Cd treatment fluid - another snake oil? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 213 Old 06-13-2008, 07:00 PM - Thread Starter
geekhd's Avatar
Ok, I've seen this kind of stuff before. It goes through the regular routine. In the white paper page they lay out the problem and deficiencies that our current music source has and then they lay out the solution, then followed by testimonies. And as you guessed it, the product is expensive as he!!.
Here's the thing called Ultra Bit Platinum Cd Treatment
I'd say it is (snake oil). What say you?
geekhd is offline
post #2 of 213 Old 06-15-2008, 11:30 AM
ChrisWiggles's Avatar
If you have to ask...
ChrisWiggles is offline
post #3 of 213 Old 06-15-2008, 05:25 PM - Thread Starter
geekhd's Avatar
I'm relatively new at this hobby called AV so I can't help having questions often.
geekhd is offline
post #4 of 213 Old 06-16-2008, 09:12 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
Yes, snake oil. Because of our biased hearing, we will convince ourselves that treated CD's sound better than untreated ones and we will recommend it to others. That's how the high end audio industry operates.
I didn't bother to click on the link, by the way. Give it a little thought. What is encoded on the CD is digital data. Someone is trying to convince you that his treatment will alter the data that the CD players reads from it? Give it a little thought. Common sense will lead you to the right conclusion.
FMW is offline
post #5 of 213 Old 06-17-2008, 07:27 PM - Thread Starter
geekhd's Avatar
I'm not familiar with digital data scan technology with laser and etc. So I'm curious what the gurus would say about the quote from their white paper below (sorry little long). It's got a lot of tech terminologies and I'm simply overwhelmed.
What do we have here?
"Surface Contamination
Foreign matter on the transparent polycarbonate protective surface of a disc's encoded reading or burning side may cause distortions/diffractions that scatter the reading laser beam (beams in the case of three beam players) or block its path entirely, causing momentary interruptions of data reading, or mistracking or both. Long before audible mistracking or data loss occurs, excessive error correction/servomotor action may mean increased noise and distortion that decreases clarity, reduces transparency and adds harshness with high frequency glare. And as you may already know, some of the success of separately powered transports, analog amplification stages, and outboard digital-to-analog converters (DACs) has been attributed to the greater isolation of their power supplies from electrical interference caused by overstressed tracking and reading servos. The digital jitter caused by faulty data or clock recovery can also spoil the integration of harmonics to its fundamental and the relationships of the fundamentals to each other. In severe cases all manner of extraneous noises from clicks and pops to actual muting may be heard, and the player may act as if it's stuck in one spot or instead skips forward and backward continuously.
Brand new, fresh out of the package CD's are often coated with mold releasing agents or other substances left over from the manufacturing process. This type of contamination is often invisible. Therefore, if you have any reason to question the cleanliness of a CD's surface you probably should clean it, unless of course, you still resist the idea of cleaning CDs because you haven't discovered yet, that the claim CDs represent perfect sound forever, and unlike vinyl records, are practically immune to dust and dirt or damage is more mythical than factual.
Shouldn't the playback problems be corrected at the source? Misread music or clock data may mean misplayed music at the player's output. The better and more efficiently a laser tracks and reads the bit stream the better it should sound. Fortunately, although a mistracking laser beam may cause digital glitches and dropouts, it doesn't damage a CD's pits and lands, unlike a mistracking phono cartridge's stylus that damages a vinyl record's grooves.
Surface Scratches
In 1982, when CDs became the new music storage media, the only way to repair scratches was by polishing. While it's true that relatively large scratches or damaged areas may be restored by careful polishing with mild abrasives, you'll invariably end up increasing the number of fine scratches on the disc's playing surface. So although you may reduce or eliminate most of the grossly audible effects of mistracking, you may severely compromise low-level accuracy and musicality. Abrasives in any amount should only be used as a last resort to make an unplayable disc playable, or to eliminate extreme mistracking and or muting. If polishing a disc becomes necessary, we suggest that you don't try to fully correct the damage with one application but rather do a little polishing, a lot of cleaning, and then some listening. If necessary, repeat this process until either the defects have been audibly cured or you cease to hear further improvement. That way you may avoid most of the unpleasant side effects from the damage that occurs when fine scratches mar a previously unblemished portion of the disc's surface.
But, a lot has changed in the eighteen years since the first version of this White Paper was written in 1989 for our first product Finyl the Digital Solution*. Now there's a new method of recovering pristine data that doesn't cause additional harm to the original damaged disc. By using a CD duplicator such as Digital Systems'& Solution's RealityCheckCD Audiophile Grade Duplicator (RCCD-AGD), whose ability to accurately read damaged discs is much more robust than almost any CD or DVD player, a severely damaged disc that's copied to CD-Rs retains all the original data and sounds more musical than the original disc when it was new*, unless the disc is so severely damaged that the duplicator can't read it either. This process is analogous to using a copy machine to make an unwrinkled copy of a wrinkled original. Copying a disc with a stand-alone duplicator produces a first generation CD-R that's polarity inverted relative to the polarity of the copied disc which enables you to correct the polarity of a polarity inverted original. A CD-R copy of the first generation CD-R will make a second generation CD-R that will be in the same polarity as the original disc and will sound at least as good as the first generation polarity inverted CD-R and better than the original. RCCD-AGD copying takes place at four times real time (or faster as set by the user), making it a much quicker process than removing scratches by polishing. If you're interested in the significance of listening in absolute polarity, we can mail or e-mail you a paper titled A Speculation Regarding Perception of Detail.
We think it's safe to say, there's a general consensus among audiophiles about much of what's been said so far. But from here on differences of opinion may not be so easily resolved. At one extreme the pure subjectivists only trust their ears and have little use for measurements or specifications. At the other extreme, strict objectivists make measurements and study specifications because they don't trust their ears. Then there are the majority of listeners between these two extremes who simply want to enjoy the music for the sheer pleasure, choosing to avoid anything that might otherwise distract. Perhaps what's needed to resolve the differences of opinion, as distasteful and tedious as it sometimes becomes, are double-blind tests to convert some of that intense heat into light.
Does the lack of measurable data explain why UBP is the digital solution engineers hate to love? Without a doubt they love its sound, though when asked to explain why applying UBP to a perfectly clean disc could improve its sound, they express their doubt as follows: since the digital signal can only assume two values, on and off, with nothing in-between (otherwise known as bits are bits), once a disc is clean no further treatment should be beneficial. But seldom is anything concerning audio as simple as it first appears or sounds. We think that when you understand more about the way a laser reads a disc you'll appreciate why we call UltraBit Platinum The Digital Solution. With that in mind we offer the following for your thoughtful consideration.
History of the Problem
We at Digital Systems & Solutions, like many others, felt that CD sound wasn't realizing its full potential. Despite all the improvements in recording and mastering techniques, including oversampling, upsampling, reclocking, playing from a hard drive, or from a memory without any moving parts or vibration, various advanced filtering schemes, the use of vibration dampers and isolation devices with disc stabilizers, the full musical promise of the CD had yet to be fulfilled. Could some heretofore-unknown ingredient be missing from the CD reproduction chain?
From the outset we decided to limit our search for improvements to those that would be inexpensive, practical and wouldn't void a player's factory warranty. It would also need to be compatible with all players, whether upgraded or not, as well as all laser-read media. UBP isn't only compatible with all factory stock players, it's also synergistic with all modifications and accessories. Not only is UBP inexpensive and practical (two ounces will treat all surfaces and edges of about 500 4-3/4 inch discs), it's a necessity for maximum playback resolution and fidelity of all stamped or burned discs. No player, whether totally upgraded or factory stock, can be guaranteed to achieve its full potential if the data stream it processes has been corrupted by misreading. If you think you like the sound of your player now, imagine just how much better it will sound with lower electrical interference when it receives the bit stream with minimum jitter, music data and clock data intact, with nothing added and nothing taken away. Isn't that what high fidelity is all about?
The Encoding of the Disc
The accompanying illustration should help you understand our written explanation of how optical impedance matching (OIM) can improve the accuracy of recovered encoded music data's electrical signals produced by the reflected laser beams read by the player's photodiodes.
Notice that although we refer to pits and lands (the lands are flat areas between and around the pits), the laser beam actually reflects off the backsides of the pit bottoms which appear as bumps to the laser beam(s). That's because commercial CDs are stamped from their label side making the pits concave on the label side and convex on the reading side. We will, however, continue to describe the bumps as pits.
Our illustration shows that a continuous pit or land represents an encoded 0 and a pit edge represents an encoded 1. That means steady state reflections represent encoded 0s, and transition states from lands to pits or vice versa represent encoded 1s. This rather clever scheme saves considerable disc space over one that uses each pit or land to represent 0s and 1s directly; it does, however, require two distinct reflectance states to read the data. There's a high-level of almost total reflectance of the beam from lands or pits
and a low-level of reflectance when the beam transits a pit edge and splits into two beams, when their almost simultaneous reflections recombine, because the pit's height is 1/4 of the laser's wavelength. In other words, the split beam's reflection from a land recombines with its reflection from the pit, and the 1/2 wave length difference between pit and land reflections (1/4 down to land and 1/4 up to pit bottom) tends to make the two beams cancel each other due to the 180 degree phase difference between them attenuating the signal's amplitude at the photodiodes.
The Problem
Any ambiguity or confusion between the high and low reflectance states will probably corrupt the data stream with digital glitches and dropouts. Starting with a clean disc, what factors could impede the reading process? One factor is the partial reflections of the laser beam(s) at the disc's reading surface (which is made of polycarbonate and labeled TRANSPARENT SUBSTRATE in the illustration) which it crosses twice, once on its way to the encoded surface, and then back again on its way to the reading and tracking photodiodes. Another factor is the scattering of the laser beam off the pits (bumps) toward the disc's inner and outer rims (edges) and partial reflections back (because of the .55 difference of the indexes of refraction between the air and disc's rims, explained below) to the reading photodiodes that may interfere with the main reading or tracking beam(s). Measurements at an optical laboratory show that UBP lets more light out at the disc's edge than opaque treatments absorb which makes it more effective than any of the opaque edge treatments we tested, and unlike opaque treatments, you don't need to worry about getting UBP on the reading surface because it's meant to be applied to the entire disc. Misreads may also occur when the laser is defocused and dispersed or diffused due to unwanted refractions by imperfections on the disc's surface. CDs may appear flat and smooth to the naked eye, but under a high magnification with a scanning electron microscope even the best CDs look rough and uneven. A scratch, so tiny that otherwise it might have gone unnoticed, could dominate the view.
Reflection and refraction occur at the interface of the disc's surface with the air because the refractive index of air and polycarbonate are different from each other (approximately 1.00 and 1.55 respectively). The index of refraction of a coating that minimizes the disc's reflectivity is about 1.2455, the geometric mean of 1.00 and 1.55. If the indexes of refraction of air and polycarbonate were equal, then applying UBP to the disc wouldn't be optically impedance matching, as the two mediums would already be perfectly impedance matched. Partial reflection takes place each time the laser beam crosses the disc's surface (air and polycarbonate interface) and disturbs the intensity of the reflected returning beam. In optical physics this is called constructive or destructive interference depending upon whether the relative phase between the reflected beam and returning beam reinforces or cancels respectively the returning beam's amplitude. Refraction and diffusion of the beam by surface defects or imperfections also takes place in both directions causing a defocusing and diffusion of the beam that disturbs the amplitude and integrity of the signal received at the photodiodes. Therefore, although the laser beam starts out tightly focused and nearly 100% coherent, it may end up much less focused or coherent and will be diminished in its overall intensity. The net effect is that a disc treated with UBP improves a beam's reading and tracking by focusing it to a smaller more precise spot at its focal point on the encoded layer. This allows a beam to track and read the data with greater accuracy with quicker more distinct transitions between low and high signal states due to greatly reduced reflection of the laser at the interface of disc and air with less diffraction or diffusion of the beam by surface scratches. UltraBit Platinum applied a CD player's photodiode lens will also improve the optical impedance matching of its interface with air, but it should be applied very carefully to avoid damage.
Erratic shifts of the beam's intensity or amplitude at the photodiodes may cause the bit stream to become so corrupted by errors that even the most advanced error correction algorithms, currently in use, could fail to reconstruct the bit stream sufficiently which causes the audio output to be interpolated or muted. If this occurs, it forces the player's error concealment circuits to take over, which inevitably results in a serious degrading of playback fidelity and musicality. In addition, one shouldn't be surprised when the player or transport tracking servos also misbehave if they are triggered by false signals from their photodiodes. Misread digital words that represent the encoded data may have any number of digital signal glitches and dropouts randomly distributed from the least significant bit to the most significant bit and anywhere in between. If errors go undetected, frequency components of the audio signal will not be harmonically related to the original signal and consequently will not be well masked by the music. Then music that's meant to be enjoyed may turn out less emotionally fulfilling than it is enervating, which is another possible source of digital listening fatigue.
Again, if there's interference with analog circuits or data errors get to the DACs undetected or there's excessive jitter, the random nature of digital glitches dropouts that may occur, means at any particular instant the number of ways the playback sonics are degraded and detract from musicality are not strictly predictable. The following is a list of possible musical and sonic deficiencies that may result:
1. Generally increased harshness or roughness that distorts the high frequency harmonics and contributes to an overall loss of smoothness;
2. Poor articulation of bass and mid-bass notes;
3. Attenuation of dynamics and smearing of transients;
4. Increased noise with loss of both inner detail and intertransient silence;
5. Reduced mid-range presence that diminishes clarity and transparency;
6. Loss of image specificity and focus;
7. Reduction of the apparent width and depth of the soundstage, virtually eliminating the possibility of holographic imagery;
8. Decreased resolution of the low-level detail that is so necessary to the recovery of hall ambience;
9. Altered instrumental and vocal timbres that lack coherence or cohesiveness; and
10. A loss of rhythmic drive and pace.
From a musical standpoint the above list barely begins to scratch the surface. Some of the musical values that suffer are listed below, and again the list may not be complete:
1. Subtle breath effects on brass or wind instruments become more difficult to discern as are nuances of fingering and bowing on string instruments.
2. Vocal texture and expression are obscured.
3. Instrumental lines and musical themes are more difficult to sort out.
4. Complex rhythms and tempos are less easily followed.
5. Above all, it will not be as an emotionally involving and satisfying musical experience than might otherwise have been possible.
Given the above list of possible faults it's no wonder so many music-loving audiophiles are so vocal in their criticism of the sound of laser-read media.
The Search for a Solution
We decided early on that the best place to begin searching for answers was at the beginning, because the first stage in the reproduction chain we could improve was the reading of the disc. The logic of this approach appeared to be self-evident, since the disc is the first element in the reproduction chain the consumer has the option to modify or treat.
In theory, the perfect solution would be to immerse the player's optical system, disc and all, in a liquid with an index of refraction equal to polycarbonate's in order to make the disc's surface optically disappear, scratches and all. By eliminating the air, we also eliminate the .55 difference between its optical impedance (index of refraction) and that of polycarbonate. Although surface reflection and refraction would now be nonexistent, a new problem arises because the .55 difference of the air's refractive index and that of polycarbonate helps to focus the laser on the disc's metallic reflective layer where the encoded data is found. You may want to refer to the illustration of the DISC PROFILE. But even if the index of refraction air and polycarbonate were the same UBP would still be a good disc cleaner and static discharger because it protects the surface from contamination and the disc's tendency to become re-charged. With the immersion approach eliminated from serious consideration, we set out to find a more realistic soluton. The result is UltraBit Platinum the Digital Solution.
UltraBit Platinum represents our best effort to strike an ideal balance between scientific analysis and aesthetic judgment. As a single layer interface, UBP's formulation had to be tailored with two conflicting requirements in mind. The first is the necessity of minimizing surface reflections, and the second is filling in surface imperfections to eliminate the diffraction and diffusion they cause. The first objective requires an index of refraction equal to the geometric mean of the two different indexes of refraction (air and polycarbonate), whereas the second objective requires the single layer to have the same index of refraction as the polycarbonate substrate. By concentrating on the first objective, to the exclusion of everything else, we were able to cut surface reflections roughly in half. The improvement in the sound and musicality was nothing short of dramatic. However, despite our wonderful first impression, like so many music-loving audiophiles, we soon craved even more improvement. Even though the elusive goal of ultimate playback fidelity had once again escaped our grasp, which probably meant a lot more research and development, we refused to be deterred.
Next we investigated interference coatings that potentially can reduce reflections to almost zero, but it soon became apparent there might be certain insurmountable drawbacks in our specific application. Interference coatings are wavelength specific, whereas lasers used in current CD players may have somewhat different frequencies, at least according to their published specifications, and DVD players have blue lasers of a much shorter wavelength than CD players so an interference coating won't work. We could have made different versions of UBP for the most popular players, but then to play a treated CD on different players you'd need to remove one version before applying another version. And although UBP can easily be cleaned off with our CleanDisc disc cleaner, we quickly discarded the idea, because we felt it was too much trouble for the small gains that might be realized. More critical yet, an interference coating is extremely sensitive to the angle of incidence of the light passing through it. Because different angles of incidence represent different film thicknesses to the laser beam, since laser beams consist of both parallel and nonparallel rays, interference coatings wouldn't work all that well anyway.
The Listening Test and Finding the Solution
Now that we had done the science it was time to do the art. If we could optimally combine UBP's Optical Impedance Matching properties with its ability to reduce the degrading effect of surface defects, perhaps we would finally hear a compact disc achieve its full musical potential. Our only goal was the maximum improvement of the sound and musicality so listening tests were absolutely crucial.
To avoid setting our sights too low we wanted to find out what the improvement would sound like if the only objective was enhanced musicality. This would create a reference standard we could use to gauge the success of formulations that might be only slightly less enhancing but much less costly to produce. Next we had to make sure UBP would also satisfy our other requirements. Having made excellent progress, with the release of a finished product appearing imminent, we suddenly realized we overlooked one of the most important requirements of all, that the use of UBP would never harm musical or sonic values. When the tests for possible negative effects failed to produce any usable results, it was abundantly clear we had grossly underestimated the difficulty of the listening task. We decided the best way to beta test UBP was to enlist the aid of a panel of expert listeners dedicated to advancing the state of CD fidelity. All panel members were experienced music loving audiophiles and most had at least some musical training and/or technical degrees. They listened to practically every type of music on a huge variety of systems and players. This included a full spectrum of CD players, DVD players, from inexpensive portables to very elaborate and obscenely high priced two or more piece players as well those with tubes analog sections. Nor did we leave out modified players and accessories such as disc dampers, damping rings, disc edge trimmers, static dischargers, demagnetizers, isolation feet, just to mention a few. Many of the listening sessions were conducted in double-blind fashion to minimize the effect of listener bias. Many other disc optical surface treatments were included to be sure we had a real winner. CDs were compared with their vinyl counterparts whenever possible, but our ultimate reference remained the sound of live unamplified acoustic instruments and voices heard from an aesthetic distance in a natural acoustic environment, which many audiophiles and audio gurus define as the absolute sound (TAS). We needed over one hundred iterations to perfect UBP's unique formulation and sonic properties before it attained the highly refined state it enjoys today.
Last but not least, to solicit opinions from listeners with impartial perspectives, numerous samples were sent out to both prospective customers and potential distributors. Their perceptive and very astute feedback gave us many useful insights and much encouragement. We are especially gratified by their enthusiastic support for the concept behind Utrabit Platinum. Simply stated, Maximum playback fidelity begins at the disc surfaces.
Conclusion
When at last the testing was completed and we tabulated the results, the evidence was overwhelming. The listening panel had established a consensus. If a laser read media disc hasn't been treated with UltraBit Platinum then you haven't really seen or heard it. We carefully analyzed and reanalyzed the test results from every perspective we could think of to see if we could find even the slightest discrepancy, but nothing turned up to change our minds. At last there was positive verification that UltraBit Platinum meets or exceeds all of our original goals! We believe that UltraBit Platinum sets a new reference for disc treatments that enhance fidelity and musicality, and we think you'll agree with us that its price is more than commensurate with its results. We honestly believe that for the fore-listenable and fore-seeable future UltraBit Platinum will remain unequaled in its ability to bring forth music and video images from laser-read media.
We worked long and hard and used all of our technical know-how and listening skills so you could make the UltraBit Platinum listening test. Our ultimate purpose will be fulfilled if UltraBit Platinum enables you to enjoy the greatest possible emotional involvement with the aesthetic values of music. But ultimately for you, it's only your let the bits fall where they may critique that matters."
geekhd is offline
post #6 of 213 Old 06-17-2008, 08:05 PM
Wilfred's Avatar
As a famous wabbit once said, "Unga bunga bunga inga binga binga bunga!" So much marketing babble, so little real information. If there were a real effect, just a comparison of the eye patterns is all that is necessary. If the eye patterns of a treated and untreated disc are indistinguishable, then there is no effect. Period.
Wilfred is offline
post #7 of 213 Old 06-17-2008, 08:45 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
They call it a 'white paper" because they want you to think it's written by scientists. It isn't; it's advertising copy. The folks who actually wrote it probably have no more idea what the jargon means than you do.
Simple truth: A laser either can read the data, or it can't. A CD has to be pretty dirty before it can't be read. Once it's that dirty, all you need is mild soap and water. End of story.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #8 of 213 Old 06-18-2008, 05:35 AM
FMW
FMW's Avatar
Liked: 1684
This is typical of the techno babble you see in the high end audio "tweak" business. Like I said, think about it logically and try to imagine how some "treatment" would change the value of the digital bits encoded on the disc and why it would necessarily change it for the better if it could. Jitter has attracted these "tweakers" like a flame attracts a moth because it provides all kinds of opportunity for technobabble. However, jitter isn't audible. It never has been. That's been proven over and over.
FMW is offline
post #9 of 213 Old 06-18-2008, 09:47 AM
PULLIAMM's Avatar
Definitely snake oil. In fact, that may be one of the ingredients!
PULLIAMM is offline
post #10 of 213 Old 06-18-2008, 10:49 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Oh, it's a cleaning solution.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #11 of 213 Old 06-18-2008, 11:55 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
aka soap & water.
mcnarus is offline
post #12 of 213 Old 06-22-2008, 09:12 PM
Christian's Avatar
Agreed. Treat your CD's with care, and carefully clean them if they get dirty. Soap and water works for me.
Christian is offline
post #13 of 213 Old 06-24-2008, 10:27 PM
Erik Tracy's Avatar
Following this techno-babble logic - we would be best advised to disassemble our hard drives and clean the platters so that our powerpoint files glisten like the fresh dew of morning, so that our emails read like crystal cut gems of knowledge, exhalt at the rediscovered clarity of your excel spreadsheets.
Zeroes and Ones rendered in unmatched fidelity like sheer cliffs of unparalleled straightness.
Blah blah blah.
Keep it clean and relax.....and save your money.
Erik
Erik Tracy is offline
post #14 of 213 Old 06-25-2008, 04:43 PM
OB_Ron's Avatar
I've heard the benefits. UltraBit Platinum isn't snake oil. Just try it. It's amazing.
There are many possible mechanisms of benefit other than changing the data (the bits). The benefits are fairly uniform and consistent -- therefore, it doesn't make sense that it is changing any bits most of the time. I believe UltraBit Platinum, and other optical disc conditioners, provide an improved signal-to-noise ratio at the analog optical pickup. This allows the servo-tracking and bit detection mechanisms to do their job more easily, thus lowering noise in the circuitry, and thus lowering noise in the power supply and reducing EMI/RFI within the player. Problems with EMI/RFI between nearby circuits, and within audio equipment enclosures, are often highly underestimated by engineers and audiophiles. Ground quality is another often underestimated factor. I carefully treated my Benchmark DAC1 with Stillpoints ERS material for absorbing and diffusing EMI/RFI (keeping it a good distance away from sensitive circuitry) just for the purposes of quieting the internal electromagnetic environment. The results were astonishing -- much smoother, cleaner, sweeter, more enjoyable. So I believe anything that can quiet the EMI/RFI environment inside an audio component without interfering with its natural operation is likely to provide audible benefits. I think UltraBit Platinum conditioning does that.
Internal power supply design and external AC power and AC power conditioning, including power cords, can have dramatic effects on sonic performance. It's not too hard to imagine that UltraBit Platinum conditioning may reduce noise fed back to the AC power line, or EMI/RFI in the local environment, thus creating benefits for other components within an audio system.
Figuring out the mechanisms is important for the engineers, because the fact that UltraBit Platinum does provide significant benefits means their electronic designs are not doing their job well. Ideally, the optical signal should be totally isolated, and have no sonic effect if the bits are read the same. I hope the engineers can use UltraBit Platinum as a tool to help them figure out what they are doing wrong.
UltraBit Platinum shouldn't provide any significant audible benefits -- but it does! Just try it, and be your own judge. Satisfaction is guaranteed, so you are only risking your dogmatic belief that bits are bits.
OB Ron, MSEE and a friend of the creator of UltraBit Platinum
PS Check out The Absolute Sound magazine's upcoming Digital Focus issue.
OB_Ron is offline
post #15 of 213 Old 06-25-2008, 05:26 PM
Erik Tracy's Avatar
Be sure to use this cable too!
http://www.usa.denon.com/ProductDetails/3429.asp
Erik
post #16 of 213 Old 06-25-2008, 05:31 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Yes, folks, that is what snake-oil salesmanship sounds like. Here's my favorite bit:
I guess if the "optical pickup" is analog, then it could indeed have a signal-to-noise ratio worth caring about.
Presumably where you will find more of the same.
mcnarus is offline
post #17 of 213 Old 06-25-2008, 05:48 PM
WilliamZX11's Avatar
Quoted: 25 Post(s)
Kinda says it all right there. How could a friend of the creator lie to us? What motive would he have?
WilliamZX11 is offline
post #18 of 213 Old 06-25-2008, 05:58 PM - Thread Starter
geekhd's Avatar
Since it's audible, it should be measurable and presentable. All this talk is cheap. Just show some measurements, "before & after" or "with vs. without". It's that simple.
Wait a minute,
You think? In other words you are not sure and it could well have been a placebo effect...
geekhd is offline
post #19 of 213 Old 06-25-2008, 06:05 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 252
And this is a guarantee of and for what?
AS is just another audio rag of useless info.
Do you have hard data to support any of the claimed outcome due to this fluid? Publish that, not what that rag imagines or makes up about it?
By the way, you did your comparisons DBT, right? You mean you didn't?
CharlesJ is offline
post #20 of 213 Old 06-25-2008, 06:17 PM
OB_Ron's Avatar
I forgot to include as a mechanism for UltraBit Platinum's audible improvements, the potentially most obvious and well acknowledged factor, digital clock jitter. There are many designs for reducing jitter, and the negative effects of jitter are pretty well known. UltraBit Platinum probably helps reduce initial jitter components, and thus makes it easier for the jitter reduction circuits to produce a higher quality result. Additionally, EMI/RFI, ground noise, and power noise all contribute to jitter, so unless you have a memory player that stops the optical drive while the music is playing, UBP may provide benefit even if the DAC is independently clocked.
To you cynics, I have no financial connection with UltraBit Platinum.
How can you criticize something you haven't even tried, and obviously don't understand?
OB Ron
OB_Ron is offline
post #21 of 213 Old 06-25-2008, 06:20 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Maybe if you didn't buy products from wanna-be 'engineers', OB_Ron, they wouldn't be doing all that underestimating
Chu Gai is offline
post #22 of 213 Old 06-25-2008, 06:23 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
OB Ron
My pappy, before he died, gave me one of these although they're hard to find in San Diego.
As for understanding...sheesh.
Chu Gai is offline
post #23 of 213 Old 06-25-2008, 07:07 PM
OB_Ron's Avatar
To the Cynics, again,
Check out the review of UltraBit Platinum on the EnjoyTheMusic web site. The author is obviously not a friend of the creator. In fact the author says the testing and review were difficult to do because of a previous adversarial relationship.
Enjoying music is what matters, not measurements. Your ears and brain are what count.
I haven't done a DBT with UBP, but others have, and the UBP treated discs were pretty consistently picked out as providing superior sound.
The difference with UltraBit Platinum treated discs isn't subtle in most systems. If an audio system is performing well otherwise, UBP may produce a WOW experience. You might be shocked -- if you just had the guts to try it.
No Bull-Crap,
OB Ron
OB_Ron is offline
post #24 of 213 Old 06-25-2008, 08:11 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
As are the thresholds for audibility.
Jitter is a phenomenon of digital-analog conversion. "Treatment" of the disk can't have any impact at all.
Oh, we understand.
I've never tried a perpetual motion machine either, but I can tell you exactly how effective it is.
mcnarus is offline
post #25 of 213 Old 06-25-2008, 08:17 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
That's because ETM exists to promote snake oil. If the author had an adversarial relationship with a maker of snake oil, he would naturally suffer cognitive dissonance.
mcnarus is offline
post #26 of 213 Old 06-25-2008, 08:26 PM - Thread Starter
geekhd's Avatar
OB_Ron, sorry to notice, you're not very good at this, are you. I've seen better online sales pitch than what you've put out. Far better ones.
Well, you have some homework to do. Get going now.
geekhd is offline
post #27 of 213 Old 06-25-2008, 08:49 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 252
I forgot to include as a mechanism for UltraBit Platinum's audible improvements, the potentially most obvious and well acknowledged factor, digital clock jitter. ...To you cynics, I have no financial connection with UltraBit Platinum.
OB Ron
Perfect. That is measurable!!!
Where is your data supporting this is a result of using this liquid??? No data??? Why not? Cannot produce???
Oh, it is easy to understand the snake oil. What is there to try? You, nor the maker have not made any convincing evidence for its usefulness outside of speculation, postulating, supposing and maybe?
The maker made a hude claim for their product with no supporting evidence.
CharlesJ is offline
post #28 of 213 Old 06-25-2008, 08:57 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 252
...Enjoying music is what matters, not measurements. Your ears and brain are what count.
No Bull-Crap,
OB Ron
I guess then you don't use measurements? Or, just not in audio applications?
As to the ear and brain, yes that is where things get translated and made into understandible terms. BUT, you forget, or don't even know, worse, how easy it is to fool your brain to imagine things that are not real. Please, you go ahead and have full trust in your senses, perhaps yours are more reliable and foolproof that all others.
As to those claimed DBTs and results, that is to be replicated, properly. Again, no need to hold breath as to the real outcomes
Yes, bull-crap.
CharlesJ is offline
post #29 of 213 Old 06-26-2008, 05:51 AM
eljr's Avatar
Quoted: 1050 Post(s)
Liked: 8028
It seems to have done pretty well for the human race.
To suggest that one's senses are not to be relied on is absurd.
And to do this with such pomp is incredible.
I think you misspoke.
eljr is offline
post #30 of 213 Old 06-26-2008, 06:00 AM
eljr's Avatar
Liked: 8028
Surface Scratches
The Problem
Conclusion
Better to give a link and write a synopsis.
eljr is offline
Reply CD Players & Dedicated Music Transports
