasound says, but not sure exactly what this means:
"SACD goes directly to audio DACs as a DSD bit stream "
and
"and SACD DSD bit streams are sent directly to the audio DAC's, eliminating intermediate conversion that can be detrimental to audio fidelity"
rodH is offline
post #30 of 159 Old 05-21-2008, 11:15 AM
ldgibson76's Avatar
Quoted: 14 Post(s)
I apologize for the error. DSD can only be achieved via analog connection. But all the players we've mention give you the choice of how you want listen to your music.
http://www.dsdproaudio.com/html/dsd_sacd_explained.html
Again, I apologize for the error.
I'll tell you what though, I wish I was in a position to purchase one of these players myself. I envy you! This topic makes me want to drop kick my Denon 2910!
Regards
Ldgibson76
Current Ensemble
Reply CD Players & Dedicated Music Transports
