DAC question - AVS Forum
post #1 of 3 Old 10-25-2008, 05:45 PM - Thread Starter
bdz1's Avatar
I have a Denon 2930CI as my DVD/CD player. I run an HDMI cable to my Yamaha RX-V2700 which has a 24/192 Burr Brown DAC.
Am I correct in my understanding that, with the above setup, the digital-to-analog conversion in my system is being done in the Yamaha's DAC? If so, would I be better off letting the Denon do the D/A conversion and then running analog cables up to the receiver to play directly in "pure direct" mode?
Does it matter? I guess it's a question of which sounds better, but in theory, should it matter? Both are fairly upper-middle-end units.
Brian
bdz1 is offline
post #2 of 3 Old 10-25-2008, 08:31 PM
soundlovr's Avatar
You are correct that the Yamaha is doing the DAC work. The Denon 2930CI also has 24/192 Burr Brown DACs (PCM-1791a). There is no chance in the universe that you could ever hear a difference. None. Zero. Ziltch.
soundlovr is offline
post #3 of 3 Old 10-26-2008, 10:33 AM
fdiddy's Avatar
Good morning, my name is bionic ear.
fdiddy is offline
Reply CD Players & Dedicated Music Transports
User Tag List
